Manual Transmission questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PukinMr86d, Jul 23, 2023.
  1. Jul 24, 2023 at 9:55 AM
    PukinMr86d
    PukinMr86d [OP] Member
    2017 Magnetic GreyTRD Off-Road Manual
    I know she's a turtle starting out but these impatient ATL drivers are not aware. Guess I have to get use to getting honked at. Feel like I'm in F1 in the higher gears compared to the old shitbox 4runner I had tho so I'll get over it.
    First time owning a manual, plus it being the nicest truck I've ever owned, every little tic gives me a slight panic attack, thanks for the help.
    wayupnort likes this.
  2. Jul 24, 2023 at 11:30 AM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Congrats on your first manual and you should look into a tune. There is a few in the performance section if you wanted to check them out
  3. Aug 10, 2023 at 4:24 PM
    PukinMr86d
    Alright I finally got my Unicorn Cu... I mean Tears in the mail.
    Its a FORD product?!
    I feel like letting a ford product anywhere near a Toyota is sacrilegious
  4. Aug 10, 2023 at 4:48 PM
    mtip
    mtip Go Outside & Play!!!
    South Louisiana
    18 TRD Sport 6MT 00 Tundra 5MT
    Hopefully you'll feel different about that, once those "tears" get in your transmission.
  5. Aug 11, 2023 at 8:34 PM
    2023tacomer
    2023tacomer Well-Known Member
    I dont see how a fluid change on low mileage tacomas can improve shifting. Is the fluid from factory synthetic? If so, I dont see how one can improve upon it. I just got my manual, 700 miles in and I don't believe the gear oil is the issue. It's just the truck, drive it correct and the gear oil is fine. If I change any gear oil it won't be until 10k, and that will probably be the last time ever. Even if I got to 220k like my tundra.
  6. Aug 11, 2023 at 10:45 PM
    joba27n
    Nolan
    Alberta
    In my experience the first service fill should be changed maybe not after 700 mi but maybe 5k-10k because there is no filter in there to capture the debris. After that following the manual is good because sure you could probably run it as a lifetime fill but again no filter in the system and albeit smaller there still will be wear material that will cause more wear to the gears, bearings and seals. Plus i find you can usually feel when the fluid degrades so for i found acdelco syncromesh is toast after 25'000-30'000kms or 2 years where as amsoil 75w-90 manual trans oil is good for around 70'000-80'000 kms before the sifting sucks
