March 2016 Gulches ride with lots of BS (Aiming for biggest Southeast meet/trail ride EVA)
Discussion in 'South East' started by Acerwin, Nov 17, 2015.
March what?
Poll closed Dec 18, 2015.
  1. 4th
    1 vote(s)
    4.8%
  2. 11th
    2 vote(s)
    9.5%
  3. 18th
    13 vote(s)
    61.9%
  4. 25th
    5 vote(s)
    23.8%
  1. Dec 13, 2015 at 10:29 PM
    #1241
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    With the proper setup (a properly-tuned, full-length antenna, in an optimum mounting) and a decent, peaked and tuned CB, you can get out about ten miles or so if the weather is good. Further if the atmospheric conditions are just right. Trouble is, almost none of us run a full length antenna. I expect to get out about 3-4 miles or so with my new 3' antenna, though that will only be on the interstate. The range goes down considerably when in the woods with a lot of trees in the way, or in the hills.
    I'll say it again though, a Cobra 25 is really all you need. it's basically the same as a 29 just paired down to the most useful features and placed in a more convenient form-factor. Unless you're a trucker and need something to screw around with when not driving, the 29 is just overkill, IMHO.:cool:
    Oh, and you can still get out a long, long way with a CB. You just have to get an amplifier. It's illegal, but it's not like the FCC runs around looking for people running amplified CBs to arrest anymore. o_O
  2. Dec 13, 2015 at 10:48 PM
    #1242
    Taco No Baka
    Lee
    Tampa, FL
  3. Dec 14, 2015 at 12:10 AM
    #1243
    Taco No Baka
    Lee
    Tampa, FL
    So, I tuned my new antenna tonight. These are the results...
    Radio and equipment: 1990 Cobra 25LTD Classic (peaked and tuned), 9' Firestik Fire Ring coax, Firestik dome mount on the roof with a medium duty spring.
    3' FS Firefly Antenna:
    SWR on Ch1: 1.5
    SWR on Ch40: 1.7
    SWR on Ch20: 1.1 (the needle was actually slightly under that)
    I left it slightly biased toward the lower channels since Ch4 is the default trail channel and I'll probably be down there more often than I am on the upper quarter.
    With the 2' FSII antenna, it was...
    SWR on Ch1: 2.2
    SWR on Ch40: 2.2
    SWR on Ch20: 1.3
    As you can see, one foot more antenna netted me a huge improvement. I should get out a lot further now and it doesn't look too retardedly tall. Still going to be slamming it into a lot more stuff than I did with the 2 footer, but hopefully the firefly is flexible enough to take it. As long as it can take the abuse, I'm extremely happy with the new setup.
  4. Dec 14, 2015 at 10:09 AM
    #1244
    HHIRunner
    HHIRunner Former Heep Traitor
    Jake
    ATX
    ‘20 Taco
    Yep I need to install my new CB this week. Ordered it months ago and forget what model it is, but it's definitely a better unit than my current setup.
    Acerwin[OP] likes this.
  5. Dec 14, 2015 at 5:06 PM
    #1245
    Taco No Baka
    Lee
    Tampa, FL
    Okay, I was bored and screwing around with paint.net and I came up with this for a possible t-shirt design instead of the front of the stock 2nd gen (which I was never too partial to in the first place :wink:). Needless to say, I like this idea better.
  6. Dec 14, 2015 at 5:07 PM
    #1246
    Acerwin
    Acerwin [OP] The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    I'm down for that design!
    Taco No Baka[QUOTED] likes this.
  7. Dec 14, 2015 at 5:08 PM
    #1247
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    scottalot likes this.
  8. Dec 14, 2015 at 5:13 PM
    #1248
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
  9. Dec 14, 2015 at 5:13 PM
    #1249
    3milecreek
    3milecreek MtnGoat
    Stephen
    Barnwell SC
    Heavily Modified 94 Yota
    Never the same
  10. Dec 14, 2015 at 5:25 PM
    #1250
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    Has a date been set yet? I should have my new lift on by then.
  11. Dec 14, 2015 at 5:26 PM
    #1251
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Yessir the 18th of March
  12. Dec 14, 2015 at 5:30 PM
    #1252
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    This could go on the front :notsure:
    Taco No Baka likes this.
  13. Dec 14, 2015 at 5:32 PM
    #1253
    Warputer
    2011 TRD Off Road
    And what's the plan so far......wheeling the afternoon of the 18th....camping that night & more wheeling on the Sat?
  14. Dec 14, 2015 at 5:37 PM
    #1254
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    You got it haha and fishing in the creek if you want
  15. Dec 14, 2015 at 5:40 PM
    #1255
    Warputer
    2011 TRD Off Road
    OK....I work the night of the 17th......will be sleeping the 18th. I'd be down for first thing showing up on the 19th (Sat)! You guys still planning on playing that Sat?
  16. Dec 14, 2015 at 5:44 PM
    #1256
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Yeah most are staying till that Sunday so a lot of playing Saturday!
  17. Dec 14, 2015 at 5:51 PM
    #1257
    Warputer
    2011 TRD Off Road
    Cool.....I'm a most likely to show up on Sat. morning then. Of course I'll have to stay on the Mall Crawler trails. :thumbsup:
  18. Dec 14, 2015 at 5:53 PM
    #1258
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Nah I want to see that beast go rampage
  19. Dec 14, 2015 at 5:55 PM
    #1259
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    I also plan on showing up that Saturday morning and spending the day. I more than likely will not be camping.
    @Acerwin put me down for a shirt (M)
  20. Dec 14, 2015 at 5:56 PM
    #1260
    Warputer
    2011 TRD Off Road
    :laugh: SO I can blow out CV seals with 9" of lift? :facepalm:
    Acerwin[QUOTED][OP] likes this.
