Manual Transmission. NO CLUE
Discussion in '1st Gen. Tacomas (1995-2004)' started by mrroper33, Apr 20, 2013.
  1. Apr 20, 2013 at 7:30 AM
    mrroper33
    mrroper33 [OP] Member
    Hello I have a 1989 Toyota Pickup with a 22re v4 2.7L engine. I was driving it the other day and going down the road you would be in gear and then it would rev up like it was in neutral but was still in gear. Finally it decided that it didn't want to be a mover. You can move through all the gears without pushing in the clutch and the stick moves just as if u had the clutch engaged.
  2. Apr 20, 2013 at 7:35 AM
    82 yotaman
    82 yotaman H.O.G Hunter Of Gunman
    BUBBA
    Northern colorado
    1982 toyta pickup/2013 toy MGM dcab 4x4 trd
    avs bugshield, avs inchannel vent visors, weather techs, trd shift knob, tailgate theft mod, windows tinted to 20%, wet okole front and back and black level 8 guardians wrapped in 265/75/R16 Duratracs oil catch can mod interior LED's, pop & lock pl5500, Leer 180 topper, OME full lift with Arb bullbar
    sounds like you need a new clutch and the 22re displacement is 2.4L
  3. Apr 20, 2013 at 7:43 AM
    scottg918514
    scottg918514 Well-Known Member
    2013 DC, TRD 6-spd Manual, 4wd
    Exactly what happens when clutch disc slips.
  4. Apr 20, 2013 at 8:06 AM
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    CLUTCH IS GONE
  5. Apr 20, 2013 at 8:08 AM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Pressure plate can't hold clutch any more because it has worn down.
    Kinda like a brake worn down to the point that it doesn't work.
  6. Apr 20, 2013 at 11:20 AM
    mrroper33
    Thanks that kinda is what i was told by others but wasn't sure. And ya i messed up on the displacement not sure with i put 2.7
  7. Apr 20, 2013 at 11:28 AM
    mrroper33
    so do i need just the plate or should i replace the who clutch assembly
  8. Apr 20, 2013 at 11:32 AM
    82 yotaman
    BUBBA
    Northern colorado
    whole clutch, the disc, pressure plate,Throw out bearing, pilot bearing, and aliment tool just remember to get the flywheel turned and while you got the tranny out if your rear main is leaking fix it. Also when you put the flywheel back on put blue thread locker on the flywheel bolts and torqe to 80 ft/lbs
  9. Apr 20, 2013 at 11:36 AM
    mrroper33
    is the a throw out bearing the same as a release bearing
  10. Apr 20, 2013 at 11:37 AM
    82 yotaman
    BUBBA
    Northern colorado
    yes it's the same thing
  11. Apr 20, 2013 at 11:38 AM
    mrroper33
    ok thanks
  12. Apr 21, 2013 at 3:06 AM
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
  13. Apr 23, 2013 at 9:36 AM
    scottg918514
    Pushing pedal, pushes on pressure plate which pulls clutch disc off flywheel, allowing shift without grinding.
    If pressure plate couldn't pull disc off flywheel and the disc was fine, it wouldnt slip. I would just be hard to change gears, since tranny wouldn't stop spinning (or slow down).
    But, agree on changing pressure plate and throwout bearing, if replacing clutch disc.
