Manual Transmission Lube
Discussion in 'Performance and Tuning' started by hardground, Jun 9, 2016.
  1. Jun 9, 2016 at 7:33 PM
    hardground
    hardground [OP] Well-Known Member
    Massachusetts
    2011 TRD OR DC V6 Manual
    OME Lift, ImMrYo Mirror Bracket, BlendMount & Mirror Tap ,TRD Quickshifter, 4x4 Illuminated Switch, Red Line Hood Struts, Bak Roll-X
    Recommendations on a GL-4 Lube?
    I know the manual says you can use either GL-4 or GL-5
  2. Jun 15, 2016 at 11:22 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Redline Oil MT-90
    stevotivo12, NAAC3TACO and Srice57 like this.
  3. Jun 15, 2016 at 7:53 PM
    hardground
    Massachusetts
    Thanks, that is what I ordered
  4. Jun 17, 2016 at 6:57 AM
    hardground
    Massachusetts
