Map light surging/flickering
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Davis98, Oct 16, 2018.
  1. Oct 16, 2018 at 3:01 PM
    Davis98
    Davis98 [OP] Well-Known Member
    2016 Tacoma TRD Sport 4x4
    Can anyone help me figure out why within the past 2 days the map lights in my 2016 look like they’re flickering or surging while the truck is running but when turned off the lights go back to normal. Also, I’ve noticed within the past 2 days my headlights have started doing the same flickering as the map lights I would have thought that it’s just normal HID bounce that most people have but it’s when the truck is parked. Any opinions would be great
  2. Oct 16, 2018 at 3:02 PM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Do you have a multimeter?
    I’ve experienced similar conditions, and had a broken alt field wire deep in the harness. Check batts and charging.
  3. Oct 16, 2018 at 3:06 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Does your rig have aftermarket HIDs?
  4. Oct 16, 2018 at 3:06 PM
    Davis98
    No I dont Have one, can you explain the alt field wire? Electrical stuff is not my best field. Thanks
  5. Oct 16, 2018 at 3:06 PM
    Davis98
    Yes
  6. Oct 16, 2018 at 3:12 PM
    Plain Jane Taco
    USA
    I would suspect those are the culprit
    stun gun likes this.
  7. Oct 16, 2018 at 3:12 PM
    stun gun
    Aaronski
    Tacomas.
    Swap back to oem before anything
  8. Oct 16, 2018 at 3:15 PM
    Davis98
    Those could be making the map lights flicker? The only reason I thought It wasn’t the HIDs was because of the map lights flickering too. That and that I’ve had my hids for almost 8 months now I didnt Think they would of all of a sudden messed something up
  9. Oct 16, 2018 at 3:18 PM
    Plain Jane Taco
    USA
    You're probably noticing the surging in the lights...but it's probably fluctuating in the entire electrical system to some degree
  10. Oct 16, 2018 at 3:20 PM
    Plain Jane Taco
    USA
    HIDs draw a fair amount of power. Issues with the ballasts or caps could certainly cause some weirdness
  11. Oct 16, 2018 at 3:21 PM
    Davis98
    Makes sense, I’ll have to switch them back and se did it helps. If it works that just means I’ll have to get some Anzo headlights since they aren’t supposed to be run with HIDs which will make taking the HIDs out not so bad
