Manual transmission situation
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LJGIbbs, May 13, 2017.
  1. May 13, 2017 at 8:14 PM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    Parking brake is on always when parked. I add putting it in gear when I know there's an incline even ever so slightly.
    0210 and TACOVRD like this.
  2. May 13, 2017 at 8:23 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    In gear with the emergency brake on here, even on level surfaces.
    The only time I'd leave a vehicle in neutral is if I had wheel chocks, and that was just when I was storing a vehicle long term without the parking brake on.
    When I had my automatic '13 I'd park with the truck in park and the foot automated emergency brake on to reduce the parking pawl on the auto. That was just me though, as it became second nature.
    TACOVRD and shakerhood like this.
  3. May 13, 2017 at 8:26 PM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Yeah I always use the e-brake on my auto to reduce/eliminate torque lock on the tranny. I just hate the position of the e-brake....I'd much rather have a T-handle.
  4. May 13, 2017 at 8:29 PM
    LJGIbbs
    LJGIbbs [OP] Well-Known Member
    Independence Missouri
    2017 TRD PRO Cement 6MT
    none yet/none planned! It's perfect!
    How did this post become about automatics?
    TACOVRD likes this.
  5. May 13, 2017 at 8:37 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I have still been punching the dash reaching for the T Handle in my 3rd Gen, 17 years of 1st and 2nd Gens will do that to you.
    TACOVRD[QUOTED] and nevadabugle like this.
  6. May 13, 2017 at 9:01 PM
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    Sorry, just professing my sincere sadness for the missing T-handle parking brake.....now back to our regularly scheduled programming. :hattip:
    shakerhood likes this.
  7. May 13, 2017 at 9:03 PM
    bodean
    bodean Well-Known Member
    Shawn
    Crowsnest Pass, AB
    02 Taco RCSB, 16 Taco AC6MT, 07 FJC, 22 Bronco
    Thanks for the replies (sorry for hijacking the thread). Guess I should start getting into the habit of putting it in gear as well.
  8. May 13, 2017 at 9:10 PM
    Garrett75x
    Garrett75x Well-Known Member
    Torrance
    2017 TRDOR 4x4 JBL P&T
    Pro Grille, Shmellfab rock sliders, Carhartt seat covers
    My 92 Pickup 22re did this as well, I woke up one morning to find my truck gone, stolen I thought.
    It was down the street (I live on a slight hill) about 5 houses down on the other side of the street with the drivers side rear tire up against the curb
    Was pretty embarrassing my neighbors probably thought I was drunk or something
    JJ TACO and TACOVRD like this.
  9. May 13, 2017 at 9:14 PM
    0210
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    Correction: always use the ebrake, regardless of the transmission type. It's a good habit to have, and will provide a safety margin in any vehicle you happen to drive, without having to think about it.
    All those recent issues with Jeep Cherokees being accidentally put into N instead of P and then rolling and killing their drivers? Yeah, use the ebrake and that shit won't happen.
  10. May 13, 2017 at 9:15 PM
    dmccurdy7
    dmccurdy7 Lurker
    Doug
    Caldwell, ID
    2010 6MT ACLB TRD Off Road
    I've always pulled my e-brake and left it in gear. Even when I've owned auto's I used the e-brake...some habits die hard.
  11. May 13, 2017 at 9:23 PM
    BlakeM
    BlakeM Well-Known Member
    Blake
    Gonzales, LA
    2023 T4R.SR5.4WD.OMG.LOL.WTF
    With all my other MT trucks, I've always just put them in 1st when I parked, unless on an incline. This is the first MT truck that I've ever used the parking brake regularly.
  12. May 13, 2017 at 11:04 PM
    AWDDude
    AWDDude Well-Known Member
    2017 Tacoma TRD Off Road DCSB, QuickSand
    In my 20's I only owned manual vehicles. Now that im in my 30's i found myself wanting something simpler to drive so i got an automatic on my 2017 Tacoma.
    In terms of how to park a manual here is what i have learned. I used to have a subaru STi, it's valve train was driven by a timing belt. that belt had tensioners on it t keep the belt tight. The problem was that the tensioners only worked when the engine spun in a certain direction, and infact would loosen if the engine was spun in reverse. This caused one of the cams on my engine tto lose timing and cause all kind of issues. So to that prevent that from happeneing again I would always use a parking brake and leave it in gear. if facing up hill i would park in reverse, if down hill i would park in first, so that if it did cause the engine to spin it would at least spin in the right direction. This probably isnt as big a deal for engines with timing chains but i still believe it to be the safest option.
  13. May 13, 2017 at 11:38 PM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    Always use the e-brake on an automatic as well. The parking pawl is a tiny little thing.
    Riding Dirty and FHC[QUOTED] like this.
  14. May 14, 2017 at 3:30 AM
    bls82261
    bls82261 Well-Known Member
    Brian
    VA
    2017 TRD Sport AC Manual 4X4
    Don't know about most people but I always leave in 1st w/parking brake applied
  15. May 14, 2017 at 4:00 AM
    #35
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    I leave my MT in gear and use the E brake.All the time, its a "Belt and Suspenders "type of thing. Plus the E brake likes to be used so it does not seize.
    su.b.rat likes this.
  16. May 14, 2017 at 4:47 AM
    #36
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    I've always left in gear and and used the e brake. Even doing this my moms Subaru Outback would roll down the driveway every once in a while, and my WRX would inch backwards and set off the alarm. Maybe it's just my experience but it seems like the handbrake works better when the rear brakes are drums.
  17. May 14, 2017 at 6:50 AM
    #37
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    It's strange going to a vehicle without the t handle. It's even weirder when someone gets in the truck and notices the handle when I release it, and they're like "wtf is that thing??" I forget that it's basically unique to toyota pickups. I'm like "duh it's the e brake wtf did you think it was"
    JJ TACO and nevadabugle[QUOTED] like this.
  18. May 14, 2017 at 6:51 AM
    #38
    stun gun
    Aaronski
    Tacomas.
    I've never messed with rear disc e brakes, but I've HEARD because of the fundamental design, they suck ass, and drums are WAY better when it comes to e brakes.
  19. May 14, 2017 at 6:55 AM
    #39
    stun gun
    Aaronski
    Tacomas.
    YEAH DUDE! killed the new Kyle Reese from the terminator salvation movie.
  20. May 14, 2017 at 6:55 AM
    #40
    DallasTX
    DallasTX Well-Known Member
    2015 4x4 AC
    I always leave mine in first and always set the parking brake. Did not used to and one time I came out of a store and found it had rolled back several feet. Fortunately, it did not crash into anything. Not sure what happened, but assumed I failed to get it all the way into gear and it slipped out. So now, I put is in first and set the parking brake. Ironically, I do not set the parking brake when driving automatics except if parking on a steep incline.
