Manually shifting your auto
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EricT, Aug 24, 2009.
  1. Aug 25, 2009 at 4:13 PM
    #61
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    there is jake brakes in the engine, we combine that with compression braking which is downshifting to bring up the rpm's. I dont drive too many dump trucks at work anymore, still have the c.d.l. though.
  2. Aug 25, 2009 at 4:17 PM
    #62
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    I downshift my auto transmission when going downhill. I've been doing it with many different vehicles of the years. A doubt that a downshift into 3rd is going to hurt your transmission. It will haul 5000lbs after all :)
    Cheers.
  3. Aug 25, 2009 at 4:29 PM
    #63
    Tacoyota
    08 4wd
    Yea EricT (thread starter) says he puts it in third and notices it will downshift but not upshift, thats what its for, the ability to select,... just dont race it to redline, why misuse it.(dont think he was doing that though)
    also the part about holding it in a gear then upshifting, like above... if you are towing and you arent going to the redline, holding it gear longer just raises rpm at cost to fuel efficiency. The next shift up will land you at a higher rpm so you can maintain speed on a grade.
    Once again i dont know your redline on the v6 so if its 5000, you would never really need to go to 4000 rpm, if you did i doubt it would do any harm , just consider the grade length, grade%, and how much you actually are towing.
