March 16 Huntsville AL Meet and Greet/Mod day
Discussion in 'South East' started by TacoAlaMode, Feb 3, 2019.
  1. Mar 12, 2019 at 8:19 AM
    #161
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    A chassis punch will cut the cleanest hole in thin sheet metal, the step bit next, the hole saw last. I really would not use a hole saw on sheet metal - especially where you will see it (as in, your roof.)
    I have a 7/8" chassis punch, which is what I used for my 3/4" antenna holes. I will have it with me on Saturday if you want to use it.
    Are you using a backing plate of any sort? I used .120" aluminum under my mounts. The roof sheet metal is rather thin, and I don't want the mounts to flex in the roof.
  2. Mar 12, 2019 at 9:11 AM
    #162
    coke can
    coke can Well-Known Member
    Brad
    Huntsville, AL
    18 TRD DCLB OR MGM
    Awesome, that punch would be much appreciated. I wasn't planning on using a backing plate out of a combination of uncertainty if I'd need one, and laziness of procuring it. You wouldn't happen to have some for sale, or know where I could get some, would you?
  3. Mar 12, 2019 at 9:36 AM
    #163
    Scott B.
    Scott
    Georgia
    I don't have any with me.
    The home centers sell sheet metal - not sure what thickness aluminum they have. There should be a metal supply place around here.
    coke can[QUOTED] likes this.
  4. Mar 12, 2019 at 10:07 AM
    #164
    coke can
    Brad
    Huntsville, AL
    18 TRD DCLB OR MGM
    Hmm, actually I bet I could steal a piece from the case of an obsolete computer laying around the office. Bet we can chop off a usable chunk with a dremel or something.
    Or bribe @Jerneyman to take his plasma cutter to my old skid plate? Thickest antenna backer ever! :rofl:
  5. Mar 12, 2019 at 10:22 AM
    #165
    coke can
    Brad
    Huntsville, AL
    18 TRD DCLB OR MGM
    Also @tacoala What's the plan for what times everyone will be hanging out/working, and should we plan to bring food to grill, or just hitting up a restaurant?
  6. Mar 12, 2019 at 10:28 AM
    #166
    Scott B.
    Scott
    Georgia
    The nearby Chick-Fil-A is next to a Redstone Credit Union - which has big parking lot. Aren't they closed on Saturday?
  7. Mar 12, 2019 at 10:30 AM
    #167
    Jerneyman
    Jerneyman Well-Known Member
    Wes
    Huntsville, AL
    2011 Tacoma TRD OffRoad 4x4
    **Armor** Home Fabbed Hybrid Front Bumper Home Fabbed Rock Sliders Home Fabbed IFS Skid Plate Home Fabbed Mid Skid Plate Home Fabbed Transfer Case Skid Home Fabbed High Clearance Rear Bumper **Suspension** ADS Front Coilovers (Extended Travel, 700lb coils, Remote Resi) Total Chaos UCAs Chevy 63 Swap w/ custom shock hoops 14" Bilstein 7100s **Wheels/ Tires** Spidertrax 1.25" Wheel Spacers Front/Rear TRD Rock Warrior Wheels 285/75/16 BFG KO2s **Electrical** Pelfreybilt Auxiliary Fuse/Relay Panel Blue Sea Fuse Box Bussman 100 AMP Breaker **Recovery** Smittybilt 9.5k Winch **Lights** 20 Inch Single Row LED Bar Rigid Side Shooters (Flood/Pair) w/ CBI Offroad Ditch Light Brackets Rigid Duallys, Amber for fog lights **Miscelaneous Mods** Rear Diff Breather Relocation RAM Mount A-Pillar Mod w/ Garmin Power Cable DRT Fabrication Cab Mount Relocation Pinch Weld Mod (Mini Sledge Special) Short Rise Bed Bar for Tire Storage/ Hi-Lift Mount
    I've got some 1/8" flat stock that would be perfect for an antenna bracket if ya'll want to give that a shot. Would be substantially cheaper than the material at Home Depot.
  8. Mar 12, 2019 at 10:42 AM
    #168
    coke can
    Brad
    Huntsville, AL
    18 TRD DCLB OR MGM
    Aluminum or Steel? (which would be ideal anyway?) How much are we talking? Bet I can get the side off an old computer for free if @Scott B. thinks that would work. Or even just a big washer from home depot to save time/trouble cutting...
  9. Mar 12, 2019 at 10:48 AM
    #169
    Jerneyman
    Wes
    Huntsville, AL
    It’s steal. Aluminum would definitely be better in the application though.
  10. Mar 12, 2019 at 10:50 AM
    #170
    Scott B.
    Scott
    Georgia
    You can aluminum or steel, it doesn't matter. The objective is to make the roof material thicker around the antenna mount, to reduce flexing.
    Yes, the side of a computer case should work. We can trim it to fit (12" x 12" or smaller, depending on roof layout.)
    A big washer would work, but I don't think you can find one big enough. You try looking at McMaster-Carr - ordered today, you should get delivery by Friday.
  11. Mar 12, 2019 at 10:52 AM
    #171
    Jerneyman
    Wes
    Huntsville, AL
    You can dig through my scrap bin anytime you want. Just sayin'.
  12. Mar 12, 2019 at 10:54 AM
    #172
    coke can
    Brad
    Huntsville, AL
    18 TRD DCLB OR MGM
    I'll probably just stick with aluminum then. I'm no materials expert, but I'd be nervous about a steel plate vs aluminum roof- can't certain metals butting against each other react and cause premature corrosion?
    Edit: yeah: https://www.albanycountyfasteners.com/blog/2017/09/15/stainless-steel-and-aluminum/
  13. Mar 12, 2019 at 11:03 AM
    #173
    Jerneyman
    Wes
    Huntsville, AL
    I don't believe our trucks are made from Aluminum. I could be wrong, but I believe its just made from steel sheet metal.
  14. Mar 12, 2019 at 11:29 AM
    #174
    coke can
    Brad
    Huntsville, AL
    18 TRD DCLB OR MGM
    Oh :oops: Guess I just assumed most vehicle body panels were formed aluminum. Maybe I should go with steel then lol.
  15. Mar 12, 2019 at 11:30 AM
    #175
    Jerneyman
    Wes
    Huntsville, AL
    Well, the offer still stands, I got some steel you can use as a backing plate.
  16. Mar 12, 2019 at 11:38 AM
    #176
    coke can
    Brad
    Huntsville, AL
    18 TRD DCLB OR MGM
    Now that I think about it, those computer cases are probably actually steel as well, right? A magnet wouldn't stick them if they were aluminum. Which also means the body panels are definitely steel as well. :annoyed:
    Maybe two wrongs do make a right! Would have ended up with the right solution if I went with old computer case, but only because I misidentified both :frusty:
    ...Shows how much I know about materials...
    I might take you up on that offer. I obviously can't be trusted to figure this stuff out myself lol.
    Jerneyman[QUOTED] likes this.
  17. Mar 12, 2019 at 11:43 AM
    #177
    Jerneyman
    Wes
    Huntsville, AL
    Lol. Well if you want, just PM me with the size and hole dimensions and I can cut you out a piece tonight and leave it at our drop site. :anonymous:
  18. Mar 12, 2019 at 11:53 AM
    #178
    coke can
    Brad
    Huntsville, AL
    18 TRD DCLB OR MGM
    @Scott B. Any recommendation on dimensions? roughly 2 or 2.5" outer diameter (or similar square)? I'm assuming 3/4" hole to match the roof?
  19. Mar 12, 2019 at 12:10 PM
    #179
    Scott B.
    Scott
    Georgia
    IIRC, mine are 12" x 12" square. As long as it fits, bigger is better.
    Yes, same size hole as in the roof. I'd wait on drilling the hole - position the backing plate on the roof, then cut the hole. Just in case the plate can't be centered due to cross braces or something.
  20. Mar 12, 2019 at 6:09 PM
    #180
    TacoAlaMode
    TacoAlaMode [OP] Mr. Midlife Crisis
    Brian
    Huntsville AL
    10 DC LB MG 4X4 TRD Sport
    Icon Ext Coilover, Alcan Rear springs, Demello 3-Hoop Bumper and RockCrusher Sliders, Full tint 360', WeatherTech Floor liners and rainguards, Debadged, In Cabin 110 with 400w anytime, Diff breather mod
    ok, here goes the update.
    I've PM'ed everyone on the Attendees list that I know doesn't have my address.
    @BAMATOY, @JKU3000 , @TheTacoma , @stronghammer , @JMY24 , @Leman , @JBTacoma , @Scott B. I know you have been here, but let me know if you need the address again. I have already sent it to @GotLift37 because he needs it everytime.
    I'm not sure how long TRD Tyler will be banned. I don't have his cell number, so if someone will check if he still plans to come.
    All the following people are still marked as possible. Let me know if I should move you to Attending and we can follow up with the address. @POOLGUY , @BamaTaco56 , @InfernoChalupa , @BlackBeauty04 , @Your Boy Rocco , @ty.s07 , @WasoHatkaTaco , @jeg0005 .
    If I have missed you somewhere, let me know!
