Manual transmission impressions at 220 miles
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2023tacomer, Jul 24, 2023.
  1. Jul 24, 2023 at 7:24 PM
    2023tacomer
    2023tacomer [OP] Well-Known Member
    I'm still not used to this transmission, almost like I feel I only get "perfect" shifts half of the time. The others being acceptable, but not seamless if that makes sense. First to second if not taking 1st gear gear up in rpms, it seems clunky going into second. Normal?
    Also, it may be because I'm a hesitant right now, being a new truck and haven't driving manual in 20+ years, but it doesn't seem to like 2nd gear at slow speeds. Like say if I roll a stop sign at 5mph, it's like it was a mistake to stay in 2nd gear but shifting from 2nd to 1st rolling has always been a no for me. I don't remember my 91 22re 5spd like this, but again it may be because I'm somewhat babying this truck. Opinions?
  2. Jul 24, 2023 at 7:28 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    You have driven it a half tank of fuel. Come back in a year or two and let me know your impressions.
    RIX TUX, Phlogiston, Chew and 13 others like this.
  3. Jul 24, 2023 at 7:28 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Part of the second gear at 5 mph is that this engine has the off idle torque of a riding lawnmower. ;)
    The transmission does seem to take a long time to break in, that said this is the most difficult vehicle I have ever had to be smooth with 100% of the time.
  4. Jul 24, 2023 at 7:29 PM
    Just_A_Guy
    Just_A_Guy Rain is a good thing
    On the hunt
    A truck
    Sounds like every manual I have ever driven.
    There’s a reason I don’t like the manual in these 3rd gens. Many do, but I find it clunky.
    Ole No. 1 and 22Coma6MT like this.
  5. Jul 24, 2023 at 7:30 PM
    Just_A_Guy
    On the hunt
    A truck
    Stop insulting my lawnmower. Geez
  6. Jul 24, 2023 at 7:33 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    :fistbump:
    At least I didn't say moped... :rolleyes:
    Delta09 and Just_A_Guy[QUOTED] like this.
  7. Jul 24, 2023 at 7:36 PM
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    I think my 2nd gen was worse. I actually like the 3rd gen manual.
  8. Jul 24, 2023 at 8:03 PM
    Llgreen
    Llgreen Member
    Leon
    2017 Tacoma SR 4x4
    I don’t know if you have the v6 and 6 speed or the 4 and 5 speed, I have the latter, but I get what you are saying. I drove an 88 22r 4 speed mt almost 500k and I did some unreasonable towing and bogging(I was 16 at the time) with it and the clutch and transmission were solid for what it was. I bought my 2017 mt 2.7 2 years ago, like you after 20 years of not having one, and it was an adjustment. At first I thought it was me being rusty, I even stalled at a couple red lights, but a lot had changed in 20 years. They do things now for newbies like make the clutch soft and forgiving and it’s not the same. I know even then it was a hydraulic clutch but you still had more “feel” of where it was. I have put almost a 100k on it now and what I have learned is to drive it like you stole it. I also added a pedal monster to help reduce the factory mpg delay on throttle, apparently a cable worked too well so they made it by wire, and that helped as well. If you have the 4, it’s stronger than the 22r but they also made the Tacoma heavier than what my 88 was. Over time, I have found the sweet spots to shift and do so almost not thinking now whether accelerating or decelerating. Whether you have the 4 or the 6, I think you may just need time to get acquainted.
    shakerhood likes this.
  9. Jul 24, 2023 at 8:16 PM
    lavrishevo
    lavrishevo Well-Known Member
    2023 Trail Edition
    Ceedub53, Speedbird and andagi808 like this.
  10. Jul 24, 2023 at 8:17 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    He has to have the V6 6 Speed, 2017 was the last year for the 4 banger MT.
    doublethebass and RustyGreen like this.
  11. Jul 24, 2023 at 8:18 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    As long as we are praising products, here is my endorsement:
    Motorcraft XT-M5-QS, it meets the Toyota specifications and has a reputation as a "problem fixer" fluid for balky manual transmissions.
    I changed to the Motorcraft at 30K. On the first trip around the block I was stunned at the improvement in smoothness, the transmission felt instantly "slicker".
    I had experienced occasional first gear blocking and also the "crunchy" second gear shift, I don't shift (or drive) very fast. :turtleride:
    Previously I was frequently conscious of the syncromesh working when shifting, I could feel it in the stick, it wouldn't grind but you knew it was there, after the fluid change the sensation was gone.
    Motorcraft data sheet:
    https://www.motorcraft.com/us/en_us...ull-synthetic-manual-transmission-fluids.html
    Rock Auto had the best price.
    https://www.rockauto.com/en/parts/motorcraft,XTM5QS,transmission+fluid,13630
    GBR, Tacobot14, andagi808 and 2 others like this.
  12. Jul 24, 2023 at 8:23 PM
    2020SilverSky
    2020SilverSky Well-Known Member
    Seattle. WA
    2020 TRD Off Road 4WD 6MT
    In my experience, as long as it has the accumulator you'll rarely get a smooth shift out of it. A tune and accumulator delete does wonders.
  13. Jul 24, 2023 at 9:13 PM
    NorrinRadd
    NorrinRadd Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    I found that I need to wind it up a bit more than you'd think to get a smooth shift.
    bls82261 and doublethebass like this.
  14. Jul 24, 2023 at 9:56 PM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    Did you just cut and paste?!
  15. Jul 24, 2023 at 10:15 PM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Kolohe07, BillW, jlemmond and 5 others like this.
  16. Jul 25, 2023 at 12:34 AM
    Irons
    Irons Outlaw Prospector
    NW Michigan USA
    '22 TRD Sport AC MT Army Green
    TRD lift, Exhaust & CAI
    Been driving manuals my whole life and this one is a strange bitch. The first 1000 miles I thought there was something wrong with me.
    Now @ 5000 miles I roll through it naturally, but it took some getting used to.
    Northerntaco69, Delta09 and 22Coma6MT like this.
  17. Jul 25, 2023 at 1:42 AM
    TacoTuesday1
    SD CA
    probably has accumulator
    Panchovilla6192002 likes this.
  18. Jul 25, 2023 at 2:01 AM
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    My ‘20 is nearly out of warranty. The accumulator delete is high up on the list of mods to be performed.
  19. Jul 25, 2023 at 2:48 AM
    Relyt4
    Relyt4 Well-Known Member
    Pennsylvania
    '20 TRD Off Road
    wrightme43 likes this.
  20. Jul 25, 2023 at 3:38 AM
    wrightme43
    wrightme43 Well-Known Member
    Scottsville Kentucky
    17 Double Cab M/T TRD Offroad Blazing Blue Pearl
    Redline custom leather shift and e-brake boot. VFTUNE Super Full Otto cycle, octane learning, premium fuel.
    I highly recommend the accumulator delete disk, motorcraft unicorn tears synth fluid, and vf tuner. I waited over 95,000 miles to do the accumulator delete. Don't do that. It really works nice after it is eliminated.
    Irons, Junkhead and doublethebass like this.
