Manual Wheeling
Discussion in 'Off-Roading & Trails' started by DanGer, May 1, 2009.
  1. May 1, 2009 at 3:26 PM
    DanGer
    DanGer [OP] Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Ok I know this question has all sorts of ways to be misinterpreted so I am going to try and fully explain.
    I normally wheel in 4wL because I have a manual. Even going "fast" (relative to the terrain I am on), dogs first gear in 4wH. Now here is my question. Now picture this: I am coming up on a gentle, easy terrain down hill slope and I want to drift in neutral. As in same quality as a maintained dirt road==no rocks or anything of danger.
    My question is this:
    Should I shift out of 4wL before I coast in neutral, or is neutral the same in 4wL as it is in 4wH/2W?
  2. May 1, 2009 at 3:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You can coast in low range.
  3. May 1, 2009 at 3:31 PM
    DanGer
    ok just wondering because I would stop, shift out of 4wL then coast in high, then if I approached an obstacle, i would stop and shift back into the proper gears
  4. May 1, 2009 at 4:16 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    Ask people who wheel with me, constantly in 4LO. You can coast as much as you want, or just throw it in 5th.
  5. May 1, 2009 at 4:18 PM
    DanGer
    alright thanks for the response!!
  6. May 2, 2009 at 4:35 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    X2
    4lo isn't any different than 4hi or 2wd in terms of drivability/changing gears.
    Use the gears as necessary to produce the speeds you want whether you're on the gas or coasting (engine braking).
  7. May 13, 2009 at 6:24 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    There is a max speed in 4L. Somewhere around 45 MPH. Probably worth checking your manual.
  8. May 13, 2009 at 6:46 PM
    johnecon2001
    Phoenix, AZ
    That's gear limited though. Physically impossible to go faster.
  9. May 13, 2009 at 7:07 PM
    Isthatahemi
    TRD OFF ROAD
    The discussion was about coasting in neutral, and you could easily exceed the rated limit on a long downhill. The speed is probably printed for that exact reason. The output shaft on the transmission, and the internal chain on the T-case were only designed to spin so quickly. At the max rated speed the output to the T-case is spinning over 6000 RPMS.....in gear or out, clutch in or out....(think output shaft bearing wear / heat.)
  10. May 14, 2009 at 6:41 PM
    stikkimikki87
    stikkimikki87 Well-Known Member
    Pensacola FL
    d44, 37s, all 4 wheels turn!
    uhh...everything? lol
    i read on ttora that its better to coast in gear and not with the clutch in or neutral to help take some load off of the clutch....not sure that i buy that, but the guy who posted it was a pretty hardcore wheeler so maybe he knows his stuff. i always coast in N and havent had any problems but i dont ever go over 10mph (if that) in 4lo....i wheel in 2wd and dont put it in 4wd unless im stuck and want to get out
  11. May 14, 2009 at 7:56 PM
    frobuster
    frobuster Well-Known Member
    Anacortes WA
    '07 access cab SR5 4x4
    juniper scratches, rock dents.
    isthatahemi sounds like he knows his stuff. I was told the same thing by a master mechanic. My question to him was "do I go 10mph in 1st gear high range, or 3rd gear Lo range"? his response....."Where do you want the heat" ? big tranny, or lill t-case.
  12. May 14, 2009 at 8:04 PM
    stikkimikki87
    Pensacola FL
    ehh, i dont buyt that at all... transfer cases are generally very strong. Honestly, i wouldnt worry too much about it man, just do whatever feels right for you and have fun.
  13. May 15, 2009 at 12:31 AM
    Janster
    Jandy
    Lancaster, PA
    Why put it in neutral at all?
    When I'm wheeling, I never put it in neutral ever. Regardless if I'm in hi or lo range. It's always in gear. I always let the engine keep my speed where I want/need it to be whether I'm on the gas or allowing the engine to slow me down.
  14. May 15, 2009 at 10:14 AM
    frobuster
    Anacortes WA
    yeah, the kind of trails I run, I'm usually in 4lo, and keep bout 5-15mph. If i'm going over 15 or so, I might as well be in 2wd. I can also say the same thing; uh...what situation calls for "Georgia Overdrive" downhill anyway???
  15. May 15, 2009 at 3:32 PM
    Isthatahemi
    TRD OFF ROAD
    So are diesel engines, but not if spin them fast....
