Map Lights on with Dome light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DR007, Nov 30, 2012.
  1. Jan 30, 2014 at 7:16 PM
    #101
    colbyrainey
    colbyrainey Well-Known Member
    Colby
    KC
    '11 Dbl TRD Sport
    TSB Leafs, Bilstein 5100's @ 1.75", K&N Filter, Kenwood DNX 6180, BFG Rugged Terrain T/A's, ImMrYo Rearview Mirror Bracket, Extra D-Rings, Gloss Black Stock Wheels, Grillcraft Grille
    It should have been mine! Every time I got in the truck at night I was pissed it didn't come that way from the factory!
  2. Feb 1, 2014 at 1:55 PM
    #102
    jangel2
    jangel2 Active Member
    Jared
    Lafayette, LA
    '05 DC PreRunner
    Bilsteins in front @ 1.75, OMD Rear leafs, HID heads and fogs, dipped front grille and lower valence, red LEDs in dome and maps, map/dome mod, Custom Bed Rack and Sliders, 32" EYourLife LED Bar, 2 x 6" Side LED Bars, 2 Cube Work Lights and 6" LED Bed/Reverse Lights.
    Did this today in about 30-45 minutes, awesome lil mod.
    My 2 cents to help others. If you are planning to solder the connections like I did and you want to be able to move freely while doing so. You can actually take both the map light panel and dome light panel out at once and measure whatever you need for wire length and solder them together on a table or the ground.
    What I actually did was get everything prepped; wire length, tabs bent and such then after I had everything together I actually pulled my headliner down a bit so that I could fish the whole dome light panel through and then out the dome panel hole. Then I just popped everything back into place, this made it easier to make good solder joints.
    Hope this might help.
  3. Mar 11, 2014 at 11:39 AM
    #103
    DRP6833
    DRP6833 Well-Known Member
    Dave
    Frederick, CO
    2014 Tacoma I4 4WD
    I finally got this done last weekend. Sweet! It works as advertised, thanks again OP!
  4. Apr 20, 2014 at 8:20 AM
    #104
    ToeKneeSock
    ToeKneeSock Member
    Tony
    San Diego, CA
    heh
    Anyone know the part# for the white female socket connector? I jack my up when trying to pry it open.
  5. Jun 5, 2014 at 11:45 AM
    #105
    Jwbfx4
    Jwbfx4 Active Member
    Bama
    14' dcsb trd
    Thanks for the write up. Just completed this and it works great.
  6. Jun 5, 2014 at 9:05 PM
    #106
    bueller
    bueller Well-Known Member
    AZ
  7. Jun 29, 2014 at 11:10 PM
    #107
    colbyrainey
    Colby
    KC
    '11 Dbl TRD Sport
  8. Jun 29, 2014 at 11:43 PM
    #108
    DR007
    DR007 [OP] Well-Known Member
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    MagnaFlow exhaust, K&N cold air intake, MB TKO wheels with 265/75/r16 Hankook Dynapro ATM, Blue Center shift LED color change, Map Lights with Dome, LED Map and Dome lights, Cluster Light Change, DTRL, Parking Light as Blinker, Blue A/C Control lights, Blue Clock, Bed Lights, Debadged tailgate, painted all exterior plastic trim, 6LZ Lightbars in grille, OTRATTW switches, Fog Light in Reverse light Mod, LED Blinkers all around, Projector Fog Lights, 15" blitzpro light bar, added hidden cig lighter port, custom plate front bumper, OME complete lift with 885 front coils, Ultraguage, CB radio 3' whips, 12v bed lighter port, Center Console Lights, AllProOffroad Sliders, 50" roof led light bar, 2 BlitzPro 6LZ Reverse Lights
    Yes sir it still does
  9. Jul 14, 2014 at 1:09 PM
    #109
    colbyrainey
    Colby
    KC
    '11 Dbl TRD Sport
  10. Jul 14, 2014 at 1:30 PM
    #110
    gravedgr
    gravedgr dirty Ford driver
    Doug
    Alpharetta, GA
    2014 Tacoma 4x4 DCSB TRD Off Road (Blue) - gone
    Method Racing Mesh wheels (17x8.5), Cooper ST Maxx tires (285/70/17), Toytec Ultimate lift (3"), Wet Okole seat covers, WT mats, Gemtex mirror, CF stubby antenna, scoop hood, painted grill surround, SOS bumper, SOS bed rack, Tepui Autana RTT, Engo 10k winch, bed lights, under hood lights, diff breather, 12v bed socket, 31M battery + battery monitor
    Are they plug and play? Link?
  11. Jul 15, 2014 at 5:57 AM
    #111
    colbyrainey
    Colby
    KC
    '11 Dbl TRD Sport
    Yep, just replace the bulbs.
    Map Lights
    Dome Light
    They come from China, but delivery didn't take long and I'm in KS.
  12. Jul 15, 2014 at 6:57 AM
    #112
    gravedgr
    Doug
    Alpharetta, GA
    Sweet, thanks! Ordered. :D
  13. Oct 5, 2014 at 7:15 PM
    #113
    ajohnson225
    ajohnson225 Well-Known Member
    Austin
    Baton Rouge
    Silver 05 DCLB Sport
    3" toytec lift, 285/70/17 trail grapplers, 17" ballistic offroad, flowmaster 40 delta flow, TRD CAI, debadged, pioneer touch screen, 2 kicker 10" on 1100 watt hifonics, 30" light bar, 15% tint front 20% tint back, interior LED's, all bulbs changed to LED's, LED pod reverse lights
    revivng old thread... I just did this mod after I installed new led's, all of the leds work but after the mod the map lights do not at all(pushing them, open door), the dome light works like normal, I reverse the mod and the map lights work again, I do not believe im doing anything wrong, any idea what could be going wrong?
  14. Oct 6, 2014 at 5:42 PM
    #114
    DR007
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    First step would be going through again and making sure you reversed the wires correctly and all the other steps. Then since you have leds and they're polarized make sure they're in correctly as well. Most are make the way they can be turned any direction but try yours.
  15. Oct 6, 2014 at 6:09 PM
    #115
    ajohnson225
    Austin
    Baton Rouge
    That makes since. Since i changed the polarity when switching the wires, i probably have to change the bulb too. Thanks
  16. Oct 9, 2014 at 4:54 PM
    #116
    Duncandiver
    Duncandiver Member
    Just did the mod, easy to do and works great. Now have some LEDs on the way.
    thanks Guys
  17. Jan 9, 2015 at 4:07 PM
    #117
    TacoTechie
    TacoTechie Member
    N. Georgia
    2015 DCSB Grey Metallic TRD Sport 4x4
    Just completed it on my 15 DCSB. The steps and process are easy peasy. But when you factor in sub freezing temperatures and fading daylight it makes it more interesting.
    A few things:
    1). The harness on the map light that needs you to swap the wires is a PITA to release the wires. I pulled the plastic side cap and that did nothing. They must have used different harnesses on my truck. I had to gently pry the plastic catch tabs up and pull out the wires. This took the longest of anything as I didn't want to break them.
    2). I used a small bullet style connector and crimped it almost flat. It connected perfect to the flipped up tab on the map light body. I shrink wrapped to insulate. I also used a zip tie to hold the wire in place against the map light body as it needs to do a 180 degree turn to go back to the dome light. The zip tie takes the pressure off of the connection.
    3). I've read that to install LEDs you need to invert the polarity for them to work. How is this done? Simply rotating the bulb, at least in a standard filament bulb, does not invert the polarity.
    4). As stated earlier remove your fuse before you do anything. I blew mine and had to make am unneeded trip to Autozone.
  18. Jan 9, 2015 at 4:58 PM
    #118
    DR007
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    Polarity shouldn't matter unless your leds states that its polarized. But if you put it in and nothing reverse it then it should work. If not.. You either did it wrong or you have a bad led
  19. Jan 17, 2015 at 11:12 AM
    #119
    raf215
    raf215 Well-Known Member
    Ray
    Rio Rancho NM
    2011 TRD Sport Access Cab
    Front map lights on with doors - great mod
    I just did this mod this morning - works as advertised and it'll be great come Monday morning to have both map and dome lights come on when I get in the truck to head off to work at 5 in the morning.
    I used a female quick connect and 2 zip ties to hold the wire in place. I zip tied the wire in with the map light cable assembly to keep the pressure off the connector as one of the other posters did.
    Much thanks to DR007 for the great write up!
    Certainly hope that Toyota put that in the 2016 ;)
  20. Mar 13, 2015 at 1:32 PM
    #120
    Jamart5
    Jamart5 HoeRunner
    Juan
    SETX
    '16 4Runner TRD
