Manual transmission
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mel2020, Sep 29, 2023.
  1. Sep 29, 2023 at 11:21 AM
    mel2020
    mel2020 [OP] Member
    2020 Tacoma TRD off road 4x4
    2020 Toyota Tacoma manual. Accidentally shifted from 5th to 2nd going 45mph. Was shooting for 4th gear. Made a skid tire sound in a matter of seconds, depressed the clutch right away. Wondering if I damaged anything.
  2. Sep 29, 2023 at 11:31 AM
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    It is my understanding neither the engines in the 3G Tacoma (2TR-FE and 2GR-FKS) are not interference engines, so there is a good chance the only thing you damaged was your ego. :)
    mtip and 6MTPro like this.
  3. Sep 29, 2023 at 11:47 AM
    terryhutchinson
    terryhutchinson Well-Known Member
    Terry
    2023 Tacoma TRD Off Road
    Aside from burning a little life off your clutch, if you damaged anything you would know it already. If it shifts normally now, you are fine. Were you trying to speed shift? I have to think it felt and sounded really off as the syncros tried to catch up the the rev difference. Personally I find these trucks are happiest when my shifts are deliberate and relatively slow.
  4. Sep 29, 2023 at 11:51 AM
    mel2020
    mel2020 [OP] Member
    I was down shifting to 4th cuz traffic was slowing down a little. Accidentally pop it into 2nd, I still had my foot on the clutch, was able to reengage after less than a second tire skid.
  5. Sep 29, 2023 at 11:55 AM
    Horseshoez
    Dale
    Maryland
    Many of my previous cars had interference engines and in communities associated with those vehicles, this type of a shift is called, the "Money Shift". Why? Piston to valve contact is almost assured which in turn requires pulling the head(s) and reconditioning the valve train.
    vivid02 and mabepossibly like this.
  6. Sep 29, 2023 at 12:01 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    You are fine man. Now if you do this 20 more times, something might break.
    Tacosha, 513Mugsy, Irons and 2 others like this.
  7. Sep 29, 2023 at 12:32 PM
    mabepossibly
    mabepossibly I know enough to make an ass of myself
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Skids, Sliders, Lights
    I believe the term originated with the early 2000s Celica GT-S where it was super easy to catch 2nd gear when trying to go 3 > 4 .
  8. Sep 29, 2023 at 12:33 PM
    Horseshoez
    Dale
    Maryland
    That might be when the phrase caught on, but I'm pretty sure I remember it from the 1980s.
  9. Sep 29, 2023 at 12:42 PM
    kona61
    kona61 Well-Known Member
    J
    LR 2022 Tacoma TRD OR
    RCI Skids
    I highly doubt the 2GR-FKS is a non-interference motor. Most cars that are non-interference have quite low compression ratios like 8-10:1, the tacoma has a 11.8:1 so I would assume it is interference.
    Also, 2GR-FEs are interference motors.
  10. Sep 29, 2023 at 12:45 PM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    Interference or not has nothing to do with over “revving” an engine.
    That said 45mph in 2nd sounds fine
    gudujarlson, OZ TRD and df41590 like this.
  11. Sep 29, 2023 at 2:40 PM
    mel2020
    mel2020 [OP] Member
    Good info, appreciate you all!! Taco on!!!
    Junkhead likes this.
  12. Sep 29, 2023 at 7:27 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    these trucks will do nearly 75 mph in 2nd gear. unless you were going faster than that then there was no chance you hurt anything. these engines are good up to about 7500rpm then the lash adjusters collapse and you start throwing rocker arms. which in most cases isnt the end of the world.
  13. Sep 29, 2023 at 9:25 PM
    NewMexiMan
    NewMexiMan Well-Known Member
    2016 SR 5 Speed
    I did the same a couple years ago, but going closer to 60 or 65. Interesting sensation. Everything still works fine.
  14. Sep 29, 2023 at 9:29 PM
    Taco47
    Taco47 Well-Known Member
    Norcal
    2016 2TR 5-Speed
    I have done this before and you’ll start noticing all the subtle noises through the rpm ranges thinking does this sound the same. You’ll be fine though.
  15. Sep 29, 2023 at 9:58 PM
    RicerRabbit
    RicerRabbit Well-Known Ricer
    '22 White TRD Off-Road DCSB Manual | '03 Lancer Evolution
    Itz JDM tyte, yo!
    You should be fine
  16. Sep 29, 2023 at 10:04 PM
    Irons
    Irons Outlaw Prospector
    NW Michigan USA
    '22 TRD Sport AC MT Army Green
    TRD lift, Exhaust & CAI
    She's a goner dude, sorry. Can I have your wheels?
  17. Sep 29, 2023 at 10:40 PM
    TacoTuesday1
    FL
    things can generally break when they are over-reved
  18. Sep 30, 2023 at 12:12 AM
    Neal4x4
    Neal4x4 Well-Known Member
    Southern California
    Truck.
    Truck is totaled. Time for a bicycle.
    But seriously you are fine.
  19. Sep 30, 2023 at 4:40 AM
    BillyE
    BillyE Well-Known Member
    You’d know if you broke it
  20. Sep 30, 2023 at 5:14 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    And he broke it
