Manual Transmission Upgrade
Discussion in '1st Gen. Tacomas (1995-2004)' started by Trett19, Jun 6, 2017.
  1. Jun 6, 2017 at 5:56 AM
    Trett19
    Trett19 [OP] New Member
    2001 tacoma v6 standard
    Volant cold air intake
    Recently I have spent a lot of time researching potential upgrade options for my 2001 3.4l V6 Tacoma. I know that eventually I want to supercharge the engine. Currently I have not found any sufficient information on what I can do to upgrade the transmission beside changing out the flywheel and clutch. Can anyone help me out with some info or point me in the right direction? Any help is appreciated.
    Thank you.
  2. Jun 6, 2017 at 7:36 AM
    Actionjackson
    Actionjackson Well-Known Member
    Jack
    MA
    2004 Tacoma
    I am not sure but I think the trans you have (me too) is a variant of the Toyota R154. A company called Driftmotion has some upgrade stuff for that trans which may fit.
  3. Jun 7, 2017 at 6:11 AM
    Trett19
    I will definitely check them out. Thank you.
  4. Jun 7, 2017 at 8:05 AM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    I would like to know as well. Most people have told me the 5 speed is pretty stout though even with substantial power upgrades.
  5. Jun 7, 2017 at 9:31 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    AFAIK there aren't any "upgrades" besides installing a short throw shifter from URD or Marlin
  6. Jun 7, 2017 at 9:39 AM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Im curious about what it would take to adapt the 2nd gen 6 speed up to the 3.4
  7. Jun 7, 2017 at 1:33 PM
    Trett19
    Yeah that's what I was worried about but if it is good enough to sustain the upgrades then I won't worry about it
  8. Jun 7, 2017 at 1:56 PM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    I think Marlin Crawler also makes some pretty bling billet shift forks for the R series transmissions.. they are pricey, but if you like it....
  9. Jun 7, 2017 at 1:59 PM
    eon_blue
    Azusa, CA
    Check out URDs website. They have several performance clutches and upgrades for the manual trans to make it better suited for added power.
    Trett19[OP] likes this.
  10. Jun 7, 2017 at 2:01 PM
    eon_blue
    Azusa, CA
    FWIW I have the TRD supercharger and URD 7th injector kit (only upgrade I've done to it) and the stock 5speed manual with a stock clutch. No issues with mine yet, though I suspect the clutch's lifespan will be shortened a bit. If you don't drive it like you stole it all the time then you'll be okay.
  11. Jun 7, 2017 at 7:08 PM
    Trett19
    I already have the stage III picked out. Just waiting on $$$ :D
    eon_blue[QUOTED] likes this.
