Manually shifting an Automatic
Discussion in '2nd Gen. Tacomas (2005-2015)' started by teneighty, Aug 1, 2013.
  1. Aug 2, 2013 at 10:15 AM
    #41
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    I do it all the time. Mostly on down shifts when coming to a stop or so I can make a quicker passing maneuver. I never take it to 1 just because of the horrible lunge it throws me for.
  2. Aug 2, 2013 at 10:17 AM
    #42
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Don't worry guys. Don't listen to Bill and Chris, the two guys who have more experience than the rest of us combined, squared and shot into a supernova to go super saiyan 4...
  3. Aug 2, 2013 at 11:13 AM
    #43
    teneighty
    teneighty [OP] I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    Very true... I hope to keep this truck for a long time. Or at least until 2014 when the diesel comes out ;)... But at the same time I need to stop obsessing over that little crap!! Haha I do it with everything too not just the truck... I'll have to start being less "OCD".
    I'm going to go open my rear slider 100 times just to help e get over it :eek:
    And I'm going to drive it home like its a manual bitches!!
  4. Aug 2, 2013 at 12:24 PM
    #44
    Mapcinq
    Mapcinq Well-Known Member
    Ontario, Canada
    Im gonna put my truck in 3 and drive to the cottage and see what happens.
  5. Aug 2, 2013 at 12:36 PM
    #45
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Manual selection of a gear will not cause any extra wear, it won't cause damage, and it won't shorten the lifespan of any of the transmission components. The transmission will not allow you to shift into an incompatable direction, or gear range.
    According to the transmission intructor from the tech school I attended: Manual selection of a gear prevents hunting, and locks in an extra clutch band. Manual selection of a gear was primarily intended for towing, and it also increases engine braking. He also said to NEVER tow in overdrive. The force the trailer puts on the drivetrain destroys planetary gears.
  6. Aug 2, 2013 at 12:51 PM
    #46
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    The highest gear it will shift up to is 3
    That is all that will happen
  7. Aug 2, 2013 at 2:55 PM
    #47
    GTOJim
    GTOJim Well-Known Member
    Jim
    SF Bay Area
    2013 PreRunner TRD OffRoad V6
    I had a GM turbo 400 trans, they are pretty bullet proof.
    I downshifted into 2nd a lot for engine braking, it's a 3 speed. The bands for 2nd gear wore out, downshifting was like putting it in neutral, up-shifts were unchanged.
    Accelerating from a stop the trans shifted perfect it just lost the ability to use engine braking in 2nd gear so for me it wasn't a big deal.
    I realize it's not the same transmission but I think about when I downshift my auto Taco, sometimes wonder if the same thing could happen with this transmission.
  8. Aug 2, 2013 at 3:31 PM
    #48
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    I pop it out of OD on long grades if I see traffic forcing a slow or stop ahead.
    I don't pull it down manually under normal driving.
  9. Aug 2, 2013 at 3:37 PM
    #49
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Totaly different trannys. Ive downshifted mine countless times. Many times, going into first at 30 moh, blipping the throttle to get it to "catch", etc. The only way I can see breaking these trannys, is by getting on the highway, and throwing it in park. .......or Reverse......
  10. Aug 2, 2013 at 3:40 PM
    #50
    Germ
    Germ Master Navigator/Zipper Operator
    Arizona
    2013 TRD OR DCSB
    Not true. First or second day I had my truck and was getting used to it I accidentally shifted up past D into reverse. Nothing happened. Felt like I put it into neutral.
  11. Aug 2, 2013 at 3:48 PM
    #51
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good to know. I was guessing, as I havent tried to destroy the tranny.
  12. Aug 2, 2013 at 3:50 PM
    #52
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Only auto tranny I have seen grenade, in recent memory, was in a friends RX-8. We were crusing along at about 80, and for some reason, she was fucking around "dancing" to some shit song on the radio, and she hit the shifter into Park. The car made a "BOOM" sound, some clicking, and grinding sounds, and I noticed there was no more forward propulsion, despite reving the engine.
  13. Aug 2, 2013 at 3:52 PM
    #53
    Germ
    Arizona
    2013 TRD OR DCSB
    I definitely wasn't trying and most certainly shit my pants when I did it. But a good deal of scientific discoveries happen by accident so score 1 for science :notsure:
  14. Aug 2, 2013 at 4:05 PM
    #54
    Rich91710
    Rich
    Los Angeles
    08 Base
    Not sure how the Toyota trans is put together, but in Park, there is an actual parking pawl that is moved into place to lock the output shaft, while disengaging the input (neutral).
    That is a piece of hardware, and if it is connected to the shift selector (it would have to be, since it operates with the truck and ignition off), then slamming into Park while moving will cause damage.
    Reverse, and all of the forward gears, are controlled by the valve body, which is controlled by the transmission control module... so the truck could lock out reverse, and the lower gears electronically based on speed.
  15. Aug 2, 2013 at 6:28 PM
    #55
    teneighty
    I've seen it happen a few times an it just ticks as you come to a stop. I can't remember what make of vehicle it was......
    No damage.
  16. Aug 2, 2013 at 6:40 PM
    #56
    jsi
    jsi Well-Known Member
    native earthling
    Kind of reminds me of thread on another forum where the OP was worried about using his power steering in a parking lot when the vehicle was stopped. If shifting the thing would cause problems they wouldn't have given you the silly gear shift. I'll shift manually if the mood strikes me. I live in mountainous country and will use lower gears coming down steep grades. And, I lock it into a gear so it won't hunt around when climbing a grade. I've done this with every car I've owned without a problem.
    Oh and I'll happily turn the steering wheel with the truck stopped in a parking lot. Isn't that the point of power steering? And if something breaks or wears out because I use it, so what, fix or replace it.
  17. Aug 28, 2013 at 8:18 PM
    #57
    gearcruncher
    Canadain bumper technician
    When a vehicle is at highway speeds and you accidently select park , the parking pawl will try to lock into the rear planetary carrier or Park position but because the vehicle is moving so quickly , the parking pawl will ratchet and you will hear klik klik klik until the vehicle slows down to a point where the parking pawl will hold .
    We use to select park at highway speeds on Fords and Dodge products to free up a sticking transmission govenor . Worked like a charm
  18. Aug 28, 2013 at 9:15 PM
    #58
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I've accidentally put it in Reverse on my way to Park while I was still rolling (low speed, slowing to a stop) and this is what happened.
    Now my parents Volo when I was real young didn't quite do the same when I accidentally kicked it into Park while my mom was driving.
  19. Aug 28, 2013 at 9:18 PM
    #59
    Who Dat Popcorn
    Who Dat Popcorn Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    Been doing it since it had 10xxx miles, and now I have 73xxx miles with no issues.
