Map light bulb removal?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonykarter, Feb 22, 2020.
  1. Feb 22, 2020 at 9:29 AM
    tonykarter
    tonykarter [OP] Crappie Savant
    Snuff Gully, Texas
    2018 DCSB 4x4 Sport 1993 4Runner SR5 4x4, 411,000 miles
    Pine tree air freshener
    When TF did I become such an inept, helpless person? I can't get the map light bulbs out. Did I not notice the onset of dementia or something? Is there a trick to getting them out? Mine are so recessed up in there that I can't even get a grip on them with hemostats/forceps/needle holders of various configurations. Help. You'd think a man could do something as easy as this without help:
    And tell me that you will come and visit me in the nursing home. At least up until the time I no longer recognize you, okay?
  2. Feb 22, 2020 at 9:31 AM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    Tape works great
    bluedevils9, sabotanker and jwctaco like this.
  3. Feb 22, 2020 at 9:34 AM
    OMGitsme
    Sold
    Just get packaging tape and fold it around bulb and pull it out.
  4. Feb 22, 2020 at 10:05 AM
    1988Mercedes
    1988Mercedes Well-Known Member
    CHARLES
    ARKANSAS
    2020 AG PRO MT
    Just pop down the entire console and the bulb socket just twist out. Console just pops down with a good pull.
    RPVTaco, Boyitz, Frsh2df and 3 others like this.
  5. Feb 22, 2020 at 10:18 AM
    tonykarter
    Snuff Gully, Texas
    GENIUS! Thanks! Yes, out of frustration I did just that. It's amazing what the right procedure and right tools do for simplifying auto repair. Once, I rebuilt a Triumph TR-6 transmission with only a Craftsman Christmas starter tool set I got back in the 7th grade. Yes, you can get those thick snap rings off the mainshaft with a couple of Craftsman screwdrivers. Eventually.
    Done. 'Preciate it everyone!
    tcjacado likes this.
  6. Feb 22, 2020 at 2:01 PM
    Tallgrass05
    Tallgrass05 Well-Known Member
    Loop a piece of tape around it, press it, and then pull. Worked like a charm when I replaced the stock bulbs with LEDs.
  7. Feb 22, 2020 at 2:06 PM
    Invid
    Invid Well-Known Member
    New Braunfels, Texas
    2016 Tacoma Limited
    It's easier to just pull the console off and twist the socket out. It takes about thirty seconds to do that, change the bulbs and replace the console.
    Devious6 likes this.
  8. Feb 22, 2020 at 5:48 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    I have very small mechanic curved set of pliers that I used to wedge mine out.
  9. Feb 22, 2020 at 6:19 PM
    ICU1
    ICU1 Well-Known Member
    Meso has what you need.
    dnguy77 likes this.
  10. Jun 20, 2020 at 8:52 PM
    Kmweb
    Kmweb Member
    Kelvin
    Calgary, Alberta, Canada
    2018 Tacoma TRD Offroad
    Light, interior
    Don’t even try to pull it out..I broke the bulb, eventually took the console down(which is super easy), took the broken bulb and socket out, tried to scrape or crush the existing glass out of socket, then screwed up the socket, (now too loose), tried to Gerry rig it, blue the fuse, then tried to order new socket (which is not sold by Toyota sepRate from entire console)...and now need to try wreckers to get an old socket. WTF...so DONT try to pull it out...take the console down and it’s a piece of cake to get at and switch bulbs!
    PurebredTaco likes this.
