manual versus auto drive shaft lengths?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NYCO, Jan 3, 2013.
  1. Apr 4, 2015 at 9:00 AM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Just dealing with this one. I have a 2009 DCSB and the difference is the length of the front drive shaft. The spare that I am trying to swap in was a spare for a MT race truck. Their is about an inch of difference in the front drive shaft. The MT driveshaft is about 1" longer. Good thing? I can cut out an inch instead of a new tube. :)
  2. Jul 21, 2016 at 5:42 AM
    Wolftaco
    Wolftaco Well-Known Member
    Luke
    Philadelphia, PA
    06 Overland Build
    Old Man Emu, Leer 100cc, Blacked Out Billet Grill, ARB Bumber, Warn M8000-s winch with under hood solenoid relocation, Stubbs HD Standard Sliders, diff breather
    Is there compatibility between engine sizes? In other words I know AC and DCSB with same transmission are compatible, but would that also hold true for 4cylinder and 6cylinder trucks with the same body and transmission?
  3. Jul 21, 2016 at 8:35 AM
    NYCO
    NYCO [OP] go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
  4. Jul 22, 2016 at 10:03 AM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    I doubt it, I'm sure the drive shafts are different lengths. And the autos are different engine to engine and the manuals are different engine to engine
  5. Feb 20, 2023 at 4:04 PM
    surfertaco
    surfertaco Active Member
    Andy
    Accesscab Off-road 6spd
    Bumping Avery important thread because I just found out the hard way that the from portion is indeed longer on the manual 2007 4x4 OR than the shorter front portion on - 2011 Toyota 4x4 OR automatic
    my back and body hurts from learning the hard way
  6. Feb 22, 2023 at 4:03 PM
    dkensk
    dkensk Well-Known Member
    Speaking strictly from my research on 2nd gen 4wd drive shafts
    V6 6speed front drive shaft is unique to v6 6speed
    V6 auto, 4cyl auto & 4cyl manual use the same front drive shaft. Which is 1" longer than 6speed
    Following the same trend on the rear shafts.
    Using a DCSB as an example:
    The 6speed rear drive shaft will be 1" longer (distance between steady bearing and Transmission/tcase out put shaft)
    A V6 auto, 4cyl auto, & 4cyl manual will all have same distance between tcase output and steady bearing.
  7. Feb 22, 2023 at 4:07 PM
    surfertaco
    Andy
    I almost pushed my carrier bearing to make it work but I opted not do so something stupid like that and go back to the stock.
  8. Feb 22, 2023 at 4:11 PM
    dkensk
    So many variations, it's best to try find the exact same donor as your chassis.
  9. Feb 27, 2023 at 6:17 PM
    NYCO
    bOb
    Colorado
    dents & scratches
    or just get a one piece made :)
