Manual transmission whine in 1st gear
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AKGSD, Apr 3, 2019.
  1. Apr 3, 2019 at 7:28 AM
    AKGSD
    AKGSD [OP] Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    I’ve noticed a gear whine (that is loud enough i initially thought it was the engine fan) in first gear, thats louder with more RPM. Sounds similar to the normal gear whine you get in reverse in almost any car. Doesn’t happen in 2-6. I’ve had a few stick shifts and none made whining noises like that in forward gears.
    Crawled under the truck, All fluids are level
    Took it to the dealer and they said they didn’t hear it
    (I’ve also got the dreaded diff howl, for which they want the toyota engineers to look at)
    I’ve also noticed the gear selector is super noisy, can hear it with the windows down or sometimes from the rear as i row through the first few gears
    Anyhow, is this stuff normal for the tacoma stick shift?
  2. Apr 3, 2019 at 7:42 AM
    SContiVT
    SContiVT Back in a Toyota
    Central Vermont
    2010 Tundra Rk Wr/2023 WRX/2023 Ford Exp
    :annoyed:
    https://www.tacomaworld.com/threads/6-speed-mt-loud-in-first-two-gears.529875/
    Most likely straight cut gears for 1st (stronger gears are straight cut, like reverse). See if you can find another 6MT and compare.
    As for shifter noise, you are literally shifting directly connected to the transmission. Sound is going to resonate through the lever, and you're going to hear the gear changes. As long as it's smooth and not a crunch, you're fine.
    tonered and trackdaybro like this.
  3. Apr 3, 2019 at 8:04 AM
    trackdaybro
    trackdaybro Well-Known Member
    Exactly this. You notice the whine in bikes as well. First gear straight cut to handle all the torques.
    tonered likes this.
  4. Apr 3, 2019 at 8:09 AM
    AKGSD
    Joe
    Alaska
    Haha apologies, i swear i searched for it!!!
    I’ve had other manual transmissioned vehicles that didn’t whine like this, but straight cut gears would do it!
    & Same with the shifter noise — My BMWs didnt do it, though of course those are more premium — but neither did my 91 silverado, and that transmission was rather.... agricultural. If thats just how these are that’s fine, i just wanted to make sure there wasn’t something wrong with mine.
    Thanks for the quick replies
    SContiVT likes this.
  5. Apr 3, 2019 at 8:15 AM
    NickleCityTaco
    NickleCityTaco Well-Known Member
    Western New York
    16 Acess SP 6MT
    stuff and things
    As the other member mentioned 100% normal. Personally I love the sound :D
    TRD4X4TOY, tonered and Tacoma1818 like this.
  6. Apr 3, 2019 at 8:16 AM
    SContiVT
    Central Vermont
    :cheers:No problem, you've obviously never heard the musical 5MT transmission in the 2005+ Legacy GT. 1st and 2nd were straight-ish cut gears, and they wined like a Short Track race car transmission on heavy acceleration...:burnrubber:
  7. Apr 3, 2019 at 8:39 AM
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
    Though not straight-cut, the tooth pitch is probably more of a hybrid between straight cut & helical... e.g. a Muncie M22.
  8. Apr 3, 2019 at 8:39 AM
    SContiVT
    Central Vermont
    :hattip:Was trying to give a simple explanation lol
    Paul631[QUOTED] likes this.
  9. Apr 3, 2019 at 8:44 AM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    Weird. Mine doesn’t whine dammit. Taking it to the dealer - they better not tell me it’s normal.
    :anonymous:
  10. Apr 3, 2019 at 10:29 AM
    That_Guy_Gray
    That_Guy_Gray Active Member
    Grayson
    2016 MGM Tacoma TRD Off-Road M/T
    I've got the same thing going on. As others have said it is completely normal due to the straight cut for 1st. Nothing to be worried about!
    As for the diff howl, I have been lucky not to have that issue.
  11. Apr 3, 2019 at 10:35 AM
    BlakeM
    BlakeM Well-Known Member
    Blake
    Gonzales, LA
    2023 T4R.SR5.4WD.OMG.LOL.WTF
    Same here. If mine does this, I’ve never noticed it.
  12. Apr 3, 2019 at 10:47 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Agreed, if you want a really noisy Tacoma along with road noise get a 1st Gen
    2001 4x4 likes this.
  13. Apr 3, 2019 at 11:44 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Same here. When I hear it, it makes me think of a gated MT.
