Manual Transmission needs Replaced
Discussion in '4th Gen. Tacomas (2024+)' started by orignalohiotrojan, Apr 9, 2024.
  1. Jul 10, 2024 at 8:35 AM
    #221
    Ryan's Taco
    Ryan's Taco Well-Known Member
    Prince Edward Island
    24 TRD Offroad manual
    I know on the Truck King channel they said that Toyota claimed they went from 5th to 1st...And maybe they did but I find it a bit hard to belive because I am quote gentle with my manual but anything over like 6km I find it doesn't want to go in. Usually around 4km and below is when I will go to first
    Want-a-taco likes this.
  2. Jul 10, 2024 at 8:56 AM
    #222
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    But these guys were trying to demo something on YouTube. The guy driving probably hadn't driven this truck fifteen miles and his muscle memory couldn't have been there at this point. Perhaps his daily driver is a 1978 Ford F-50 with a longer shift throw.
  3. Jul 10, 2024 at 3:39 PM
    #223
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    I mean, "Dad" would only have to find the 1st gear gate and push the stick enough to make the synchro spin up the input shaft. He didn't need to complete the shift to make bad stuff happen to the clutch. If he had completed the shift and let the clutch out in that situation, everyone in the truck would have been shoved forward, the rear wheels would probably have drug, and very shortly thereafter the engine would have exploded lol
    shakerhood and Lt. Dangle like this.
  4. Jul 10, 2024 at 5:34 PM
    #224
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    That would have been an epic YT video. Just saying i'd click the hell out of that thumbnail lol.
    shakerhood likes this.
  5. Jul 11, 2024 at 5:06 AM
    #225
    Ryan's Taco
  6. Jul 11, 2024 at 8:39 AM
    #226
    M1KL83
    M1KL83 Active Member
    2024 TRD OR 6MT
    Redarc Brake controller TRD aluminum running boards 255 75 R17 Nokian Outpost nAT x5
    Mine too...RT024 :(
    Couple things...I wonder if Toyota will extend the factory warranty beyond standard period for 6MTs prior to RT028
    Also, could changing our manual transmission fluid early and often help at all?
    I mean if the fault in part is there, I guess I want it to rear its ugly head earlier than later so it can be rectified but at the same time, if there is something we can do in preventative action, sign me up.
    I second @Jeff Lange for President.
  7. Jul 11, 2024 at 8:46 AM
    #227
    Sagebrush
    Gens 1, 2, 3, and 4
    It's the small upper housing that is causing this, so unfortunately, no.
  8. Jul 11, 2024 at 8:46 AM
    #228
    Ryan's Taco
    Not sure why that video didn't work on here.
  9. Jul 11, 2024 at 8:47 AM
    #229
    Sagebrush
    Gens 1, 2, 3, and 4
    I watched it over on Youtube.
  10. Jul 11, 2024 at 9:00 AM
    #230
    lit_taco4x4
    lit_taco4x4 IG and YT: @2a_crawlcamper
    Louie
    2018 Tacoma TRD Pro
    JD fab LT, Archive and Deavers, King shocks, Dual locked, Dual T case, Tundra steering rack, 39’s
    Damn. Already? Toyota quality dropping smh
  11. Jul 27, 2024 at 10:12 AM
    #231
    RGO3264
    RGO3264 Member
    Hate for this to be my first post but I've been seriously looking at buying a 2024 6MT Tacoma TRD OR and now I'm getting spooked because of this issue. The Truck I'm looking at has a VIN that begins with 3TYLE5JN, if I'm reading the TSB correctly that means that it WAS part of the production change and therefore the issue should be fixed?
    I'm excited to join the TACO club but want to make sure I don't buy something that is going to grenade lol.
    Thanks and hopefully will be joining the club soon!
  12. Jul 27, 2024 at 10:13 AM
    #232
    Ryan's Taco
    Do it up that's what warranty is for 6800km on my manual
  13. Jul 27, 2024 at 10:28 AM
    #233
    Foushee
    Foushee Well-Known Member
    Sean
    Texas
    2018 Inferno TRD OR DCSB MT
    Just getting started.
    Get the truck. Toyota warranty does a great job, and if it's part of the group of trucks post-fix then you will be fine. In fact, that transmission is from the Hilux, is well tested, and an improvement over the model in the 3rd gen. There is a lot to like about these 4th gen models, and if you have the means to get one pull the trigger and wheel the heck out of it.
    PDKTaco likes this.
  14. Jul 27, 2024 at 6:35 PM
    #234
    proudsource
    proudsource Active Member
    2023 OR 6MT IC
    yup, this is an infrequent but normal quirk of manual transmissions based on my experience too with several as a daily driver. my 3g 6mt does this too every once in a while and shifting it into other gears (usually 2nd does the trick) with the clutch in seems to reset the alignment and opens 1st back up for entry.
    specter208[QUOTED] likes this.
  15. Jul 27, 2024 at 8:28 PM
    #235
    STEELeR43
    STEELeR43 Well-Known Member
    Hawaii
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
    What others said. If you can afford it, and willing to spend the money, BUY IT, with extended warranty, extended service plan!:thumbsup:
  16. Jul 28, 2024 at 12:58 PM
    #236
    RGO3264
    RGO3264 Member
    Thanks guys! I'll have the dealer confirm if its post fix or not. The dealer is 2 hour away and I probably can't get up there till next weekend. I also need to get a fair trade on my 16 WRX if I were to pull the trigger but want to make sure I have all the info I need. Hopefully I'll be joining the club soon! If for some reason this one gets snagged, have any of you ordered one? If so, how long did it take? When I ordered my WRX it only took 2 months and it was built in Japan, hopefully not any longer than that.
  17. Jul 28, 2024 at 1:34 PM
    #237
    STEELeR43
    Hawaii
    If you “dilly dally” and don’t pay deposit now, it probraly would be sold by next weekend.
    I don’t know about ordering 4th Gen Tacoma, if dealer can bring it in from another dealership. I wanted manual 4th Gen Tacoma, last year, but was not in my Toyota dealer’s system. But they had brand new manual 3rd Gen TRD OR in stock, so I bought it!:D
    RGO3264[QUOTED] likes this.
  18. Jul 28, 2024 at 1:44 PM
    #238
    RGO3264
    RGO3264 Member
    Yeah I know there is a risk, I’ll talk to them tomorrow morning and see if maybe they could hold it with a refundable deposit or something like that. My issue is the trade, I don’t want to commit to buying it, drive up there and then they lowball me. My current car is a one owner, perfect condition, always garaged and never modified. I don’t want to give it away but also don’t want to front the cash and then sell it later.
  19. Jul 28, 2024 at 2:06 PM
    #239
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Did you get quotes from Carvana, Carmax, etc. for your WRX?
  20. Jul 28, 2024 at 2:24 PM
    #240
    RGO3264
    RGO3264 Member
    funny you ask, at carmax as I post this lol. I’ll have to checkout carvana but yeah I think that should give me a baseline.
