Map/Dome Light mod Q
Discussion in '2nd Gen. Tacomas (2005-2015)' started by snowgod06, May 7, 2010.
  1. May 7, 2010 at 2:08 PM
    snowgod06
    snowgod06 [OP] UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    Hey so im going the resistor route on this mod and was wondering how big is to big for a resistor? I have a 3ohm just laying around and i dont remember if anything over 1ohm will make the map lights dim when the dome is on. So if anyone knows which is the right one or if my 3ohm is ok, let me know. OR since i dont really use my maplights (i just turn the dome on) is their a way to do the mod so i dont have to use a diode/resistor? Im lazy and cheap so if i can go that route that would also be nice.
    thanks
  2. May 7, 2010 at 5:49 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    You don't need a diode/resistor. All you need to do is switch the wires in the plug and run an additional wire over to the dome light. Read through this thread. Post #191 on page 13 identifies how to do it without the diode. That's the way I did mine years ago.
    http://www.toyotanation.com/forum/showthread.php?t=91499
  3. May 7, 2010 at 6:16 PM
    planman
    planman Member
    Mississippi
    06 DC PreRunner SR5
    Fog light mod, DTRL mod, Undercover bed cap, Console mtd. Ipod,Console lock,maplight/ dome light mod, homelink receiver install
    Much easier to do without a resistor. Ten minutes tops is you've got your wires already made up.
  4. May 7, 2010 at 6:19 PM
    snowgod06
    Rob
    06 Access Cab
    AHHH thanks guys, Thats what i was looking for. Im just lazy and cheap and didnt want to hassle with much. But just switching the wires like i thought and the ground and BAM, SUPER THANKS
