Manual transmission issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dcmsideshow, Jul 8, 2025.
  1. Jul 8, 2025 at 11:17 AM
    dcmsideshow
    dcmsideshow [OP] Well-Known Member
    Dan
    Arvada, CO
    2019 Toyota Tacoma TRD Off-Road
    Eibach suspension; Deaver Springs; Black Rhino wheels; Toyo tires; RSI SmartCap
    I imagine this has been asked and answered before, but I'm having an issue with my 2019 Tacoma TRD Off-Road with manual transmission.
    Before I start with the issue, let me say I already did the accumulator delete mod, and the problem existed both before and after I did it.
    Okay, the problem:
    In first gear, on any steep incline on-road or off-road, when I'm trying to get started from a dead stop, I try to give it the right amount of gas to 'feather' the clutch and get going without burning out or whatever. But it feels like the truck is about to stall, no matter how much gas I give it. And often, in tricky situations off-road, it does just stall. It's like the more gas I give it, the less likely it is to move forward.
    I've played with all the buttons to see if it makes any difference (traction control, etc) but it doesn't seem to matter.
    Is the first gear just too high of a gear? Is my fuel filter clogged? It's super annoying because it makes it way harder to get out of tricky situations off-road, especially if the trail is steep.
    Anyone run into this problem? Anything to do besides re-gear the transmission?
    Willy Lump Lump likes this.
  2. Jul 8, 2025 at 11:40 AM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    When mine did that, my clutch was died shortly after.
    I've got the accum delete, Core shifter, a tune, re-geared, and I still run into that. The only fix I can mention is to give it more gas. I still stall mine out on occasion too though.
  3. Jul 9, 2025 at 4:07 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Part of the problem is that this engine has the off idle torque of a riding lawn mower. ;)
    In off road situations using low range is a great help when the going is slow & tough.
  4. Jul 9, 2025 at 4:29 AM
    Tacoma Mike
    Southern Maine
    Quote of the day. I gotta remember this one.
  5. Jul 9, 2025 at 7:49 AM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
    I can release my clutch going uphill in my gravel driveway, no throttle and it crawls up a couple car lengths with minimal effort.
    I still want to re gear and get a 4th gen trans in there for the lower lower (1-3) gears.
  6. Jul 9, 2025 at 9:21 AM
    TacoGranny
    TacoGranny Well-Known Member
    2020 TRDOR DCSB Cement 6MT
    33's, Sliders, Skid Plates, Softopper, ATH rear bumper
    I suggest working on your clutch foot. The trick to starting on hills is to release the clutch to the point just before it starts to engage before you even think about starting to move, and then release the clutch the rest of the way as you give it ample gas. Giving it gas before the clutch engages is useless, no matter the amount of feathering, you'll just wear out your clutch faster and likely roll backwards.
    I've driven offroad and climbed steep ledges on inclines and killed it a few times, the lack of torque can be hard to overcome, 4-low obviously helps a bunch. You can use the Clutch Start Cancel function in those situations (sounds awful but works as intended), and I found adding a front camera helped me a lot in those situations as far as timing when the gas pedal is required to climb a ledge.
    If you are having the same troubles on-road, then definitely work on your clutch foot, or use the hand brake method to get started. Figuring out where your clutch engages is as easy as parking in a flat parking lot, and slowly letting out the clutch without using the gas until you start to move, then it's just muscle memory.
    STEELeR43 and Willy Lump Lump like this.
  7. Jul 9, 2025 at 9:47 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    OP, you just need more practice. The more load on the engine, the more you need to slip the clutch. If the situation is so extreme that you cannot avoid killing the engine or burning the clutch, put it in 4lo.
    amyracecar likes this.
  8. Jul 9, 2025 at 9:51 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    According to your sig, you have aftermarket suspension and wheels. So I am going to assume you have larger and heavier tires. You might consider a gearing change. Especially if this started after these modifications.
    RustyGreen and doublethebass like this.
  9. Jul 9, 2025 at 9:52 AM
    Willy Lump Lump
    21’ dcsbmt
    This and that
    Thinking about teaching my daughter in 2lo so she gets some practice swings in. Then sending her into a manual VW tdi, with gobs of torque and much shorter throws.
  10. Jul 9, 2025 at 9:52 AM
    gudujarlson
    Minnesota
    I have 33” mud terrains and I have no issue taking off from a stop.
  11. Jul 9, 2025 at 9:53 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    I don't doubt it,, just saying heavier and/or taller tires will add to the issue.
    doublethebass likes this.
  12. Jul 9, 2025 at 9:54 AM
    Willy Lump Lump
    21’ dcsbmt
    This and that
    I had 75# at each corner with 265/75/16 bfg ko2 and the trd pro rim. Still the same.
  13. Jul 9, 2025 at 9:57 AM
    gudujarlson
    Minnesota
    I doubt anyone could detect a difference in a blind test.
  14. Jul 9, 2025 at 9:59 AM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Oh it’s pretty noticeable. Have had E load Coopers as my summer tires and SL Blizzaks as my winters the last couple years and when I swap them in the winter I suddenly feel like I’m in a race car.
  15. Jul 9, 2025 at 10:01 AM
    gudujarlson
    Minnesota
    I don’t disagree, but the subject at hand is starting out from a stop. The extra rolling resistance is not noticeable in that scenario in my experience. On the other hand, steep inclines are very noticeable. Either way, it is not an issue. The issue is that the driver needs more practice.
  16. Jul 9, 2025 at 10:02 AM
    Willy Lump Lump
    21’ dcsbmt
    This and that
    After I ended up with 275/70/17 and a modest weight reduction, at about 15 lbs, it made a difference. But then again I wasn’t blindfolded in this experience.
  17. Jul 9, 2025 at 10:02 AM
    Cetacean Sensation
    Cetacean Sensation Never lost in a parking lot
    PNW
    6MT ELM Taco (slow) // N54 BMW 135 (fast)
    Yeah you’re not wrong.
    It took me a week or so to get used to how much more I slip the clutch to get going on my 32s e loads vs the factory tires. I also stall it in reverse a bit more often now when I didn’t really before.
    Chew[QUOTED] likes this.
  18. Jul 9, 2025 at 10:04 AM
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    That’s what I’m saying - you can really notice 20 extra pounds per corner starting from a stop. All that extra weight takes a lot to get rotating
    Chew and MagicToolbox like this.
  19. Jul 9, 2025 at 10:04 AM
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    I would subscribe that it’s a little of both. Engine tuning and technique. I was teaching a young person manual transmission operation and one of the obstacles I gave them after basic shifting was starting on a steep hill. It was a short exercise (for fear of clutch damage) but they would stall it about 75% of the time. Me, same hill, never stalled it. Like mentioned in a previous post, the idea is to ‘catch’ the load prior to gassing the engine. If you’re really having trouble starting on a hill you can use the hand brake. BTW If you think the 3G Taco is a bitch, try a foot clutch H-D with a flathead engine. On an incline. With only one foot on the ground.
  20. Jul 9, 2025 at 10:05 AM
    gudujarlson
    Minnesota
    Ok, but are able to solve the “issue” with practice, yes?
