Map lights for 2004 Tacoma Double Cab 4X4
Discussion in 'Lighting' started by hunterwojo, Mar 23, 2010.
  1. Mar 23, 2010 at 6:27 AM
    hunterwojo
    hunterwojo [OP] Member
    Georgia
    None I like it stock
    Can anyone help a new member: Would like to replace the 2 map lights located on either side of the rear view mirror. How do I get acess to them? I do not want to damage the assembly. Also, do you know what type/size the lights are?
    Thanks
  2. Mar 23, 2010 at 6:56 AM
    maconhurler
    maconhurler Well-Known Member
    Harrisonburg, VA
    04 4wd v6 sr5
    Deckplate Mod, Catz Fog lights, Roll Top Tonneau Cover, Pioneer Premier 800prs HU, 10" Kicker L7, Kicker 5 1/4 components, Polk dB 5x7s, Oznium superflux puddle lights and bed lights
    http://www.v-leds.com/DE3175-3175-LED/White-LED/sc122285-1-2//page/1/checkForLanding/true
    has some good ones for the map lights. I replaced mine and my dome light. I used the 5k white 1w hp in the maps and wish I'd done the same in the dome. used the 5k white 6led in dome. The 1w hp is much brighter.
    Very easy to change. If I remember correctly I popped the plastic case off from the back using a screwdriver and then its an easy replacement of bulb and case. Wife hates it, says its too bright.
  3. Mar 23, 2010 at 7:38 AM
    hunterwojo
    Georgia
    Macon:
    Thanks for the info.... I have the dome off and am waiting for my three each 1W LED's to arrive from Tiawan or Japan. Paid only $4.50 for all 3 off ebay with only $3.50 in shipping. How do you get to the map lights by the rear view mirror?
  4. Mar 23, 2010 at 11:08 AM
    hunterwojo
    Georgia
  5. Mar 23, 2010 at 2:51 PM
    maconhurler
    Harrisonburg, VA
    04 4wd v6 sr5
    Pretty sure I took a small screwdriver and popped the cover loose from the backside of it up towards the mirror base.
  6. Mar 24, 2010 at 4:43 AM
    hunterwojo
    Georgia
  7. Mar 24, 2010 at 7:06 AM
    Fuzzyman81
    Fuzzyman81 The New Guy
    Jax, FL
    04 PreRunner TRD
    Hunterwojo - what size did u get for the map lights? I've got a 3175 coming for the dome light but dont know what to get for the maps.
  8. Mar 24, 2010 at 7:11 AM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Im pretty sure they take the same bulb. atleast mine do..
  9. Mar 25, 2010 at 3:40 AM
    hunterwojo
    Georgia
    Fuzzy and EverTaco:
    EverTaco is correct. I went on line and found that the 3175 and 3021/3022's are all the same. I then went ot ebay and got a 1W LED from a Japan company for only $4.50 for all three with only 3.20 shipping. I did some research and found they are the brightest. I also went on ebay and got 4 LED bright white dash lights for only $7.00 with free shipping from Tiawan..
    Good luck
  10. Mar 28, 2010 at 7:18 PM
    hunterwojo
    Georgia
    Got them in and installed. They look great!!! Can't wait till the LED 194s arrive to get the dash rolling
