March 2016 Gulches ride with lots of BS (Aiming for biggest Southeast meet/trail ride EVA)
Discussion in 'South East' started by Acerwin, Nov 17, 2015.
March what?
Poll closed Dec 18, 2015.
  1. 4th
    1 vote(s)
    4.8%
  2. 11th
    2 vote(s)
    9.5%
  3. 18th
    13 vote(s)
    61.9%
  4. 25th
    5 vote(s)
    23.8%
  1. Jan 18, 2016 at 9:48 AM
    #3441
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Maybe that can be something we look into next hunting season. :D Maybe by then I'll have the OGT straightened out and my cash reserves will recover, haha. :thumbsup:
  2. Jan 18, 2016 at 9:51 AM
    #3442
    Jystr
    Jystr IG: TW_Jystr
    Leesville, LA
    2016 Barcelona Red Tacoma TRDOR
    See build thread
    They were in love with my turd gen. Surprised I was out there doing what I was but they were impressed at what it did. I'll touch base in the Florida thread about it and gauge interest
  3. Jan 18, 2016 at 10:05 AM
    #3443
    Taco No Baka
    Lee
    Tampa, FL
    Rgr that. I think the Annual Citrus meet might be my last wheeling trip for the season with the way I'm hemorrhaging cash trying to get the OGT road worthy again. After I replaced the outer tie rod end and cv axle I tore up at Hardrock back in December, my left front tire still had play in it. I popped the boot off the steering rack this morning and had Mom wiggle the tire while I watched to see what was moving. Turns out damn near everything. the brand new inner tie rod I just replaced in November is toast and the piston on the steering rack was moving all over the place.
    Fortunately the inner tie rod is lifetime warrantied, but I'm going to have to get a new style steering rack guide from Toyota to hopefully eliminate the steering rack play. While I'm at it, I'm going to go ahead and replace the outer tie rod end with the beefier-looking, greaseable Moog unit to match the new one on the passenger side. With any luck, that will cure my frontend issues for the foreseeable future. :bananadead:
    Oh, and then there the little matter of a blown rear shock...:facepalm::frusty:
  4. Jan 18, 2016 at 10:10 AM
    #3444
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    dude, time for some limiting straps and bump stops :boink:
  5. Jan 18, 2016 at 10:13 AM
    #3445
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I'm sure some GA guys would go, just post up and I'll see what I can do
    Jeffvt0508[QUOTED] likes this.
  6. Jan 18, 2016 at 10:36 AM
    #3446
    Taco No Baka
    Lee
    Tampa, FL
    Not sure that would help. There's a dent in the side of the shock where it hits the spring when it's fully articulated with the right tire stuffed. What it's really time for is to do a ubolt flip so I can move the shock away from the spring a little. In fact, if I don't wind up going to Gulches (which is looking less likely every time I find another issue with the OGT) I might just make that my next mod.
    I wanna get the top plates like you got from Rough Stuff (?), but IIRC, they don't really sell a ubolt flip kit, so I'd still need to source the proper ubolts and lower shock mounts. Not only that, I wanna make it all complicated by drilling new center pin holes in my spring perches to relocate my axle aft about an inch. And I'd need new bumps that work with the new top plates.
    Then I might try to cough up the cash to get a set of Icons for the rear. :cool:
    Rattletrap66[QUOTED] likes this.
  7. Jan 18, 2016 at 10:38 AM
    #3447
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    that won't give you any axle wrap? Yea my chevy swap kit from Ruff Stuff came with everything I needed including U bolts
  8. Jan 18, 2016 at 10:46 AM
    #3448
    Taco No Baka
    Lee
    Tampa, FL
    I already have a nasty case of axle wrap since I put that locker in, but (and I might be wrong about this) relocating that axle shouldn't make it any worse. It's still going to be clamped the full length of the perch. It's just the alignment pin will be a little further forward.
    If Rough Stuff had a flip kit I'd be all over it. They probably have all the parts, just not in one kit. And I like your top plate better than APs since it has the bends on the ends. Not only would that make the plate more rigid, but it would also prevent stress concentrations on the springs at the ends of the plate. That and they have the extra center pin holes for moving the axle.
    [​IMG] :drool::drool::drool:
  9. Jan 18, 2016 at 12:54 PM
    #3449
    Acerwin
    Acerwin [OP] The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
  10. Jan 18, 2016 at 12:57 PM
    #3450
    Taco No Baka
    Lee
    Tampa, FL
    I sat in a 3rd Gen Sunday (I was tuning his CB antenna for him). It's nice. I like the new dash a lot. :cool:
    Why is everyone getting them in that rust red color though? :p I'd get the sand color if I was going to get one. (Or black so I could have it wrapped or painted OD green and have the black door openings show when you opened the door.):thumbsup:
  11. Jan 18, 2016 at 1:12 PM
    #3451
    Tatts521
    Tatts521 Well-Known Member
    New Jersey, Jersey Shore
    2012 tacoma-04cbr1000rr-22ktm890duke R-19 wr450f-98rm250
    I seen the 3gen at my local toyota in the sand color. Hands down that would be my choice in color
    ragincajun35 and Warputer like this.
  12. Jan 18, 2016 at 1:12 PM
    #3452
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    Is there any way to put names on trucks for the meet? back glass maybe, what do they use to write on glass, crayon or something?
    ragincajun35 likes this.
  13. Jan 18, 2016 at 1:13 PM
    #3453
    Tatts521
    That's not a bad idea at all especially for peeps like me that don't know anyone in person
    JimboAnz likes this.
  14. Jan 18, 2016 at 1:27 PM
    #3454
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Won't be able to see my window, RTT is in the way
  15. Jan 18, 2016 at 1:28 PM
    #3455
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    , OK side window? tailgate, big banner, lol
    Tatts521 likes this.
  16. Jan 18, 2016 at 1:33 PM
    #3456
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Side window would work, unless we're wheeling haha
    JimboAnz[QUOTED] likes this.
  17. Jan 18, 2016 at 1:47 PM
    #3457
    Daria
    Daria Can I pet your dog? Moderator
    Dodging tumbleweeds
    Already planned on window chalk. Figured right passenger side of windshield. Mama D has this covered....
  18. Jan 18, 2016 at 1:56 PM
    #3458
    Taco No Baka
    Lee
    Tampa, FL
    Haha, that wouldn't work for me. :D It'd be covered in mud after the first puddle I went though and then probably get wiped off by the wipers that I had to use to see where I was going. :eek: Same issue with the side windows. But then again, it probably wouldn't be necessary for me anyway. I can almost guarantee I'd be the only flat OD green 1st on Swampers there.
  19. Jan 18, 2016 at 1:59 PM
    #3459
    Daria
    Dodging tumbleweeds
    The fun part will be trying to reach some windshields. #shortpeopleproblems
  20. Jan 18, 2016 at 3:26 PM
    #3460
    ragincajun35
    ragincajun35 Well-Known Member
    Spencer
    Louisiana
    2015 DCSB MG TRD Offroad
    See Builds....
    @Acerwin could make us some decals!! :D
    That would be sick so all of the photos of the trip would have all the rigs names.
    Pretty sure we will all recognize most of the trucks though
    Acerwin[OP] likes this.
