Manual Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Johnny2525, Apr 20, 2017.
  1. Apr 20, 2017 at 12:47 PM
    Johnny2525
    Johnny2525 [OP] Well-Known Member
    California
    '14 TRD OFF ROAD DCSB
    ICON stage 3 suspension kit, Amp Research retractable steps, LED interior lighting, headlights, fog lights, MB wheels, FlowMaster exhaust. Rigid Industries back up lights, aFe Cold Air Intake with URD MAF sensor Calibrator
    Anyone know about how much it would cost to throw my auto trans in a hole and install a manual trans?
  2. Apr 20, 2017 at 1:07 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    The conversion can be done but seriously it's a pretty big project. So IMO it's not worth it... *unless* you are committed to keeping your truck and you have a chunk of change to spend.
    I'd suggest you put that money toward another rig that has the configuration you want. Sorry I don't have a real answer to your question about cost.
  3. Apr 20, 2017 at 1:09 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    You would need an ecu from a manual as well if iirc..
  4. Apr 20, 2017 at 2:39 PM
    Johnny2525
    California
    The real problem here is just that I hate the way the auto shifts. You gotta really put your foot down hard for it to downshift. Then all of sudden you're tach is reading 5000...frustrating
  5. Apr 20, 2017 at 4:38 PM
    THROTTLE231
    THROTTLE231 Well-Known Member
    Shane
    High Dez,Comifornia
    2011MGMDCSB6MT With Not So So Cool Shit...
    I LIKE BEER....
    MTFTW...:burnrubber:
  6. Apr 20, 2017 at 4:47 PM
    dipstiktaco
    dipstiktaco Well-Known Member
    canada
    2006 TRD off road access cab auto URD supercharged
    My trans is starting too act odd now that I added the supercharger and I was contemplating doing this swap as well. I'm curious if the shafts and mounts are the same.
  7. Apr 21, 2017 at 11:59 AM
    monkiballz
    monkiballz New Member
    Given that this project would be best done using pieces of a parts mule (maybe a crashed/rolled MT), the specific parts needed should all be included.
  8. Apr 21, 2017 at 12:00 PM
    monkiballz
    Well.. cost of a crashed truck with MT, plus the cost of EPA coming after you for enviro-damage caused by the chemicals leeching out of the AT that you buried in that hole.
    That and probably also the value of your time or whatever somebody else charges to do the labor for you.
  9. Apr 21, 2017 at 4:57 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    LC Engineering has an adapter for an automatic GM transmission. Then with a controller, you could shift it however you want.
  10. Apr 21, 2017 at 4:58 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Manually shift.
    If you were to purchase a UCON, when it becomes available for general purchase, it can change the shifting a little.
  11. Apr 24, 2017 at 3:24 PM
    dipstiktaco
    canada
    It doesn't change the shift pattern one bit.
