Manual transmission oil: Liqui Moly 20012 GL4+
Discussion in '3rd Gen. Tacomas (2016-2023)' started by whiseve, Oct 9, 2022.
  1. Nov 17, 2022 at 2:21 PM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    Mine has about 1800 miles and I definitely need to slow down the 1-2 shift when things are cold. Once warmed up it's better.
  2. Nov 17, 2022 at 2:22 PM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    Interesting, ty for chiming in. Seems like coarseness seems “normal”. I have few other issues with it. Most manuals have some sort of issue here and there. My m3 wouldn’t go into 2nd cold… my c5 vette sometimes wouldn’t go into 1st without going into 4th first every 10th time due to non lined up syncros…
  3. Nov 17, 2022 at 2:23 PM
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    I am, I’m not even gently on it. I’ve smoked it twice doing stupid things. It’s definitely been through a lot. The throw out bearing sounds like a supercharger but the plate is still holding and the bearing hasn’t given up on me yet lol
    maxmk8[QUOTED] likes this.
  4. Nov 17, 2022 at 2:26 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Toyota shouldn’t put the same rear gear oil in the rear axle as the MT fluid in the MT. Highly doubt they do that, they call out different fluids in the owner’s manual.
    Pretty much any GL4 75W-85 to 75W-90 will work absolutely fine. The notchy feel is mostly the transmission. I’ve had stock fill, Motorcraft XTM5QS, and Ravenol synthetic blend. They all felt like improvements initially but it wears off after a bit. Like any manual, it’s a lot more smooth when it’s warm.
