Manual Transmission-HELP
Discussion in '3rd Gen. Tacomas (2016-2023)' started by YotaLife406, Feb 21, 2016.
  1. Feb 21, 2016 at 9:58 PM
    YotaLife406
    YotaLife406 [OP] Well-Known Member
    16 DCSB OR M/T
    Need the help of other people that own the manual transmission!
    I've got about 2700 miles on my truck and have noticed it since the day I picked it up ( figured it was normal but just want to ask).
    While driving if I shift into neutral and drive over a big bump like a speed bump or washboard dirt road I hear something under the truck kinda rattle. Doesn't seem to do it while in gear. Anyone else experience this or should I be worried? Thanks!
  2. Feb 21, 2016 at 10:02 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Can you elaborate on the rattle? I'm pulling from memory here but I seem to recall a slight rattle from some of my previous manual Tacomas that there was a slight rattle while in neutral while going over bumps or pot holes but this was at a low speed. I can't recall the last time I rolled over a speed bump in neutral, usually I'm in gear when doing so.
  3. Feb 21, 2016 at 10:11 PM
    YotaLife406
    16 DCSB OR M/T
    Sounds like some part of the drivetrain or transmission rattling or shaking while I go over the bumps. When the road smooths out it stops or if I'm in gear I don't seem to hear it. It's my first manual truck and I didn't notice this with my manual 07 FJC so just looking for some reassurance that it's normal or thinking about taking to to the dealer (but I'd rather not).
  4. Feb 21, 2016 at 11:08 PM
    98tacoma808
    98tacoma808 808
    Dustin
    Big Island, HI
    2001 dblcb
    I Got a OR DBLCB MT and i hear the same noise your talking about. WAs wondering bout that tooo!!
  5. Feb 21, 2016 at 11:10 PM
    YotaLife406
    16 DCSB OR M/T
    Thanks for the feedback! At least I'm not alone :) hopefully will get more input and find out its normal
  6. Feb 21, 2016 at 11:15 PM
    StOrMyThEtAcO
    StOrMyThEtAcO @stormythetaco
    Cody
    CO
    18 TRD Sport mom bus
    All of them
    I'm pretty sure it's "normal"
    My 13 if in neutral an I go over bumps rattles as well.
    Try this, when the truck is off slap the stick back an forth an listen to the sound. It's probably going to be the same sound you hear while driving.
    YotaLife406[OP] likes this.
  7. Feb 21, 2016 at 11:20 PM
    StreetTiresJay
    StreetTiresJay Well-Known Member
    Jay
    British Columbia Canada
    '16 Taco TRD Sport DBLcab Alpine White 6M
    Wife in passenger seat, not driver seat :)
    I'll look into this tomorrow and check back. I don't recall hearing this but I could be wrong. I'm a big fan of neutral whenever possible so I'll keep an ear out for this
  8. Feb 22, 2016 at 4:58 AM
    pocketsmcaaron
    pocketsmcaaron Well-Known Member
    Oregon
    '16 OR MT DCSB WHT Prior:'15 MT ,'94 MT
    Snugtop Rebel,TRD Pro Bilsteins,2" Block rear,SR Grill,TRD Beadlocks,Toyo AT 2s,Focal Experts,Kicker AmP & 10" Sub
    Have you tested if it's coming from the steering column?
  9. Feb 22, 2016 at 9:25 AM
    YotaLife406
    16 DCSB OR M/T
    I'll try that
    No how would I test that?
  10. Feb 22, 2016 at 9:27 AM
    YotaLife406
    16 DCSB OR M/T
    @pocketsmcaaron have you heard what I'm describing on your truck? Notice you have the manual tranny
  11. Feb 22, 2016 at 9:30 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Maybe lube the driveshaft u-joints and check the cat heat shield mounted to the cab floor is secure.
  12. Feb 22, 2016 at 9:45 AM
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    I have a manual and have two rattles. One sounds like a heat shield and occurs during low rpms such as when launching in 1st or 2nd, the other sounds like what you describe, a deeper rattle from the transmission when shifting gears and in neutral.
    I've had the second one on other manual cars and just figured it's normal.
  13. Feb 22, 2016 at 9:52 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    I have the same sound - running over bumps in the road with clutch depressed in or out of gear. Sounds like its the drive train to me and it feels like it too. Just got my 5000 mile oil change from the dealer with lube so I'll check mine again. Sounds more mechanical to me, like maybe the rear end un-loaded and rear suspension rattle from un-loaded drive train.
  14. Feb 22, 2016 at 9:55 AM
    StreetTiresJay
    Jay
    Just a bit of background on how the 1st gen pickups from the 80's are built, the transmission and T-case sit on a cross member with a heavy rubber bushing. I haven't crawled under my 3rd gen yet but I'll venture a guess this is nearly the exact same setup on our trucks. The transmission itself is probably shaking on this mount because I recall this happening while off-road last week. I have a tendency to throw it in neutral when coasting through flat terrain (not sure why just a bad habit)
    I don't recall a noise so much as feeling the shifter shake in my hand however a slight rattling noise WAS present.
    As I said before I will look more into this today when I leave the mountain and report back. From what I recall. I honestly think this is normal and not s design flaw. The components and drive train on these trucks need to be able to flex and move in at least 4 axis' to some extent. Also, try contacting Toyota about it, their service department will probably confirm this and pinpoint the rattle you're hearing.
  15. Feb 22, 2016 at 11:08 AM
    pocketsmcaaron
    Oregon
    When you are off-road or rough surface and hear the noise, do you feel any clunkiness on the steering wheel?
  16. Feb 22, 2016 at 11:14 AM
    pocketsmcaaron
    Oregon
    I haven't heard anything. But mostly been listening to the radio while driving. I'll turn it off next time OR and keep your thread posted.
  17. Feb 22, 2016 at 12:11 PM
    Doug007
    Doug007 Well-Known Member
    Doug
    Houston, TX
    '16 TRD Off-Road M/T
    I'll have to check this out over the next couple of days. I haven't noticed anything yet but also haven't done much coasting in neutral and only have about 250 miles on mine.
  18. Feb 22, 2016 at 1:26 PM
    MitchK
    MitchK Well-Known Member
    16 TRD OR
    Mine does the same thing. 3000 miles and it's done it from the beginning. It hasn't gotten any better or any worse with mileage/time. It seems to be common, if not normal.
  19. Feb 22, 2016 at 3:56 PM
    YotaLife406
    16 DCSB OR M/T
    I don't feel any "clunkiness" in the steering wheel or shifter. Just hear a clunky rattle.
  20. Feb 22, 2016 at 4:02 PM
    pocketsmcaaron
    Oregon
    Went out during lunch on a washboard dirt road, let it ride in neutral going about 25mph, it was all quiet. Will try a rougher road another day.
