Map Light/Dome Light Mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by moloko4evr, Nov 18, 2011.
  1. Nov 18, 2011 at 6:55 AM
    moloko4evr
    moloko4evr [OP] Member
    Canada
    11 SR5 TRD
    Hi there,
    I'm relatively new to this forum.
    I was just wondering if anybody has done that Map Light/Dome Light Mod (where both lights go on when opening the door, etc) on a 2011 Tacoma?
    I desperately want to do it, but I am an electrical novice and would love to have step by step instructions so I don't screw anything up.
    Any info would be great!
    Thanks!
    moloko4ever
  2. Nov 18, 2011 at 6:56 AM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    By no means have I seen it all, but I've never heard of that one.
    Fink
  3. Nov 18, 2011 at 6:57 AM
    Casey05Taco
    Casey05Taco Well-Known Member
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    trd seat covers, bed mat, tinted windows, debadged, mud flaps removed, tinted tails, blacked out center console, Black Rims, 6000k HID in highs and fogs, blacked out front emblem, Pioneer AVH-4300DVD, Gauge Cluster, lower valence, retrofitted, audio system, Maxtrac Spindles, Billies
    Are you trying to get more light when your doors are open? If so you can save yourself some time and wiring and throw some LEDs in there. Makes it so much brighter
  4. Nov 18, 2011 at 7:01 AM
    Fink
    Orlando, FL
    This is great advice.
    The pics I've seen of the LEDs make them look insanely bright. It's on my list...
    Fink
  5. Nov 18, 2011 at 7:09 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Haven't seen that one either. Are you wanting the light up front rather than in the back, or do you really want both at the same time?
  6. Nov 19, 2011 at 10:46 AM
    Shiftin2Sixth
    Shiftin2Sixth Well-Known Member
    Curt (kûrt)
    Utah
    2021 MGM TRD-OR DCSB 4WD
  7. Nov 19, 2011 at 11:14 AM
    jjew18
    Alliance Airport
    05 PreRunner SR5
  8. Nov 19, 2011 at 12:37 PM
    Fink
    Orlando, FL
  9. Nov 20, 2011 at 7:35 AM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Here's my set up. Just changed the bulbs. The LED dome light is bright enough to see in the front without blinding you. If you turn on the LED's on the map lights then it's blinding lol.
  10. Nov 20, 2011 at 2:18 PM
    moloko4evr
    Canada
    11 SR5 TRD
  11. Nov 20, 2011 at 2:42 PM
    Shiftin2Sixth
    Curt (kûrt)
    Utah
    That will work but without the diode wouldnt your dome light come on whenever you turn on a map light? The diode stops the power from coming back to the dome light letting you use your map lights independently
  12. Nov 20, 2011 at 3:34 PM
    moloko4evr
    Canada
    11 SR5 TRD
    I just went out to test it out to make sure.
    The dome light doesn't go on when I turned on any of the map lights.
    I don't know if it's because the 2011's are wired differently or not.
    But it seems to work without the diode.
  13. Nov 20, 2011 at 3:42 PM
    Shiftin2Sixth
    Curt (kûrt)
    Utah
    Right on! Well good job.
