Manual Transmission Grind
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Btorquer, Jul 17, 2016.
  1. Jul 17, 2016 at 8:50 AM
    Btorquer
    Btorquer [OP] Member
    Paul
    2013 4WD Manual Transmission
    Hello All,
    Bought my 13 Tacoma 6 spd manual 4x4 about a month ago. It, like my previous Toyotas, is a great truck. There is one thing that I'm wondering about. The transmission is a little reluctant to go into 3rd without a little bit of grind. The higher the rpm and slower the shift, the more likely it is to be normal.
    The truck has 33k on it and was certified by the dealer, so it has a good powertrain warranty. I was wondering if a different tranny fluid might smooth things out a little. I've heard that Ford Synthetic Trans fluid is really good for issues like this. Does anyone have experience with this, or a different recommendation?
    It isn't a big issue, but seems like it should shift a little smoother.
    Thanks,
    Paul
  2. Jul 17, 2016 at 10:17 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    I had a Nissan 5 speed that would grind a bit when shifting to low from a stop. I changed to Redline MT-90 and the problem went away. Might help yours. One of these days I am going to change my Tacoma, tho it seems to work well now.
    Shark18 likes this.
  3. Jul 17, 2016 at 11:11 AM
    ausfahrt
    ausfahrt Well-Known Member
    FL & VT
    2015 SR5 MT 4X4 V6
    It only does it when you shift from second to third? With only 33k miles that doesn't sound right and I don't think that any magic in a bottle will fix this.
    I think it's time to make Mr. certified dealer step up to the plate and make it right.
    BassAckwards likes this.
  4. Jul 17, 2016 at 12:51 PM
    Pigpen
    Dan
    Northwest Montana
    Ausfahrt is right. These trucks might shift a little differently than others, but there should be zero grinding. Either the fluid is low or the PO screwed it up. Make sure the truck shifts properly while you have the warranty. Be prepared for the dealer to tell you it's normal. That's bullshit.
  5. Jul 17, 2016 at 1:13 PM
    Btorquer
    Paul
    Maybe "shift a little differently" might be what it is. On another forum, Miata owners call this kind of shifting "notchy" and recommend the Ford Trans lube. It's not really a "grind" but it's not dead smooth. Down shifting from 5th to 3rd or 4th to 3rd is smooth.
    58 Siesta, could you tell me what you mean by "shift a little differently"?
    Paul
  6. Jul 17, 2016 at 2:43 PM
    Pigpen
    Dan
    Northwest Montana
    Notchy is a good descriptor. There's a distinct rev hang in the engine and the transmission feels really tight - it doesn't just fall int gear. No oil will cure that. I run Redline MT 90 and my trams still shifts notchy. It's just a characteristic of these trucks.
    A grind would be a noise. It's when the synchro gears don't mesh properly and physically grind against each other.
  7. Jul 17, 2016 at 4:04 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    My '13 would grind when going into 3 from day one when I bought it new. Redline MT-90 helped quite a bit but it's still a bit tough at times going in. I've read the Ford lube is even better but it has to be the right type. There's a thread on hear that gives the part number but I wouldn't know here to start to find it. You can't force it into gear, just let it engage and it should go into gear.
  8. Jul 18, 2016 at 3:58 AM
    Btorquer
    Paul
    Thanks VSSMAN, you confirmed what I thought. It's a truck, no need to speed shift. I'm going to track down the Ford lube and try it out. I'll post up the results.
    Paul
    Pigpen likes this.
  9. Jul 18, 2016 at 4:19 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Pigpen likes this.
  10. Jul 18, 2016 at 5:52 AM
    Btorquer
    Paul
  11. Jul 18, 2016 at 6:17 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Oil will not "fix" a problem I can tell you, you need to mat the clutch like all the way to the floor. Toyota addressed the "notchy" shift in 16 it's not a new transmission is is a improved one that addressed the issue. It takes a bit to get used to the 6 speed but once you get past that they work fine.
  12. Jul 18, 2016 at 6:46 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Let me know how it works for you. FWIW, lube type can have a big influence on how the syncro's operate.
  13. Jul 18, 2016 at 7:26 AM
    Btorquer
    Paul
    I drive a turbocharged Miata ( I know, way different than my Taco ) and follow a Miata forum. Members there have had a LOT of success with the Ford lube in Miatas. In that case it's the 2nd gear shift that is a little balky.
    While it may not be a total "fix" an improvement is always welcome. Thanks for the tip in putting the clutch in all the way. That and shifting into 3rd s l o o o w l y, seem to make it un-noticeable.
    Paul
  14. Jul 18, 2016 at 7:57 AM
    nh_yota
    nh_yota Well-Known Member
    Jeff
    Portsmouth, NH
    2010 DC V6 TRD-OR 6-SPD
    2" Lift with HS coils/AAL and 5100s, TRD Exhaust, TRD Skid Plate, URD Short Shift, AT3s
    My 2010 has done the same thing since day one. You learn to live with it after a while, and switching to Redline MT-90 helps a little bit. I think the 6-speed in my Tacoma is the clunkiest modern manual transmission that I've ever driven, but it is what it is.
  15. Jul 18, 2016 at 10:15 AM
    tgear.shead
    tgear.shead Well-Known Member
    THAT ^^^
    Ok, for my experience...........
    4-cyl with R155F. I did my first gear oil change (both diffs, transmission, transfer case) and made the mistake of trying out mobil1 gear oil -- which even said that its for MT. Could NOT shift into 2nd without grinding.
    Dumped that crap out of the transmission and transfer case (left it in the diffs, since they're just gears -- no synchros to worry about), and replaced it with amsoil MT. Back to buttery smooth.
  16. Jul 18, 2016 at 10:25 AM
    Pigpen
    Dan
    Northwest Montana
    I used to drive a Freightliner... Talk about a notchy shifting SOB!
  17. Jul 18, 2016 at 10:25 AM
    tgear.shead
    That even synchronized?
  18. Jul 18, 2016 at 10:27 AM
    Pigpen
    Dan
    Northwest Montana
    I don't know.
    I quickly learned to shift without the clutch though. Both up and down.
  19. Jul 18, 2016 at 4:36 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Mack Triplex. Try that one on for size.
    Same 6 speed as in a Caddy SST. and some other GM stuff.
    Can you explain how a syncro operates?
  20. Jul 18, 2016 at 4:37 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Can you?
