Manual Transmission Fluid Change
Discussion in '1st Gen. Tacomas (1995-2004)' started by DustStorm4x4, Jan 5, 2016.
  1. Jan 5, 2016 at 1:34 PM
    DustStorm4x4
    DustStorm4x4 [OP] BBC 2020
    U S A
    04 Jeep LJ
    Can someone link to a how to video or a thread on how to change the manual transmission oil for the 3.4?
  2. Jan 5, 2016 at 2:39 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
  3. Jan 5, 2016 at 7:33 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I haven't seen one, but this is an EASY process, that should be done when oil is warm and vehicle is level...
    - Open/remove the FILL plug (so you KNOW you'll be able to re-fill what you drain) and remove existing crush washer
    - Open/remove the DRAIN plug and remove existing crush washer
    - Allow oil to drain
    - Replace DRAIN plug, including new crush washer (P/N 90430-18008, ~$1.50/ea)
    - Using hand pump (e.g., Bottle Hand Pump), refill transmission with appropriate gear oil (e.g., Severe Gear 75W-90)
    -- I like the Amsoil products linked. You are, of course, free to use whatever pump and oil you prefer, though 75W-90 GL-4 gear oil is recommended
    - Stop filling when oil reaches fill hole
    - Replace FILL plug, including new crush washer (P/N 90430-18008, ~$1.50/ea)
    6Thick, Geneyota, chrslefty and 2 others like this.
  4. Jan 5, 2016 at 8:29 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    a slight mod to Norton's instructions that I did. I only loosened the fill plug, i didn't remove it. that way when I removed the drain plug, the oil drain would be slow and it wouldn't all come out as fast as it could as though the fill plug was removed. it's honestly, along with the rear diff and the x-fer case if you have one, the easiest maintenance you can do right next to either topping off your coolant, or changing your headlights. just make sure you have the replacement gaskets on hand before you start.
    Norton and WPNZ like this.
  5. Jan 5, 2016 at 9:51 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    I can't just reuse the washers/gaskets?
    TacRo517 likes this.
  6. Jan 5, 2016 at 9:54 PM
    Caligula
    Los Angeles, CA
    Youre going to go through all this to skimp on a $0.10 gasket? :facepalm::facepalm::facepalm:
  7. Jan 5, 2016 at 9:55 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    :rofl:It's not a big deal. It was just a question.
  8. Jan 5, 2016 at 11:08 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Ive never used new washers on any drive train component or the the oil pan, never had an issue myself...
  9. Jan 6, 2016 at 12:05 AM
    Caligula
    Los Angeles, CA
    Well I bet I wouldn't have an issue wearing the same underwear for three days in a row either, but Ill still change them out each morning.
    BuelltonTacoma and ToyoTaco25 like this.
  10. Jan 6, 2016 at 12:20 AM
    Norton
    +1 to ALL of this. Good suggestion and thanks for finding the graphic I couldn't locate.
  11. Jan 6, 2016 at 9:45 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    I think the price quoted was $1.50 and not 10 cents, but WTF do I know...
  12. Jan 6, 2016 at 2:57 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    :rofl:
    #sleepsindirtyunderwear
    anafusion, Mojo Jojo, Greg617 and 2 others like this.
  13. Jan 6, 2016 at 3:05 PM
    Cohutta
    Cohutta Well-Known Member
    Georgia
    2011 4x4 AC 2.7
    Dog hair
    I've reused washers for transfer case / transmission / differential fluid swap jobs multiple times. I just don't have any dealers very close to me and always forgot to order em. Never had an issue over a decade and 3 different Tacomas.
    Not saying it's recommended or couldn't cause problems but it's no biggie in a pinch.
  14. Jan 6, 2016 at 3:14 PM
    Caligula
    Los Angeles, CA
    Im starting a charitable fund on Tacomaworld for people that cant, or wont, afford to replace gasket rings. Call it Gask-Aid.
  15. Jan 6, 2016 at 3:19 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    "For just 20¢ a day, you can help these poor people afford the gift of a lifetime. Gaskets. Donate now, and we will give you a picture of the person your helping with a free complementary spark plug."
  16. Jan 6, 2016 at 3:29 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Yep, Amsoil Severe Gear or Redline MT-90 are the best gear oils imo, both make the tranny shift like butter.
  17. Jan 6, 2016 at 3:29 PM
    Cohutta
    Georgia
    2011 4x4 AC 2.7
    Dog hair
    I just need one catastrophic leak seizing my transmission because I reused a crush washer and I'm sure I'd be changing them every time... Until that day happens I refuse to change
    vern650 likes this.
  18. Jan 6, 2016 at 3:30 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I've never used new gaskets for the diffs or tranny/tcase either... no issues ... :notsure:
  19. Jan 6, 2016 at 3:33 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Random question though, I had my clutch/flywheel replaced at the dealer and ever since my shifter stick spins around pretty easily. Before it wouldn't do that at all. Makes it especially annoying now when I'm trying to remove the shift knob... what gives?
  20. Jan 6, 2016 at 3:36 PM
    Caligula
    Los Angeles, CA
    I'll tell you if you promise to use new gaskets from now on...
    Mojo Jojo likes this.
