Manual Transmission Getting Stuck in Gear
Discussion in '3rd Gen. Tacomas (2016-2023)' started by motomaster132003, Feb 9, 2016.
Does your 2016 Toyota Tacoma 3.5L 6sp Manual become difficult to shift out of gear on longer drives?
  1. Yes
    30.0%
  2. No
    70.0%
  1. Feb 9, 2016 at 9:56 AM
    motomaster132003
    motomaster132003 [OP] Well-Known Member
    2016 Tacoma TRD OR DCSB
    Update:
    Here is a video of the truck shifting:
    https://www.youtube.com/watch?v=8IWh0MzmXO0
    My 2016 TRD OR DCSB V6 Manual now has over 2000 miles on it. When cruising down the interstate at 75 mph for an extended period of time, it will get stuck in gear, and it becomes extremely difficult to shift. This usually occurs when shifting back and forth between 5th and 6th, but it has been stuck in 3rd, 4th, 5th, and 6th gear both up shifting and down shifting. I have to literally force it out of gear when it gets stuck.
    I took it into the dealer at 1800 miles and they said they weren't able to replicate it because during their test drive it was only driven in the city and short spirts of freeway at 65mph, so it never stuck for them. Since it never stuck, they said that their isn't a problem to diagnose. I showed them a video clip, but they said it has to happen while they are driving.
    I need to get this problem fixed because it becomes a safety issue on the I-17. When downshifting on uphills, I lose over 10 mph when trying to get it to shift from 6th to 5th. Feel free to comment on the video if you would like.
    Thanks
    Dannyblues likes this.
  2. Feb 9, 2016 at 9:59 AM
    mferguson
    mferguson Well-Known Member
    Marc
    2011 Tacoma TRD Sport
    don't know much about the '16 manual trans, maybe see if there is a slave cylinder and check if its leaking. if its a hydraulic clutch it probably has one, don't really know.
  3. Feb 9, 2016 at 10:28 AM
    usadaytrader
    usadaytrader Well-Known Member
    Manuals are supposed to be king tho. Seriously. Take it back to the dealer
  4. Feb 9, 2016 at 11:40 AM
    sdguyman
    sdguyman Member
    I have the TRD Sport DCSB V6 Manual with about 1400 miles, I have not had any issues with it getting stuck in any gear. One time I couldnt get it into first but I think it was more of an issue of being rushed to get it into gear and I dont think I caught the right spot. I just pulled it into second, then pushed it up into first.
  5. Feb 9, 2016 at 12:49 PM
    MicComa
    MicComa Well-Known Member
    ADK MTNS, NY
    Take it back to the dealer before you change anything !! It's new so you shouldn't have to do a thing. They may try to void your warrenty if you do. Not sure but if slave cyl was leaking I would think you clutch pedal would be getting spongey. Hope you get it straightened around or start lemon law process.
  6. Feb 9, 2016 at 1:03 PM
    BeaverNation
    BeaverNation Well-Known Member
    Mines been good, reverse is the only notchy throw but it's gotten better. 200 miles on it
    jviffer and NickleCityTaco like this.
  7. Feb 9, 2016 at 1:14 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    problem is "occasionally" gets stuck in 3rd, 4th, 5th, or 6th gear when slowing down. it needs to do it at the dealer if it does not act up when they test drive it they will send you home.......
  8. Feb 10, 2016 at 6:16 AM
    motomaster132003
    Exactly, that's why I am trying to hold off on taking it in. I drove it 40 miles yesterday, and it only happened once. There is also a possibility that if they up shift and down shift at different RPM's then I do, it might not even get stuck in gear.
  9. Feb 10, 2016 at 6:19 AM
    NeedmoreTaco
    NeedmoreTaco Garage full of white Toys...
    Eric
    Travelers Rest, SC
    2012 Super White DCSB Prerunner
    LEDs and stuff
    What RPMs are you shifting at?
  10. Feb 10, 2016 at 11:34 AM
    motomaster132003
    So far it has only happened down shifting, but I usually up shift around 3 to 3.5k in the city and I have been getting 19 to 20 mpg with ko2s. Usually when the shifter gets stuck is when I have been in 5th for the last few miles cruising around 45 to 50 and then I hit a red light. I go to down shift to 4th and I have to pull hard to get it out of 5th. It's not consistent though.
    pcledrew likes this.
  11. Feb 11, 2016 at 8:00 AM
    Halena Molokai
    Halena Molokai Well-Known Member
    Black 2016 TRD DCSB OR 4x4 MT6
    BFG KO2 265/70/17 Moto Metal 17x 9 -12mm ToyTec Boss 2.0 lift Kit Wet Okole, Ceramic tint 35% Bakflip F1 Flowmaster Exhaust Single in /Dual out with 3"stainless tips DashMat Covercraft Custom windshield shade Tilt Alarm Weatherbeater Mats Diode Dynamic LED upgrade to interior OEM Bed Mat OEM 5" Chrome Side Steps
    6 speed manual trans only come in the 4X4 version correct?
  12. Feb 12, 2016 at 7:33 PM
    motomaster132003
    No, you can get it in 2wd as well.
    tacoguy88 likes this.
  13. Feb 12, 2016 at 8:44 PM
    AFMurse2014
    AFMurse2014 Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    Mine does this after cruising on the interstate for a bit. Usually in 6th
  14. Feb 12, 2016 at 9:19 PM
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    Isn't this a similar transmish? Just " updated "
  15. Feb 12, 2016 at 9:22 PM
    stealthmode
    Alberta
    Yeah been looking for the part codes between gen 2 and 3. To read up on it but haven't found much
  16. Feb 12, 2016 at 9:28 PM
    motomaster132003
    Interesting, how many miles do you have on yours?
  17. Feb 12, 2016 at 9:45 PM
    forty2
    forty2 Well-Known Member
    Cascadia
    2016 DCSB OR 6MT
    There are no trims currently offered in 2wd with a manual trans. It's SR 4x4 I-4 access cab, Sport 4x4 access cab, and Sport & Off Road 4x4 double cab. Canada gets an Off Road 4x4 access cab.
  18. Feb 13, 2016 at 6:32 AM
    motomaster132003
    Fair enough, I was going by what the sales man told me, but I should know better then to trust a sales guy! When I was looking for a truck, he asked me if I wanted to test drive a 2wd Manual sport lol
    Taco Fan and db2 like this.
  19. Feb 13, 2016 at 10:07 AM
    AFMurse2014
    Devin
    San Antonio
    26xx
    It did it again just last night after being in cruise control in 6th gear for a bit at 80mph
  20. Feb 13, 2016 at 10:09 AM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    TAKE IT BACK!
