Manual transmission towing
Discussion in 'Towing' started by vectaur, Jul 15, 2021.
  1. Jul 15, 2021 at 6:28 AM
    vectaur
    vectaur [OP] Member
    Just curious if you manual guys ever use 6th gear for towing?
    Manual says to avoid, but towing in 5th on a long trip there were several stretches where the engine wasn't straining at all and I felt maybe I could have saved a bit of fuel. My trailer is about 3200lbs loaded, this is a 3rd gen.
  2. Jul 15, 2021 at 6:33 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    I have on flat stretches or down hill areas when I didn't need engine braking. Otherwise it isn't much use and I tend to stay in 5th.
  3. Jul 16, 2021 at 9:52 PM
    TerandDi
    TerandDi Member
    2015 White DCSB TRD Sport
    About the same for me with a 2015. Fifth or sixth doesn't make much of difference in fuel mileage. I've towed in sixth, but find I downshift to fifth at the first slight grade.
  4. Jul 27, 2021 at 2:48 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    if U had a ScanGauge ( I run 1 all the time )
    U would see that under load little is gained goin to 6th
    unless Ur are running 75-80 mph +
    the ecm compensates ...............changes the throttle & ignition accordingly
    there is a valid amount of ‘ load ‘ on the engine simply getting U down the road
    i gained 2mpg simply putting on a shell top = MORE aero than the turbulence of an open bed
    only time weight makes a diff is pulling grade
    U lose more MPG by the aero tearing up the actual ‘ CD ‘ coefficient of drag
    18 wheeler trucks have gained as much 20% advantage & have increased mpg
    simply cheating the air
    everyone mentions weight o trailer.....................Ur NOT as heavy nor move as much air as a semi
    some actually have double overdrives tho they are TUNED to pull double overdrives
