Map light bulb replacement, piece came off w bulb
Discussion in '2nd Gen. Tacomas (2005-2015)' started by schleygo, Apr 9, 2015.
  1. Apr 9, 2015 at 4:19 PM
    schleygo
    schleygo [OP] Well-Known Member
    Daniel
    Ft Worth TX
    07 Dbl Cab Radiant Red
    Bilsten 5100s, Eibach Coils, 2" toytec AAL, LR UCAs, SC5 Matt Bronze
    Replacing map light. This came off with blown out bulb. Tried to put it on with the new bulb hoping it would make contact and light up, it didn't work. I even pulled away the metal reflective lens to see if I could solder it, it is too tight of a space.
    Any other options? Do I need to buy a new overhead console or can I just replace the bulb socket?
    Pic attached
  2. Apr 9, 2015 at 5:19 PM
    schleygo
    Daniel
    Ft Worth TX
    It appears I can replace just the dome lights via pics I have seen. Looks like a few Phillips head screws hold it in place. Searching for that part # all over this interwebs.
    What is the part # just for that piece?? None of the diagrams I find show that piece
  3. Apr 10, 2015 at 5:42 AM
    schleygo
    Daniel
    Ft Worth TX
    Can I just order this part circled in red? All the overhead console diagrams do not show this part #
    Also the piece that fell off came from right where the arrow is pointing.
  4. Apr 10, 2015 at 8:02 AM
    Siblue
    Siblue Well-Known Member
    So Cal
    25 Tundra TRD pro
    I don't think its available seperately.
    You can try a used part, sometimeswill appear on this marketplace.
  5. Apr 10, 2015 at 11:33 AM
    schleygo
    Daniel
    Ft Worth TX
    Maybe it's time to upgrade to a compass temp overhead console?? This sucks, a $1.49 bulb turns into a $100+ problem
  6. Apr 10, 2015 at 12:44 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    huh ? wut ?
    solder that little piece right back in,
    what.....2 cents of solder
    4 cents of butane
    it's not hard to fix that
