Manual Transmission oil change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Manwithoutaplan, Dec 25, 2011.
  1. Dec 25, 2011 at 5:13 PM
    Manwithoutaplan
    Manwithoutaplan [OP] the full Monty
    ID
    I am about to change my manual transmission oil & i am just double checking if this is the correct weight (Manual Transmission: 75w90). Any specfic brand I should use or stay away from?
    aka i did use the search option :p
  2. Dec 25, 2011 at 5:19 PM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series LC
    Tons and 40s
    75w-90 is the correct weight. IIRC about 3 qts. Seems redline mtl and mt-90 is really popular.
  3. Dec 25, 2011 at 5:22 PM
    Manwithoutaplan
    ID
    thx man appreciate it alot.
  4. Dec 25, 2011 at 5:39 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I use AMSoil severe gear 75w-90 with no issues and I too have read that Redline MT90 works good.
  5. Dec 26, 2011 at 8:17 PM
    Manwithoutaplan
    ID
    one more question is their a filter in the transmission like a automatic???
  6. Dec 26, 2011 at 8:20 PM
    afd23a
    The Dynamo of Dixie
    Nope. The drain plug has a magnet in it so just clean the shavings off of it and you're good to go.
  7. Dec 26, 2011 at 8:21 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
  8. Dec 26, 2011 at 8:22 PM
    Manwithoutaplan
    ID
    sweet thanks for the input :D
  9. Dec 26, 2011 at 8:27 PM
    afd23a
    The Dynamo of Dixie
    no problem. just make sure you loosen the filler plug before draining it
  10. Dec 26, 2011 at 8:28 PM
    Manwithoutaplan
    ID
    ok. I am guessing that makes the oil drain faster correct???
  11. Dec 26, 2011 at 8:29 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Yup
  12. Dec 26, 2011 at 8:30 PM
    afd23a
    The Dynamo of Dixie
    Yes, but the main reason is so that you know you will be able to fill it back up after draining it.
  13. Dec 26, 2011 at 8:30 PM
    Manwithoutaplan
    ID
    good stuff.
  14. Dec 26, 2011 at 8:31 PM
    Manwithoutaplan
    ID
    that makes sense.
  15. Dec 26, 2011 at 8:38 PM
    afd23a
    The Dynamo of Dixie
    yeah, you don't want to get stuck with no oil in the tranny and no way to fill it back up.
  16. Dec 26, 2011 at 8:39 PM
    afd23a
    The Dynamo of Dixie
    you may need a fluid pump depending on the type of bottle your oil comes in
  17. Dec 26, 2011 at 8:39 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    also makes the flow coming out less messy
  18. Dec 26, 2011 at 8:41 PM
    Manwithoutaplan
    ID
    ok cool. yea i was thinking of going with royal purple.
  19. Dec 26, 2011 at 8:43 PM
    MonkeyProof
    SoCal- SGV
    go with amsoil or something else..been reading up on royal purlpe after chase from ecgs said something about in regards to using it in the diffs..seems like a lot of peeps don't like royal purlpe after googling and reading about experiences in various forums
  20. Dec 26, 2011 at 8:46 PM
    Manwithoutaplan
    ID
    ok should i go with synthetic oil or just regular gear oil
