Manual Transmissions Low on fluid?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Roughontacos, Jan 19, 2016.
MTF levels
  1. didn't check
    1 vote(s)
    33.3%
  2. They were low
    0 vote(s)
    0.0%
  3. They were good
    2 vote(s)
    66.7%
  1. Jan 19, 2016 at 11:07 PM
    Roughontacos
    Roughontacos [OP] New Member
    RY
    TRD OR AC MAN
    Hey guys I'm new here, I'v been creeping though. Has anyone checked their MTF levels? After reading about low factory levels on the automatics it has me wondering. Seeing dry U joints on my rig left me even more skeptical.
  2. Jan 19, 2016 at 11:14 PM
    moweryaviation
    moweryaviation Life begins, where the pavement ends!
    Dixon, California
    2011 Tacoma, 4x4, manual, access cab
    3" (or so) lift, Dakar leafs & 886 up front.OME Sport shocks, Pro-Crap struts up front, SPC UCA's, Brute Force Fab front and rear, super winch 9500, KM2 255/85, Holly Brakes, SS Brake lines, DOT 4 Fluid, Custom bed system, independent bed LEDs, black head lights, Mag Grey grill, DIY 50$ roof tie down system, On Board Air, DIY spare tire swing arm, DIY painted rims, Energy bushings, camp lights, independant power system, BAMF Bolt on Sliders, DIY IFS Skid, DIY Roof Rack, Bad ass additude, one old smart dog, one young dumb dog, and one hot Burnett!
    My pops showed me me take the plug out when it is cold, stick your finger in and if you touch oil, your good to go. Dry U-joint? You might not be able to see the grease, until you service it and see grease come out of the bearing on your first pump.
  3. Jan 19, 2016 at 11:24 PM
    Roughontacos
    RY
    TRD OR AC MAN
    That simple eh? For the Ujoints i filled them up today with mobil 1 synthetic grease and it took countless pumps before they filled up and purged a smidge of black grease before seeing my grease
  4. Jan 19, 2016 at 11:27 PM
    moweryaviation
    Dixon, California
    I get cought all the time (I'm a aircraft mechanic) in a "multi-bearing-single nipple" situation looking in one spot for the grease to come out. Ill pump and pump, then a glob a grease that I was not seeing grows larger and larger. Are you sure it just did not come out one of the other 3 bearings on that U joint?
  5. Jan 19, 2016 at 11:38 PM
    Roughontacos
    RY
    TRD OR AC MAN
    Im rather certain all 5 joints did not deceive me. Seeing as how i could spin the front drive shaft, the 3 bearings being within 2 inchs of the zerk and having my face be within a foot of viewing it
  6. Jan 19, 2016 at 11:44 PM
    moweryaviation
    Dixon, California
    LOL, now that I have that visual, that was a dumb comment I made! Sounds like they needed it.
  7. Jan 20, 2016 at 6:37 AM
    forty2
    forty2 Well-Known Member
    Cascadia
    2016 DCSB OR 6MT
    It's been pretty well documented that the u-joints come with assembly grease only. Greasing them for the first time requires so many pumps because the zerk and fill cavity are bone dry from the factory.
    I haven't heard anything about low fluid in the manual. Mine was fine when I checked all fluids a week off the lot.
