Manual Transmission Noise
Discussion in 'Technical Chat' started by WabashTaco, Jul 26, 2022.
  1. Jul 26, 2022 at 2:50 PM
    WabashTaco
    WabashTaco [OP] Well-Known Member
    2017 TRD OR DCSB
    Hey TW,
    I'm experiencing a high pitched whine when downshifting into 1st gear, while the clutch is still in.
    On a previous Wrangler MT, I had a similar issue that turned out to be a problem with the Synchromesh.
    Has anyone else experienced this and had it diagnosed / repaired? Thanks.
  2. Jul 26, 2022 at 2:51 PM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    Post a video of the noise so we can get a better idea about your problem.
  3. Jul 26, 2022 at 2:52 PM
    WabashTaco
    2017 TRD OR DCSB
    Will do this evening. Thanks.
  4. Jul 26, 2022 at 3:00 PM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    At what speed?
  5. Jul 26, 2022 at 3:18 PM
    WabashTaco
    2017 TRD OR DCSB
    Anything over 15 mph. I typically downshift into 1st between 20-25 on a manual.
    I'm also the second owner, just bought it about a month ago with 45k miles... Which was also similar to the Jeep... the previous owner of that vehicle (my salesman/buddy) would start out in second a lot.
  6. Jul 26, 2022 at 3:20 PM
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    That sounds really fast for 1st gear. You sure you aren’t just hearing the gearbox whining because of the speed? Not so much a problem as nature of the beast?
  7. Jul 26, 2022 at 3:22 PM
    WabashTaco
    2017 TRD OR DCSB
    That's just when the downshift occurs, but again, the clutch is still in at this point. After noticing it in the first couple weeks, I've just been leaving it in neutral until I come to a stop.
  8. Jul 26, 2022 at 3:40 PM
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    I’m interested to hear what others think. My suspicion is that it’s too much speed for first gear and even though the clutch is in, the back half of the transmission is still spinning relatively fast which makes first gear spin fast which causes the noise.
    Which witch is which
    Cadha13, JPT4x4ac and 69 Jim like this.
  9. Jul 26, 2022 at 3:49 PM
    WabashTaco
    2017 TRD OR DCSB
    Can't get a video uploaded. Won't accept mp4.
  10. Jul 26, 2022 at 3:50 PM
    WabashTaco
    2017 TRD OR DCSB
    I just tested it at 15 mph and same problem. Noise persists down to 5 mph.
  11. Jul 26, 2022 at 3:52 PM
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    I’m sticking to my guns here. Anything faster than a rolling stop and 2nd gear is usually a better bet. I think the truck’s just moving too fast for the downshift into 1st.
  12. Jul 26, 2022 at 3:53 PM
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Upload it to YouTube and post the link. That usually works best on here
  13. Jul 26, 2022 at 3:54 PM
    WabashTaco
    2017 TRD OR DCSB
    I've been driving manuals for over 30 years... And I've only run into this problem twice now.
  14. Jul 26, 2022 at 4:02 PM
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    I believe you.
    I haven’t specifically had synchro issues on any of my manuals, Wranglers included. I’m curious what others think.
  15. Jul 26, 2022 at 4:05 PM
    WabashTaco
    2017 TRD OR DCSB
  16. Jul 26, 2022 at 4:06 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    i've had this issue in multiple cars and the issue was using GL-5 fluid when I should have been using GL-4 ONLY. the gl-5 was just too slippery for the synchros.
    Key-Rei and doublethebass like this.
  17. Jul 26, 2022 at 4:08 PM
    RTweet
    RTweet Well-Known Member
    Oregon
    2021 White TRD Pro, MT
    Doesn’t feel like engine braking? My truck would break my neck if I shifted to first @ 20-25mph.
    SoonToBeOn39s, 69 Jim and Key-Rei like this.
  18. Jul 26, 2022 at 4:11 PM
    WabashTaco
    2017 TRD OR DCSB
    Not sure if the tranny fluid has been changed, but I did ask at the last service.. And factory recommendation is like 90k miles, so I just assumed it was still the original fluid from the factory.
  19. Jul 26, 2022 at 4:12 PM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    what's funny is the owner's manuals on those vehicles said use Gl-4 or gl-5 fluid but really you should only use gl-4. i'd get some redline fluid in there asap.
    MaxTorque likes this.
  20. Jul 26, 2022 at 4:14 PM
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    It’s not engine braking if the clutch is to the floor because the gearbox would be disconnected from the engine, so no breaking necks here.
    It sounds to me like the back half of the gear box is straining to catch up to road speed and these trucks have loud gearboxes. 1st will spin the fastest and so it’ll be the loudest.
    SoonToBeOn39s and ToyoTaco25 like this.
