Manual Transmission Sound
Discussion in '1st Gen. Tacomas (1995-2004)' started by woad4, May 11, 2023.
  1. Sep 9, 2023 at 6:22 PM
    woad4
    woad4 [OP] Well-Known Member
    2003 Tacoma Xtra Cab
    3rzfe
    If anyone ever stumbles upon this thread with similar symptoms?
    The transmission shop pulled it apart, replaced several items including the input shaft bearing, put it back together and the sound was still present.
    They pulled it apart again and noticed the mainshaft was skewed? Either way, the truck is dead silent now.
    The previous owner stated the carrier bearing section broke and the drive shaft spun around like crazy for a second. Curious if that was what damaged the mainshaft.
    Currygoat and Madjik_Man like this.
  2. Mar 27, 2025 at 12:41 PM
    czotie
    czotie Dang Ol' TacoBio
    Zote
    California
    2001 Silver Tacoma 4x4 Xtra Cab
    Bilstein 5100's Firestone Riderites Deckplate Mod & AEM Aisin Clutch plate Luk Flywheel Timken bearings Marlin Crawler shifter bushing GTA CarKit Gentex 453
    I got my 2001 Tacoma in 2016 with 235k miles on it. It had this issue when I bought it. It's now at 280k and I haven't rebuilt the transmission yet. I wheeled it through the Mojave and many other areas multiple times.
    The sound is certainly getting louder... I have a a full AISIN rebuild kit and some extra parts that I've been sitting on till I lived in a place with a garage but that still hasn't happened. I'm getting a little paranoid now in the Sierras that the transmission might take a @#$@ so I'm not doing any long drives on it or any wheeling.
    I'm planning on syncing the carbs on my Honda motorcycle and then dropping the transmission in the Tacoma and driving it up to Nick with Yota1 in Riverbank CA. They've been good to chat with and after seeing Tim's video it I can't imagine taking it anyone else.
    Wish I had a garage but... California :)
    Black97v6MT and ab_1280 like this.
  3. Mar 27, 2025 at 1:06 PM
    ab_1280
    ab_1280 Well-Known Member
    Alan
    2000 Silver Tacoma TRD 4x4 3.4L V6 X-Cab Manual 413K
    I'm in the same boat. My transmission is making a small amount of noise that both of my two shops I use says is input shaft bearing. My other mechanic is not as concerned about it than the 1st one and thinks I can drive it for possibly quite some time before getting to the rebuild. Both are people I trust, one is more cautious.
    Seeing as the truck is our only vehicle right now, I'm going to wait. Old subaru died recently, we're shopping.
    Then, if weather allows (CA, where it doesn't rain April thru Oct, generally), maybe I could drop it in the driveway and take it to yota1 or Martin Crawler.
    I do hear the whirring sound faintly and have noticed a slight drop in mpg. But I really have to listen for it.
    Black97v6MT likes this.
  4. Mar 27, 2025 at 1:22 PM
    czotie
    Zote
    California
    Sounds like you're where I was at 235k. Your Bio says* 413k, was the trans ever replaced? I plan on doing the driveway drop soon.
    Im in SLO County, Marlin is a bit closer to me. But this is the primary reason I would go to Yota1: https://www.tacomaworld.com/threads/manual-transmission-r150f-help.828515/page-3#post-29723439
    ab_1280[QUOTED] likes this.
  5. Mar 27, 2025 at 1:38 PM
    ab_1280
    Alan
    Thanks for the link. I'll look at carefully over the weekend. Yota is closer to me, so that's good. I'm in the east Bay Area.
    Yes, I'm at 413k and going strong. Just did my 4th timing belt, my 1st new clutch after 380k on the original, new cats, new driveshaft carrier bearing, and a few other items. Engine is great, clean oil every 5k with almost no replenishment of oil in between. There's a little oil getting onto the transfer case from above, gaskets may be leaking slightly. My regular mechanic says don't do anything yet. He's says it's minimal and to be expected at 400k plus.
    I've had to do a bunch of small stuff (MAF, new spark plugs when I had the timing belt done, etc). Tranny has never been changed. When the clutch was done (it really was noisy with a bad throw-out bearing), mechanic noticed the input shaft bearing noise when it was in the shop. I couldn't hear it before, perhaps due to the throw-out bearing noise. I could barely hear it after they put it all back together and thought maybe I was imagining it. But now (15k later) it is a little more. I wish I had done the tranny when the clutch was being done but couldn't wait for the rebuild due to our dead subaru. We only had one vehicle.
    Let me know how your driveway drop goes. Do you have a 4cyl or 6cyl?
    czotie[QUOTED] likes this.
  6. Mar 27, 2025 at 1:56 PM
    czotie
    Zote
    California
    Will do. 3.4L 6 Cyl, running great.
    Check out Tim's YouTube series with Yota1, the first part is dropping the transmission on the driveway. There are some foobar moments you'll want to know about. I wish Yota1 was that close to me, it's a 4.5 hr drive.
    Glad to hear your trans lasted that long!! I did the clutch at ~240k hoping that would fix the noise but it's the countershaft bearings so it didn't. Sounds like you're on top of the maintenance and it's shown.
    New cats, wow I've been praying and clearing every time I get the dreaded P420 I won't need to do that. Replaced the O2 sensors got me around that for now. I would suggest checking out your IAC valve and cleaning it if you haven't already. That was causing MPG and idling issues for me. Also helps with airflow.
    I also had some oil on the transfer case. I did the valve covers on my truck in 2018 after I had a mechanic do it in 2017 and they didn't use OEM and didn't put FPIG in the cam corners and half moons. I've been doing everything that doesn't require a press since.
  7. Mar 27, 2025 at 2:14 PM
    czotie
    Zote
    California
    I just called Yota1 and they will take a 3-4 week notice prior to drop off.
    If you plan to ship you need to work with them to make sure it's not a crappy company with shitty crates.
    They say it will be a 2-4 week turn around on the rebuild depending on core salvage situation and what mods you want.
    I'm going with the 5th gear upgrade for low rpm and better gas mileage at highway speeds.
    If you have a rebuild kit and other items from Marlin and they haven't been tampered with they will use them in your rebuild.
    I'm heading up that way middle of next month so I may just do it now.
    ab_1280 likes this.
  8. Mar 27, 2025 at 2:53 PM
    Pbfender15
    Pbfender15 Well-Known Member
    '00 Reg. cab 5spd; '03 Xtra SR5 TRD
    Stock, more or less...
    @woad4 OP
    I bought my '03 in 2016 with 86kmi. Bought from a used dealer in WA. Got home to NY and found the sound you had. Push in clutch, no sound. Idle, whirring sound.
    Went to 3 shops incl. Toyota all said throwout bearing. Truck had a 90 day warranty for power train. Got dealer to pay for Trans rebuild. They did several bearings, etc., shop amazed at like new condition of trans when it was apart. All back together -- still same noise. "just how it is" he said. Fortunately, I paid nothing for this work.
    Now, 9 years and 100k mi later, still same noise, no worse. I've tuned it out.
    Can you be more specific what they did to fix yours? Replace the main shaft....?
    thanks -
    Currygoat and Black97v6MT like this.
  9. Mar 27, 2025 at 4:25 PM
    ab_1280
    Alan
    Yeah, I chased that P0420 for a while. I'm on my 2nd pair of new cats. The first pair was at about 250k in 2014. The aftermarkets aren't as good I guess because the rear one needed to be replaced at 280k (no cost to me). At about 318k, p0420 again. We did the usual stuff, clean MAF, throttle body, IAC cleaning, vac hoses, and O2 rear sensor at 344k. Then at 383k put a new MAF in. I was passing smog, so all good.
    Then around 395k, the P0420 wouldn't go away. I'd clear it and 25-30 miles later, back again. I broke down and did the cats. Aftermarkets again because I was told originals not available, and quite expensive if they were.
    There was an exhaust smell after the 1st set of cats and again at the 2nd set. After the first, they checked all over the exhaust system looking for a leak, they tightened things up (I guess) and it was sort of ok. They even used a wand to try to chase the leaks down.
    2nd set of cats, the exhaust leak smell was less than the first time and gradually got better. I also think old gaskets in the firewall may let some exhaust smell in, but I don't know. I notice it mostly when climbing up a hill and the windows are open, or the moonroof is open.
    I really want to do the tranny but need to wait until we get a 2nd vehicle. It just bothers me to drive it when I know the truck needs something and I'm not giving it to her. But it could also be good to wait until the noise is more definitive.
    Thanks for the info on Yota in your next post. I might go for the 5th gear upgrade. I would also deliver and pickup myself rather than shipping.
    Also thanks for the info on the IAC. I may look into that sooner rather than later. There was a good video posted in TW on that. I'm not having any idling issues, the truck just purrs. But mpg is down 1-2 miles. I'll monitor that better on an upcoming trip and see.
    Edit: also thanks for the info on the valve cover gasket. My mechanic says not needed now, but at some point I'll want to do it because of the same reason, it bugs me....
  10. May 19, 2025 at 11:33 AM
    czotie
    Zote
    California
    After talking with Yota1, they don't need lead time for drop offs. They say it will take 2-4 weeks to rebuild. Nick does 4 in a day. I would recommend calling them still to make sure they have everything you need and they're ready for you.
    @Pbfender15
    My only guess is that your mechanicas skipped this step of checking runout on the main or countershaft with a dial indicator lathe set up and your bearing may be spinning instead of stationary or the shaft may have extra play on the inner race of the bearing... : https://www.tacomaworld.com/threads/manual-transmission-r150f-help.828515/page-3#post-29723439
    ab_1280 likes this.
  11. May 19, 2025 at 4:22 PM
    Black97v6MT
    Black97v6MT 366k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    I had a rebuilt r150f done by Yota1 and shipped out to Toyota specialty shop in Chicagoland where original clutch started getting fussy out on the road
    After many thousands of coin in repairs plus rebuilt trans and shipping halfway across the country
    It has always made the most obnoxious whirring noise since I got taco back
    It happens noticeably at idle with pedal out and gets worse while on the move with RPMs increasing
    I have no clue what it is going on for what to do about it :(
    Taco has not ever sounded this horrific in the past 28 years
    Is it Bad transmission rebuild, bad parts? Bad yota mechanic and techs that hacked putting my poor taco back together
    :notsure:
    Is this all related somehow?
    https://www.tacomaworld.com/threads...ormal-vibrations-in-the-shifter-stick.855702/
    Currygoat likes this.
  12. May 19, 2025 at 5:21 PM
    czotie
    Zote
    California
    So your rebuilt trans from Yota1 was having heavy vibration and not able to get past 55 mph in 5th gear?
    Did you get a 5th gear upgrade or any custom gearing changes?
    Did you have a core transmission or was it a fully rebuilt from a different core?
    Sorry to hear that. Blows my mind how many people I see with this exact same sound, exact same issue, and we don't have any definitive answers.
    Black97v6MT[QUOTED] likes this.
  13. May 19, 2025 at 5:40 PM
    ab_1280
    Alan
    Hi Black97v6MT-
    I'm sorry to hear about your issues continuing! I wish I had some ideas to throw your direction other than what has already been discussed. Others on this forum are more qualified than I am...
    Did you ship your original transmission to Yota1? If Yota1 rebuilt yours, did they tell you what was wrong with it? And what they needed to replace? Did they check shaft runouts?
    Or did you send them yours afterwards as a core?
    Did you look into U-joint issues? I think that was mentioned in the other thread.
    I am currently scheduled to have Yota1 remove, rebuild and re-install my transmission next month. They told me that based on what they found inside, the cost may need to be adjusted up or down. I am wary...after reading about your experience. Mine could be different since they will be removing/rebuilding/installing it. They are about an hour and a half away, so I could conceivably take it back for warranty work (1 year unlimited mileage on the rebuild plus install).
    My tranny has a faint but audible whirring sound in pretty much all gears. The mechanic that replaced my clutch last June identified it as the input shaft bearing.
    I'm rethinking about who should fix mine, Yota1 vs my local guy that I have had pretty good experience with so far. He'd send the tranny out, but not to Yota1, a different rebuilder that he's worked with for a long time. But I'd be 2 weeks without a vehicle rather than 1 with Yota1.
    Appreciate any thoughts from all...anyone had Yota1 remove/rebuild/install?
  14. May 19, 2025 at 5:46 PM
    czotie
    Zote
    California
    @ab_1280 I'm going to call Joe at Yota1 tomorrow and see if they can give us any definitive info on this issue. Nick has to know what it is.
  15. May 19, 2025 at 6:01 PM
    #35
    ab_1280
    Alan
    Thanks for doing that! I chose yota1 based on mostly positive descriptions here on TW. Also shorter turnaround.
    I sure hope the OP gets an answer on this. These old trucks have their idiosyncracies.
  16. May 19, 2025 at 6:11 PM
    #36
    czotie
    Zote
    California
    OP posted on YouTube that they had the main and counter shafts replaced for the sound to go away.
    From all my other reading this points to the input shaft and counter shaft having runout or being slightly bent and a bad or worn thrust washer which will result in counter shaft misalignment and input shaft/countershaft teeth wear.
    If Yota1 transmissions are having these issues after rebuild it could be within tolerances.
    Requesting new input shaft and countershafts along with thrust washers may raise the cost of your rebuild significantly. It may also be a longer wait for the parts to come from Japan... But it maybe he the only way to get rid of the sound..
    Although we don't know definitively.
  17. May 19, 2025 at 6:17 PM
    #37
    ab_1280
    Alan
    Interesting idea, however. I could possibly ask Joe to quote them with a lead time. My truck is drivable and I could wait.
    Black97v6MT and czotie like this.
  18. May 19, 2025 at 6:27 PM
    #38
    czotie
    Zote
    California
    Let me know what he quotes you. Tarrifs aren't helping us here.
    I was planning on dropping the transmission last Saturday but I called Friday and the 5th gears are on order from Japan so I'm waiting.
    Something I may have forgotten to mention is I replaced my clutch, throw out bearing and pilot bearing 3-5 years ago and it didn't change a damn thing in fact it only has gotten louder.
    I hope this bearing inside the tcase lol.. that would be rich.
    ab_1280 likes this.
  19. May 19, 2025 at 6:55 PM
    #39
    Pbfender15
    Thanks -- I hope you sort yours. I've put 100k on mine as is so won't pursue any additional remedies. Drives fine and no decline in 100k/9 years. The only annoyance is when I talk to someone out the window at idle...I have to quiet it down by stepping on clutch or shutting engine...the latter a good thing because idling is lame. GL~
  20. May 20, 2025 at 12:35 PM
    #40
    czotie
    Zote
    California
    Came across the post from Marlin (RIP) on here:
    https://board.marlincrawler.com/index.php?topic=4236.0
    He mentioned the seal between the transmission and the tcase often goes bad and transmission oil leaks into the tcase resulting in transmission gear running bear or low and burning.
    I've noticed my Tcase has had a minor leak from what looks like the fill plug so it would correlate with what Marlin is suggesting in his response.
    I just cracked the transmission and it's full of MT-90 still and smells just fine so... That's not the problem.
    Onto the next thing...
