manual transmission fluid change?
Discussion in '1st Gen. Tacomas (1995-2004)' started by neglected tacoma, Jan 13, 2015.
  1. Jan 14, 2015 at 4:38 PM
    neglected tacoma
    neglected tacoma [OP] Member
    4x4
    I'm just scared i will remove the wrong bolts lol
    I've changed the oil many times but never have tried anything else. Does the haynes repair manual show these things?
    It's been to cold to craw under it and look i should have done it in the summer.
  2. Jan 14, 2015 at 5:59 PM
    jkulysses
    jkulysses Well-Known Member
    Jake
    Oregon
    01' Tacoma 4x4 3.4l 5 spd
    Okay I literally just went outside at night in the cold and took these pictures for you lol.
    This picture shows the transfer case which is where the rear driveshaft attaches to. the bottom one, my finger is touching it, is the drain and the fill is up and to the right and looks exactly the same.
    This next picture is the fill plug for the transmission. This is right above the front driveshaft on the drivers side pretty much parallel with the rear of the front drivers side tire.
    The next two pictures are taken from the passenger side of the truck but the plug is right under the middle of the truck towards the back of the transmission right before it connects to the transfer case.
    Jake
  3. Jan 15, 2015 at 3:26 AM
    neglected tacoma
    4x4
    much appreciated Jake! :)
  4. Mar 9, 2015 at 2:27 PM
    Racerzl1
    Racerzl1 Member
    Quitman,Ms
    2003 Tacoma 4X4 SR5
    How many quarts of Redline MT90 are needed ,to do the Transmission oil change? Thanks.
  5. Mar 9, 2015 at 8:37 PM
    LogCabins
    LogCabins Well-Known Member
    Robert
    Oahu
    99 SR5 3.4L 4WD
  6. Mar 15, 2015 at 11:27 AM
    Racerzl1
    Racerzl1 Member
    Quitman,Ms
    2003 Tacoma 4X4 SR5
