Manual transmission first gear only partially engaged
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rex3553, Sep 15, 2024.
  1. Sep 17, 2024 at 6:58 AM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
    The adm will change how the clutch grabs. You will be able to feather it and alllow differ t amounts of fluid to pass through. The accumulator is there to make it is easier for an inexperienced driver.
    After I changed my fluids, I was going uphill on a grade that often requires to drop some gears. ( 4 th is best, sometimes just 5th is okay. ). I downshifted and no giant clunk/slam, just went into gear, felt normal.
    If you have a ‘21 you probably need to change the transmission fluid out. If that is the factory fluid, it needs to go, it has done its job.
    a tune also helps out.
  2. Sep 17, 2024 at 7:00 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    I wouldn't be concerned about damage at all, it takes a lot more than that to really hurt a synchro or gear.
    Just wait until your rear wheels hit a bump at the exact same time you shift into a gear. You'll get a nasty grind that really makes you feel bad.
    Willy Lump Lump likes this.
  3. Sep 17, 2024 at 7:01 AM
    Rex3553
    Rex3553 [OP] Well-Known Member
    2021 Voodoo Tacoma 6MT
    Yeah it’s usually pretty easy to notice. The person who had it happen to them had never driven a Tacoma before so wasn’t used to the length of the throws and assumed it was fully engaged. I was just distracted and tired and must have granny shifted because usually I notice right away cause it definitely feels different when you hit the stopping point of a fully engaged first.
  4. Sep 17, 2024 at 7:02 AM
    Rex3553
    oh gosh not looking forward to that. I’m sure it will happen when I inevitably go off-roading. Thank you for the peace of mind though!
  5. Sep 17, 2024 at 7:04 AM
    BLtheP
    Plano, TX
    It's more at higher speed, like a pothole at 10 mph while shifting into 2nd...or something similar to that. It's very rare but if it happens just right, the shockload from the wheels will drive the countershaft faster than your shifter and synchro want to move to engage the gear, and you end up with a mismatch in speeds that are trying to mesh. Grind.
  6. Sep 17, 2024 at 7:04 AM
    Rex3553
    Dangit, I had just convinced myself I didn’t need it especially because of people mentioning warranty stuff with it. With the accumulator deleted does it engage harder like with a clunk? Because one thing I like about how the truck drives right now is how easy it is to have smooth starts in first.
  7. Sep 17, 2024 at 7:05 AM
    Rex3553
    That makes sense. Combined with the slop in the driveshafts these trucks have I’m sure that makes for an amazing noise.
  8. Sep 17, 2024 at 7:06 AM
    Willy Lump Lump
    21’ dcsbmt
    This and that
    I’ve been there on that one too. I’m sure the fj had more bottom end than the taco. off-roading with the manual trans, is a good time to explore 4lo. That’s a game changer, literally makes you think, I should use 4 lo more often.
  9. Sep 17, 2024 at 7:08 AM
    Willy Lump Lump
    21’ dcsbmt
    This and that
    I have a tune (sporty) and no acccumulator. When the truck is warm, I can drop the clutch and crawl little to no gas (depending on terrain obv). So it’s still pretty smooth out of first.
  10. Sep 17, 2024 at 7:11 AM
    Rex3553
    That’s for sure true. I drive the Tacoma and think it feels a little sluggish compared to the FJ until I get it up above 3000 RPM then the Tacoma feels like it’s flying.
  11. Sep 17, 2024 at 7:11 AM
    Rex3553
    Okay that may be worth it then. Have you ever had any issue with warranties?
  12. Sep 17, 2024 at 7:14 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Blip into first as you come to a stop but are still rolling, not after you stop.
    GBR and Rex3553[OP] like this.
  13. Sep 17, 2024 at 7:18 AM
    GBR
    GBR Well-Known Member
    19 TRD OR
    You should absolutely delete it. The only person I see it benefitting is someone who is completely dumping the clutch every shift with zero feathering.
    And funny you mention starting in first. That was the first thing I noticed being off with the accumulator. I'd pull the clutch out to the engagement point like any other manual, but with the accumulator that point is never consistent. I'd nearly always get pulsing through the driveline when starting from 1st.
    Also note that the 4th gen, with a nearly identical transmission set up, no longer uses the accumulator.
    Oh and +1 for the Motorcraft fluid. It's not a miracle in my trans but it's noticebly better.
  14. Sep 17, 2024 at 7:22 AM
    Rex3553
    Okay I’ll definitely look into it then. I’ve heard it’s not terribly hard to do (obviously just putting the disk in) but I’ve never bled a clutch or done any work in that area so I may see if my mechanic will install it.
  15. Sep 17, 2024 at 7:35 AM
    #35
    Willy Lump Lump
    21’ dcsbmt
    This and that
    I used the Acura brake hard line. Sent my accumulator off to die for science.
    I haven t made any warranty claims, not really worried about that, but I managed to get the shield back on so maybe a tech won’t look there?
  16. Sep 17, 2024 at 7:39 AM
    #36
    Willy Lump Lump
    21’ dcsbmt
    This and that
    It’s pretty easy to do. You need a flared end wrench for the lines. The bleeding process takes a minute to rebuild pressure. But can easily be done by one person. After I did mine, I drove uphill, from a dirt road to asphalt, the response from the truck was great. It threw some rocks and chirped on the road. Couldn’t believe it.
  17. Sep 17, 2024 at 7:55 AM
    #37
    Rex3553
    That is impressive I find it hard to believe I could chirp my tires with it like it is now.
  18. Sep 17, 2024 at 12:23 PM
    #38
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    It feels as bad as it sounds through the shifter. Tons of potholes in my area, it happens frequently. I just hope it's not causing damage.
  19. Sep 17, 2024 at 12:41 PM
    #39
    Rex3553
    I mean I doubt it and with the lengthy drivetrain warranty these trucks have I wouldn’t be too worried.
  20. Sep 17, 2024 at 12:59 PM
    #40
    BLtheP
    Plano, TX
    That is not an issue nor will it ever be. Uncomfortable, yes.
