Manual transmission fluid low/wet foam
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MATacoma226, Jan 6, 2014.
  1. Jan 6, 2014 at 4:14 AM
    MATacoma226
    MATacoma226 [OP] New Member
    Hello all,
    I have a 2011 Tacoma 6cyl/6 speed manual TRD offroad with 43,000 on it. I used the dealer for all the free maintenace included with the truck. The free services ran out and did a couple oil/filter changes myself but did not do the full reccomended 30,000 mile service until recently.
    The transmission had an unusual whine before the service (which is what spurred on the service). While draining the transmission it seemed like 2 quarts did not come out. What really concerned me was how soaked the foam insulation was that is above the transmission. I definitley feel it was some sort of fluid/oil.
    Is there some sort of breather or other reason why it would be soaked? Is this where the fluid from the transmission could have gone? Any thoughts or ideas? I did a search of the forum here and couldn't come up with much.
    Thanks,
    MATacoma226
  2. Jan 6, 2014 at 9:31 AM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    So you got a transmission fluid change done at the dealer? How do you know 2qts did not come out? Did you measure it?
  3. Jan 6, 2014 at 11:49 AM
    MATacoma226
    Sorry for the lack of clarity... I did the 30,000 mile service myself. When I opened up the drain plug (warm fluid) my estimate was that 2qts. Did not come out
  4. Jan 6, 2014 at 12:55 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    The 6spd doesn't hold much transmission oil, I would hope you DIDNT have much more than 2 qts come out b/c it doesnt hold much more than that when you drain/refill IIRC. I run redline mt-90 in mine. its great stuff.
  5. Jan 6, 2014 at 2:35 PM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
    When you're sliding into home, and you feel some greasy foam...diarrhea
  6. Jan 7, 2014 at 4:57 AM
    Chris24
    Greensboro, NC
    If you don't see any leaks around the trans drain/fill plug, i wouldn't worry about anything. Refill trans with 2 qts and check it in a few days for leaks or new oil spots. I have no clue what the stains could be from though...I could be wrong, but i don't think there is a breather for the trans on the 6sp...i've never seen any fluid/oil around mine
