Many products Now Back In Stock @ MarlinCrawler.com!
Discussion in 'Marlin Crawler' started by Marlin Crawler, Mar 20, 2025.
  1. Mar 20, 2025 at 11:06 AM
    Marlin Crawler
    Marlin Crawler [OP] Well-Known Member Vendor
    Fresno, CA
    The following great products are now back in stock!
    4.70:1 Low Range Gear Kits
    • 21- & 21-spline
    • Most successful, decorated, technically advanced and longest lasting low range gear sets on the market
    • Durability proven with the most podium finishes in competition events with zero failures
    • Made out of Chromoly in Japan by Toyota's own gear cutter
    2.28:1 Turbo Input Gear
    • Designed around our Total-Spline technology
    • Strongest gear drive t/case input ever made
    3.12:1 80-series Land Cruiser & Lexus LX Gear Kit
    • Provides a 25% reduction
    • Increases low range torque for heavy Land Cruiser builds, makes the vehicle feel lighter and more nimble
    • Increases engine compression braking, requiring noticibly less braking on descents
    Axle & Knuckle Service Kits
    • High quality Japanese sourced parts
    • KOYO and Nachi wheel and knuckle bearings
    • 1979-85 Pickup/4Runner Axles & Knuckles
    • 1976-89 Land Cruiser Axles & Knuckles
    • Our industry-first EcoSeal Heavy Duty axle seals available
    Wheel Bearing Kits
    • Front and Rear Kits available
    • Available EcoSeal Heavy Duty Rear Axle Seal
    • Pickups, 4Runners, Land Cruisers
    • IFS Bearing Kits also available
    80-series Land Cruiser and Lexus LX Steering Upgrade Kits
    • Upgrade to stronger DOM steering links with new OE Japanese-made tie rod ends!
    • Proper, factory-style steering stabilizer mount instead of cheap "u-bolt" designs
    • Japanese ends, USA-made DOM tubing
    Long Spline Drive Shaft Kit
    • Upgrade to a full 8" of drive line travel
    • Really nice kit with High Quality, Japanese-made extended length slip joint
    • Japanese-made High Quality U-Joints
    High Quality Japanese U-Joints
    • We only offer High Quality Made In Japan U-Joints
    • Proper strength and quality that prevents U-Joint faliure out on the trail
    • Much higher quality than over-the-counter auto part store offerings
    • Great to carry as a trail spare
    LCA Frame Brace Kit - Improved design!
    • We have improved the design for 2005-2015 2nd gen Tacoma applications!
    • Now a precision fit over factory Cam Tabs without having to choose which gap to average
    • If you've been eyeing this kit, now's a great time!
    MarlinCrawle.com
