Mark C.'s Mods
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mark C., Nov 4, 2010.
  1. Nov 4, 2010 at 1:37 PM
    Mark C.
    Mark C. [OP] If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    Here are a few of my mods. Anyone interested in "How-to", please ask. Most of the mods and ideas for them came from TW. Thanks all!
    Sorry about the pic quality..........getting used to camera and uploading this stuff.....hard for an old fart!
    Thanks for looking.........
    Non-TRD....so I improvised.
    [​IMG] Add-On Thermometer
    Didn't like the GPS above the Dash soooo.......
    [​IMG] Mount and Cable for GPS
    [​IMG] Back of GPS
    [​IMG] GPS Mounted
    Works great for checking just how close that tailgater is!
    [​IMG] Back-Up Camera Switch
    Cheaper than the push-button switch, and fits nicely.
    [​IMG] Older style lighted rocker fog switch
    Oznium LED Floods with modified reed switch activation.
    [​IMG] Engine Compartment Flood LEDs
    Got tired of the buckle banging on the hard plastic on rough roads.
    Sticky-backed felt pad cut to size from Home Depot.
    [​IMG] Seat Belt Buckle Pad
    [​IMG] Engine Flood LEDs 2
  2. Nov 4, 2010 at 2:40 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
  3. Nov 4, 2010 at 2:45 PM
    pauls2ndblessing
    pauls2ndblessing Well-Known Member
    Paul
    Alabama
    06 PreRunner SR5
    I like the engine bay LED's a lot man!
  4. Nov 4, 2010 at 2:49 PM
    MadeInMaine
    MadeInMaine MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    What kind of lights did you use for your engine compartment? You have great output from those...
    I just bought some strip LEDs and going to hook them up in near future
  5. Nov 4, 2010 at 2:50 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    x2^^^^^^^^^^^^^^^
  6. Nov 4, 2010 at 2:51 PM
    Logically Insane
    Logically Insane Well-Known Member
    Wes
    TN --- USA
    2010 PreRunner Access Cab
    Kobalt toolbox mounted with J-Hooks, Locks on storage compartments in bed, Window Visors, Toolbox LED Lights, Underbody Lights, More to come.
    Where did you run the little circular thingy for the thermometer? I've got the same one, and I just havent gotten around to running that part for the outside temperature.. lol
    looks good
  7. Nov 5, 2010 at 3:19 AM
    Mark C.
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    I got those from Oznium. 12V Marine LED floods. They are waterproof and are sometimes used for swimming pool lighting. The lights are automatically switched on when I lift the hood. I installed a relay and a reed (magnetic) switch along the side near the battery and a rare earth magnet attached to the hood. Makes it much easier to see in the night.....should you have the need to.
    The floods come in different colors.
    and............you can get them here:
    http://www.oznium.com/marine-led-light
  8. Nov 5, 2010 at 3:22 AM
    Mark C.
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    I will try to get you some pics tonight. I ran the wire under the door weather strip, along the fender/body seam, under the "lip" along the left side of the engine compartment and attached the probe on the inside of the grille with 3M HB double sided tape. I was surprised at how well it works.
  9. Nov 9, 2010 at 2:41 PM
    Mark C.
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    Some pics of thermometer sensor wiring run:
    [​IMG] Route temp sensor wire under weather strip and out gap between near hinges and between fender and hood.
    [​IMG] From under door weather strip up past door hinges.
    [​IMG] Temp sensor wire between fender and hood.
    After that, run it down the wire run inside the left front fender in the engine compartment, past the battery, under back of headlight, and attach to inside of grille using VHB (Very High Bond) 3M tape.
    Done!
  10. Nov 10, 2010 at 12:02 PM
    Logically Insane
    Wes
    TN --- USA
    Now, if I can remember where i put the thermometer, I'll do this, thanks for the help.
  11. Nov 10, 2010 at 12:04 PM
    Mark C.
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    If you can't find it.....they're $9.99 at Wally World! Good luck!
  12. Nov 17, 2010 at 1:44 PM
    Mark C.
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    I know the cross-member color of the stock grille on the 10 doesn't match the MGM....but painted and emblem with the fusion gray textured paint and applied a couple of coats of topcoat.
    Here are the pics...but it was starting to get dark and they may be hard to see...and I am still experimenting with the camera.
    Please comment. (I received another grille today from an 07, which has flat black cross-members. I am going to clean it up and apply some fresh flat black to see how it looks)
    With Textured Emblem
    [​IMG] Stock with Chrome Emblem
  13. Dec 4, 2010 at 7:36 AM
    Mark C.
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    Got bored and tried this. The cup holder is hold up very well after 3 weeks..and pretty hefty changes in temperature.
    Driver door
    Passenger door. Will let everyone know how it holds up.
  14. Dec 4, 2010 at 3:48 PM
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    I like the LED's under the hood. I may have to do that one.
