Map, Dome and License Plate LEDs Installed
Discussion in 'Lighting' started by BAP_29, Sep 2, 2011.
  1. Sep 2, 2011 at 6:48 PM
    BAP_29
    BAP_29 [OP] Well-Known Member
    Ben
    North Carolina
    05 Prerunner DC TRD Sport
    Bilstein 5100s at 2.5" and Toytec 1.5" AAL Eagle Alloy 063 Wheels on 285/60/18 Cooper Zeon LTZ tires Alpine iDA-X305 Head Unit MB Quart DKD 116 Discus-Line 6.5" Front Speakers (Baffles by Marv) Alpine 6-Disk CD Changer Toyota All-Weather Floor Mats Kobalt Low-Profile Toolbox 13" Wicked Flow Muffler w/ Chrome Tip
    Installed LEDs in the dome, map, and license plate lights. Turned out pretty good I'd say. Ordered them from superbrightleds.com
  2. Oct 1, 2011 at 11:43 AM
    NastyNava
    NastyNava Member
    Jared
    San Diego, CA
    07 PreRunner murdered out
    Black Westin Bull bar, black Westin side steps, 5%window tint all around(until CHP made me take it off the front!!), 2.5" ready lift in the front, 2" block lift in rear, Rollbak Retractable Tonneau cover, Black JDM head/tail lights, HID head/fog lights, black badged all around, 20" UltraSport black wheels on 33" Pirelli tires. Interior---JL Audio Stealthbox holding 2 JL W1V2 10" subs, 2 500W amps to power the subs and the JL C5 door speakers up front.
    Are the license plate LED's the same size as map and dome light led's?
  3. Oct 1, 2011 at 1:47 PM
    LifeIsGood169
    LifeIsGood169 Well-Known Member
    Greg
    Philadelphia
    03 Tacoma XtraCab 2.7L 5spd
    Chime Mod Kenwood Headunit Greased all Zerks, locks, and bushings Reverse Flood Lights Extang Cover Weather stripped tailgate Burner Fog Lights Toggle Switches in Dash
    The license plate lights don't seem to be throwing out a lot of light. But the interior ones look crazy bright.
    Map light & License plate: 168
    Dome light: DE3022
    The dome and map light LED mod will probably have to be different. But the Map light and license plate ones should be similar. What parts did you use?
    Do you know if you can put maplights into the Tacoma Xtra cab? I only have a dome light. I took off the plastic cover above the rear view mirror. It looks like I've got all the wiring ready to go. I bet there is an easy way to add OEM map lights, but I haven't seen a good tutorial (after searching). Any advice?
  4. Oct 1, 2011 at 2:22 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    Just find donor^
    direct bolt in..direct wire in
  5. Oct 3, 2011 at 5:03 PM
    Doc Foster
    Doc Foster Well-Known Member
    Doc Foster
    Fredneck, MD
    2012 4X4 DC/LB Sport
    Slightly taller 265/70/17 ARE Z series cap.
    Can you provide some details on the exact bulbs and install?
    Looks cool. Thanks!
  6. Oct 3, 2011 at 7:32 PM
    BAP_29
    Ben
    North Carolina
    Map Lights - 168 style - WLED-x5 LED Wide Angle LED bulb (need 2 bulbs)
    Dome Light - 4410-x9 LED Festoon bulb (need 1 bulb)
    License Plate - 168 style - WLED-x-x LED bulb (120 degrees viewing) (need 2 bulbs)
    Install was simple:
    Pop off the dome light cover and just snap in the bulb. Replace cover.
    Map Lights - Pop off the lens covers and pry out the bulbs using a flat head screw driver. Push new bulbs into place, Replace lens covers
    License Plate - Unscrew the black housings and twist out the old bulb. twist in the new bulb. Replace housings.
  7. Oct 3, 2011 at 7:33 PM
    BAP_29
    Ben
    North Carolina
    The map and license plate are both 168 Style
    Dome Light is a festoon type bulb. See above post
  8. Oct 12, 2011 at 5:20 PM
    nsb808
    nsb808 Active Member
    Hey, i went to the website, but it's so confusing. Can you please provide the links or navigation to each different type of bulb you used?
  9. Oct 12, 2011 at 5:41 PM
    nsb808
    Wut color is your license plate bulbs?
  10. Oct 12, 2011 at 6:04 PM
    BAP_29
    Ben
    North Carolina
  11. Oct 12, 2011 at 6:04 PM
    BAP_29
    Ben
    North Carolina
  12. Oct 12, 2011 at 7:13 PM
    nsb808
    The light blue or dark blue? Thank you for your help!
  13. Oct 13, 2011 at 8:56 AM
    BAP_29
    Ben
    North Carolina
    light blue, it looks like 6000k hids in person. The dark blue square looks like royal blue in person
  14. Oct 13, 2011 at 8:58 AM
    uscg2008
    uscg2008 Well-Known Member
    coby
    San Diego, CA originally from Huntington Beach, CA
    06 trd sr5 four door 4x4
    CLICK ON SIGNATURE>>>>
    The led I have in my dome light have had some of them go out how do u like urs
  15. Oct 13, 2011 at 9:08 AM
    BAP_29
    Ben
    North Carolina
    I havnt had any trouble with mine. You must have a panel of leds in your dome light. The kind I have is just a bulb with leds inside of it. It looks almost identical to the stock bulb.
  16. Oct 16, 2011 at 10:30 AM
    uscg2008
    coby
    ya thats what i have right now. i think im gana change to the style that you have soon. i have had mine for like 2 yrs and its just now starting to lose lows of lights in the panel.
  17. Oct 16, 2011 at 10:34 AM
    w8n4mud
    w8n4mud I'm back.
    Albert
    Chula Vista, CA
    2019 Tacoma Off Road DCSB
    Stock. Purchased 2/17/19. Cement!
    Looks good. Another simple yet useful mod.
  18. Oct 24, 2011 at 12:56 AM
    nsb808
    Hey Bap,
    I just got my bulbs in. The dome light doesnt really fit evenly into the prongs, are yours like that too? Also, the license lights arent as bright as the stock, is yours that way too?
  19. Oct 24, 2011 at 1:13 AM
    nsb808
    I also had a question on the map lights, how did you fit the metal housing around the bulb? The hole in mine wasnt big enough to use that metal reflector.
  20. Oct 24, 2011 at 1:24 PM
    BAP_29
    Ben
    North Carolina
    Thats odd about the dome light, mine fit perfectly. It was the same size bulb as the stock one if I remember correctly. And yes the license plate lights dont appear to be as bright as stock, but they've since grown on me and seem suitable to me. My map lights pushed right up into the housings though. I dont know why your bulbs are causing you so much trouble.
