Manual transmission grinding
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jrazzle, Jun 19, 2018.
  1. Jun 19, 2018 at 10:41 PM
    Jrazzle
    Jrazzle [OP] Well-Known Member
    Denver, CO
    ‘18, 2000 miles and I have an issue with the trans grinding when shifting from second to third while in 4lo. Anyone else have this issue?
    Also noticed the clutch engagement isn’t smooth when shifting into 5th and 6th around 2-4K rpm. Kinda feels like the clutch is being dumped when I’m engaging it slowly while shifting into those gears.
    It’s been to the dealer and apparently “it’s mechanically fine” and yes, I know how to drive a manual.
  2. Jun 19, 2018 at 10:43 PM
    tcjacado
    tcjacado Well-Known Member
    4lo is meant for no more the 5mph. Use 4hi to go faster.
    BSFord and peavey02 like this.
  3. Jun 19, 2018 at 10:53 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    :facepalm:
    BSFord likes this.
  4. Jun 19, 2018 at 11:14 PM
    BeaverNation
    BeaverNation Well-Known Member
    Maybe you mean the diff lock? I run 4 lo in 5th and 6th gear pretty often on trails
    AFMurse2014 and tcjacado[QUOTED] like this.
  5. Jun 20, 2018 at 3:32 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Mine will grind if I'm not careful with the footwork when upshifting in low range. IIRC, you gotta pay more attention to your revs and let them fall between gears. I also let the synchros do the work and not force the shifter.
    In other words, I don't believe you have an issue.
    hiPSI likes this.
  6. Jun 20, 2018 at 5:41 AM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    Are you referring to the "thump" that you feel in those two gears? I have it, and I guess it's normal for this truck. I've never felt it in any of my other 12+ manually transmission vehicles I've owned, but there's no noise associated with it, so I'm not concerned.
    MOC221_ likes this.
  7. Jun 20, 2018 at 6:04 AM
    eon_blue
    Azusa, CA
    You can use 4lo to go faster than that, I run 4lo up to 4th gear at ~20 mph regularly on trails. RPMs never exceed 2.5-3k or else it's time for 4hi. Also depends on terrain.
    tcjacado[QUOTED] likes this.
  8. Jun 20, 2018 at 6:50 AM
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    2017 TRD Sport AC MT
    5th to 6th is a tricky change in this truck, mostly because the gap between the two isn't as big as the other gears. Most guys here skip 5th completely.
    I've driven manual transmissions nearly all my adult life, and this manual really took some getting used to. You've only got 2K on yours... you need to drive it more to figure it out.
    I never use 4LO in anything other than 1st, so I can't help you there.
    MOC221_ likes this.
  9. Jun 20, 2018 at 7:00 AM
    Jrazzle
    Denver, CO
    Yeah I don’t have a Probelm with the footwork....even coasting, no throttle, clutch in, no rpms, it grinds from 2-3 and 3-2. I’ll update with the dealer response next week.
    MOC221_[QUOTED] likes this.
  10. Jun 20, 2018 at 7:08 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Change the trans fluid to Redline MT90
    05Taco4x4 likes this.
  11. Jun 20, 2018 at 7:38 AM
    Jrazzle
    Denver, CO
    if by thump you mean that it feels like the clutch is being poped and occurs around 2-4k rpm, yes. i've read some other threads on the 1-2 thuds and haven't experienced anything there, just 4-5 and 5-6.
  12. Jun 20, 2018 at 7:50 AM
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    I'd say NOT normal. This truck's MT is a very smooth and very easy to use. Maybe need an adjustment :confused:
    shakerhood likes this.
  13. Jun 21, 2018 at 6:07 PM
    05Taco4x4
    2TR-FE Enthusiast
    Made a very noticeable difference in mine
  14. Jun 22, 2018 at 3:15 AM
    MOC221_
    Frank
    Same, if I don't get it just right on those upshifts I'll get the clunk/thump. IMO it's in the driveline somewhere aft of the tranny, as it goes into gear fine and clunks on clutch release.
