Map Lights on with Dome light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DR007, Nov 30, 2012.
  1. Jul 10, 2018 at 7:18 AM
    #181
    Berniebikes
    Berniebikes Well-Known Member
    Bernie
    Williamsburg, VA
    2015 White TRD OR Double Cab
    It is an old thread. I went and checked and I only have some leftover female pins. You would still have to get some male pins
    they should be pretty available at any electronic shop, radio shack, probably at the hardware store if it's well stocked
  2. Jul 10, 2018 at 11:11 AM
    #182
    TheBlueBeast15
    TheBlueBeast15 Well-Known Member
    Kevin
    H-Town
    2015 Blue Ribbon Metallic TRD Off Road double cab short bed
    Wait I need a male pin? Where do I plug in the male pin. Iv been reading this thread over and over again and even the one over on Toyota nation. I think I’m going to follow this guy write up from this thread
    Am I missing something?
  3. Jul 22, 2018 at 4:52 PM
    #183
    Bravisimo
    Bravisimo So many mods, very little money.
    Joe
    Santa Clarita, CA
    2014 Tacoma PreRunner SR5 DCLB
    Tint, headlights wrapped & rear lights smoked, power outlet mod., grill & rear bumper wrapped, Falken A/T 3W,
    Can someone make a video explaining / doing the process? It would be super helpful.
    hammertaco11 likes this.
  4. Aug 28, 2019 at 8:26 PM
    #184
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
  5. Aug 29, 2019 at 6:46 PM
    #185
    caribe makaira
    Caribbean, Puerto Rico
    Swap the location of the terminals and add a terminal (090/2.3II type, not a molex terminal) (do not bend it) with enough wire to reach the negative hole in the Room Lamp (Center), terminate wire with a ring terminal. Use a bolt, washer n nut. Insulate added bolt so it does not touch the roof.
    NavyDiver72 and Bravisimo like this.
  6. Sep 28, 2019 at 8:58 AM
    #186
    2021TacoTruck
    2021TacoTruck Active Member
    Erik
    Mesa, AZ
    2021 TRD Off-Road 4x4
    RC Vertex 3” adjustable c/o’s w/ resis, RC UCA’s and RC 2.5 adjustable rears w/ resis. TRD Pro Black wheels wrapped in 285/75 R16 BFG AT’s. Nitro 4.88’s KD Max tune
    I just completed this mod. Thanks, DR007 for the write-up.
    Not sure if this has been covered, but some had difficulty swapping the map light wires. To remove the wires, it's best to use a small pick. I used the 90 degree pick to remove the white plastic wire retainer, and then drive the pick in from the front of the connector (the side which goes into the map light pins) and slide the pick on top of the metal wire connector to release the small plastic retainer. Once you see the connector, my description will make sense. I hope this helps save someone frustration.
    Great mod, as it takes very little time to achieve a useful result.
    TxStVanWilder likes this.
  7. Feb 15, 2020 at 12:01 PM
    #187
    whatarush
    whatarush Active Member
    Missouri
    2015 Blue Tacoma DCLB TRD Sport
  8. May 9, 2020 at 9:19 PM
    #188
    EME
    EME Well-Known Member
    Nick
    05 Tacoma sport
    thanks to the OP, just completed this mod, and added the LED lights at the same time, nice and bright for sure.
  9. May 11, 2020 at 9:55 AM
    #189
    jbcanes
    jbcanes Well-Known Member
    Justin
    Tampa, FL
    14 PreRunner double cab
    backup camera, intermittent wiper, step bars, bug deflector, window vent, console vault,solid fold 2.0, 2016 sport wheels, front camera, anytime rear front camera mod, homelink mirror, dash cam, unifilter,
    Thanks for the great write up. Did it this morning. Everything went well except the metal end of the dome led ripping off.
  10. Jun 11, 2020 at 8:10 AM
    #190
    Shayne
    Shayne Well-Known Member
    Shayne
    South Shore, Mass
    2018 Inferno TRD Sport DC 4x4
    Will this work for a 3rd gen?
  11. Jun 11, 2020 at 11:24 AM
    #191
    caribe makaira
    No...
    3rd Gen Map lamps
  12. Jun 27, 2020 at 12:05 PM
    #192
    JimIowa
    JimIowa Well-Known Member
    Jim
    Des Moines, Iowa
    2015 TRD OR DCSB
    "Park Avenue" ACDF horns
    Just completed this today. Had to switch the map light bulb polarity as mentioned somewhere on this tread. Don't forget this bulb flip if things don't initially work. For anyone who is going to try this, and wants one of the steps easy-peasy, I have 9 extra 22-18 female connectors for $1.00 each (postage mainly). This size slides on the "bent" blade nicely. [/ATTACH] IMG_20200627_1355275.jpg Noname.jpg
  13. Sep 14, 2022 at 10:47 AM
    #193
    reallifedog
    reallifedog wat.
    Jordan
    Denver
    08 Tacoma TRD OR
  14. Sep 14, 2022 at 10:57 AM
    #194
    caribe makaira
    reallifedog[QUOTED] likes this.
  15. Sep 14, 2022 at 11:11 AM
    #195
    reallifedog
    reallifedog wat.
    Jordan
    Denver
    08 Tacoma TRD OR
    well dang, I thought I was on to something. Either way, I'm going to give them a try. I also ordered the terminals from Corsa to compare.
  16. Sep 21, 2022 at 7:30 AM
    #196
    reallifedog
    reallifedog wat.
    Jordan
    Denver
    08 Tacoma TRD OR
    I tried both pins and they both snap into the plug firmly, but since the 7116-4026(from Ballenger motorsports) is an insulated pin I trimmed the rear wings to create the uninsulated crimp onto the wire insulation. Regardless, I installed the 7116-4021 pin from Corsa.
    I'm able to turn my map lights on with the dome in the "OFF" position which disagrees with everything I've read. Otherwise, everything works perfectly and IM super satisfied with the outcome.
  17. Sep 21, 2022 at 7:35 AM
    #197
    caribe makaira
    It all depends on which side of the center dome you attach the added wire from the maps...
  18. Sep 21, 2022 at 9:51 AM
    #198
    reallifedog
    reallifedog wat.
    Jordan
    Denver
    08 Tacoma TRD OR
    Interesting, I did it on the side opposite the plug.
  19. Nov 5, 2022 at 8:48 AM
    #199
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Great mod! Just did this and it's an awesome cheap upgrade. Very stoked.
  20. Jun 28, 2023 at 8:00 AM
    #200
    Samram92
    Samram92 New Member
    Samson
    Littleton, Colorado
    2014 Mag Grey Tacoma TRD off-road
    ARB Deluxe Bull Bar Winch Mount (F) Bilstein 5100 shocks (F/R) AT 265/75R 16 Tires OME 2886 Coils (F) Toytec Boss Leaf (R) Unknown rear bumper
    On my 2014, swapping the wiring position in the map light didn’t work. Once I put them back to their original position, everything worked as intended. Cool mod for convenience! Thank you!
