Manual transmission issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dcmsideshow, Jul 8, 2025.
  1. Jul 9, 2025 at 10:08 AM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Yeah probably. Or 4Lo / 2Lo
  2. Jul 9, 2025 at 10:15 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    So yes, it’s not so bad that you are worried about burning the clutch or killing engine except in extreme situations, eg pulling a boat up a steep launch ramp.
    doublethebass[QUOTED] likes this.
  3. Jul 9, 2025 at 10:22 AM
    Longbow25
    Longbow25 Active Member
    Colin
    2021 Black TRD Pro
    Are you sure you aren't starting in 3rd gear? I say that kinda tongue in cheek, but that's literally what your symptoms sound like.
  4. Jul 9, 2025 at 12:27 PM
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    right, which is what the OP’s doing when the problem pops up.
  5. Jul 9, 2025 at 1:02 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I can agree with this. I wasn't suggesting gears/tires were the entire issue, just part of it (possibly, we have yet to hear what tires OP has).
    Without any of us witnessing this in person it's hard to say exactly what the problem is. I know the OP said he played with all the buttons, but I am wondering still if in certain shituations, the traction control is still activating, which we all know how our truck's behave,,, power is cut. I think the TC isn't totally disabled unless the button is held down for a few seconds?
  6. Jul 9, 2025 at 3:47 PM
    gudujarlson
    Minnesota
    Traction control does not do anything unless a wheel is spinning.
  7. Jul 9, 2025 at 3:49 PM
    gudujarlson
    Minnesota
    What I interpreted is that he is having problems taking off in normal daily driving situations.
  8. Jul 9, 2025 at 3:56 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    The 3rd gen Tacoma's need 4600 rpm to get max torque. That simply does not work with manual transmissions on hills or pulling loads. All trucks, by all manufacturers since the 1990's have had engines designed to work with automatic transmissions. Old school engines when manual transmissions were the norm got torque at 2000-2500 rpm. That's why so few manuals are made today. It's an afterthought by manufacturers.
  9. Jul 9, 2025 at 4:11 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    The problem with you repeatedly peddling this on every manual transmission thread is that you don’t need max torque to get rolling. Yes, max torque is 4600 rpm. No, you don’t need it to get moving. It really sounds like OP is learning to drive a stick and probably also doesn’t know when to use 4L. If max torque were at 2-3k, it would still need better clutch management.
    The industry pushes autos not because of how great they are at doing work, it is because they can control them and get better emissions out of them. You can build a manual to do anything an automatic can; they just won’t.
  10. Jul 9, 2025 at 4:12 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    Correct
    Again we’re not there, but if OP is revving up and releasing the clutch, there could be wheel spin.
  11. Jul 10, 2025 at 3:33 PM
    dcmsideshow
    dcmsideshow [OP] Well-Known Member
    Dan
    Arvada, CO
    2019 Toyota Tacoma TRD Off-Road
    Eibach suspension; Deaver Springs; Black Rhino wheels; Toyo tires; RSI SmartCap
    You don't think 27 years of driving manual is enough practice?
  12. Jul 10, 2025 at 3:35 PM
    dcmsideshow
    Dan
    Arvada, CO
    Hi. OP here. I've been driving stick for 27 years.
    I'm not gonna put it in 4L to get off the line at a stop sign.
    It's not my clutch work. It's a mechanical issue.
  13. Jul 10, 2025 at 3:37 PM
    dcmsideshow
    Dan
    Arvada, CO
    Y'all. I'm not new to driving stick. Been at it for 27 years. I've had a lot of trucks, some of 'em heavy and some of 'em not. Some of 'em modded and some of 'em not. I've owned four Tacomas.
    Not a single one has had this issue, except for this Gen 3.
    Please stop it with the "OP just needs to practice using the clutch."
  14. Jul 11, 2025 at 12:02 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    You're not alone, I too have had this happen while trying to start off uphill while pulling a heavy trailer (maybe 3500lbs). Only way forward is to smoke the clutch until you get enough speed for the engine to not die (or use low-range if not on a public road / don't need to go fast or far).
    If I was to guess, the others above were likely meaning you just needing to get used to driving your 3rd-gen (not your stick driving skills altogether). Indeed, none of my past vehicles have been as likely to unexpectedly stall out if the RPM dips below a certain amount under a high torque load either (35 years w/stick here).
    My assumption is this is something with the drive-by-wire throttle control (all my past vehicles had cable-actuated throttles). The ECM won't open it all the way (or will even shut it) while you're trying to command it to open further. This of course is completely counter to what you expect it to do, and so the stall happens.
    Maybe a tune can fix this?
    gudujarlson and doublethebass like this.
  15. Jul 11, 2025 at 12:28 PM
    #35
    dcmsideshow
    Dan
    Arvada, CO
    I appreciate the thoughtful response.
    FWIW, I've been driving this truck for three years now, so it's not really a matter of getting used to the truck either.
    A tune may b e in order.
  16. Jul 11, 2025 at 1:09 PM
    #36
    p_sando
    p_sando Well-Known Member
    utah
    2020 DCSB TRD OR 6MT
    I was driving on a somewhat steep dirt road recently at elevation and had to stop briefly.
    Thinner air = less power, 3.5L = needs lots of RPMs, accumulator = inconsistent clutch feel sometimes
    What helps me in these situations in 2WD is using the e-brake, really helps get the engine up to RPM without rollback meaning your momentum starts off forward instead of fighting gravity going backwards downhill a bit less. That and I need to do the ADM for a more responsive clutch.
  17. Jul 11, 2025 at 1:16 PM
    #37
    dcmsideshow
    Dan
    Arvada, CO
    I did the ADM and honestly, the clutch still feels pretty vague. I don't notice a ton of difference.
    I do often drive at high elevation, so maybe that's a factor here...
  18. Jul 11, 2025 at 2:32 PM
    #38
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    From lots of time spent in Tahoe, I know Elevation does have an impact on the performance. Especially where it is weakest. (low revs).
    On the highlighted text above, you have to get revs well above stall. Once on the edge, the motor will be hard pressed to get itself to higher revs since it will only be producing a tiny amount of HP/Torque. A stall is very likely at that point.
    One approach I use is to get the clutch fully engaged and the wheels turning as early as possible. (the rev point will be load-dependent). Then lean on the gas to get more power and speed avoiding excessive clutch slip this way. Again, the point and revs needed to pull away as needed will depend on load. (Weight, grade, etc.)
    Easy with an unloaded truck on the street, you can be fully engaged at just above idle, then power-up (gently) from there. More difficult with added load of course; as on steep grades / sandy soils / heavily loaded truck, etc.) .
    Clutch slip is needed in some instances... you simply have to get to a point where you can access the horsies required to do the job...
  19. Jul 11, 2025 at 2:58 PM
    #39
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
  20. Jul 11, 2025 at 3:19 PM
    #40
    bbal
    bbal Well-Known Member
    ‘23 CSM DCSB 6spd
    it seems the 2LO harness is not available anymore
