mark your oil filter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by scrantonscrambler, May 26, 2012.
  1. May 27, 2012 at 5:10 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    A newer Corolla may be tough, it has the non spin on filter.
    PK
  2. May 27, 2012 at 5:13 AM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    lol they wouldn't go near my truck, except for an alignment or a tranny flush.
  3. May 27, 2012 at 5:15 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    here is what I do
    I would never let anyone change my oil - this is for my own reference cause I usually go over 5k.
  4. May 27, 2012 at 5:19 AM
    2012 Tacoma
    2012 Tacoma Well-Known Member
    Todd
    Illinois/Arizona
    2012 SR5
    Undercover Classic, TRD Skidplate, Wet Okoles
    I've never been able to trust a dealer or Jiffy Lube..Last time I went to Jiffy (20 years ago and away from home) found the oil drain plug rounded out like the kid used a friggin pipe wrench on it because he didn't have a metric socket. I also don't trust them to use synthetic. I'm the only one under my truck unless it's a warranty issue.
  5. May 27, 2012 at 5:24 AM
    XXXX
    sKiP
    05 Prius
    The one time in over 15 years I didn't feel like changing my oil (freezing rain/snow - no garage) I took it in and supplied my own Mobil-1 and filter. I watched the service writer type "owner supplied oil/filter on passenger seat". When I got into my truck it was all sitting there still. I popped the hood, checked the dip stick, and walla freaking morons put in regular oil. I was in a rush so I flipped out at them got a $50 gift certificate I never used and never went back. I ended up flushing it out the next day in the freaking snow while blowing 3 quarts of synthetic... NEVER AGAIN.
  6. May 27, 2012 at 5:25 AM
    dYL0n
    Dyl0n
    New Orleans, LA
    I'll take that gift certificate....
  7. May 27, 2012 at 5:29 AM
    StickShifty
    StickShifty Well-Known Member
    New Jersey
    2012 AC 4WD 6SPD
    i would mention the dealer, so we can avoid it. i will be taking Toyota up on my 2 years of free oil changes, but i will be marking my filters for sure.
  8. May 27, 2012 at 5:39 AM
    XXXX
    sKiP
    05 Prius
    lol....that was when I was a Ford man and many years ago.
    That dealership took a poop and is now a Toyota dealer :D
  9. May 27, 2012 at 6:16 AM
    K Williams
    K Williams Well-Known Member
    Long Island, NY
    2011 TRD Off Road V6 MT
    Banks Monster Exhaust URD Stage II Clutch
    I'm taking my truck to an off road shop. I can't trust these stealerships anymore...
  10. May 27, 2012 at 6:18 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    I have not nor do I think I would ever pay for a oil change, especially after hearing these stories. I can not imagine a Toyota dealer not replacing a filter on a oil change. Thats Not Right...
    Its the best half hour I spend with my truck- thats about 1.5-2 hrs a year- to change the oil and filter I want to use, fill the window washer, look over everything, spray a little lube on the hinges, etc. Doing this keeps you rolling down the road with far less surprizes...:cool:
  11. May 27, 2012 at 6:26 AM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    I always do my own oil changes, even on my wife's new Sienna with the 2 years of free service. It is just something I like to do. I used to own a mobile oil change business in NY, and talked to a lot of people. You wouldn't believe how many folks have had very bad experiences with all kinds of places from Jiffy Lubes to Dealerships.
  12. May 27, 2012 at 6:50 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    I wish I could remember how it works exactly but all the lazy techs take the easy jobs because they pay the best and they generally don't do shit. My friend worked at a dealership for awhile and he shared the stories.
    Unless its something under warranty.... I don't let people touch my truck. I've always had to use a damn screwdriver to get the filters off after leaving Toyota. Fucktards don't know how to install a damn filter and play Hercules wrenching it down.
  13. May 27, 2012 at 6:54 AM
    TacoTitan11
    TacoTitan11 Well-Known Member
    Mr. C
    North Carolina
    2012 Tacoma
    wow....pretty sad that this happens but like i said, its your truck, you have to look out for yourself. cant rely on others. wow, pretty shady.
  14. May 27, 2012 at 7:03 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    I worked at a dealer for many years and usually the way it works is the kids get the oil changes, because they get paid hourly unlike the techs that get flat rate. The problem actually shows up more with warranty work because the warranty book pays shit times so SOME techs will shuffle it in and out to get another job, hopefully a customer pay job because the book was different. Then comes the UP SELL. That is where most techs and shops make their money, you go for the 30K service which includes all these extras besides the oil change, well the tech will check all that crap anyway hoping to find an issue to up sell. There is alot more to dealer life. Just like any place or any job it is the person that makes a differance so if you find a tech at the dealer that you like ask for him or her by name
  15. May 27, 2012 at 7:04 AM
    #35
    brian
    Elizabeth City, NC
    That's exactly what my friend told me! Thanks for the info!
  16. May 27, 2012 at 11:34 AM
    #36
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Jiffy Lube oil wouldn't bother me. It's Pennzoil, which is decent stuff.
    Jiffy Lube oil filters do bother me. They're Pennzoil, which are Fram.
    I always laugh my ass off when I see "disturbed" oil filter boxes at K-Mart and see that someone has swapped a Pennzoil for a Fram filter... paying the Pennzoil price and thinking they're getting a better filter when it's the same thing :D
  17. May 27, 2012 at 11:37 AM
    #37
    Rich91710
    Rich
    Los Angeles
    08 Base
    Took my wife's '00 Echo in to Longo Toyota for the brake booster recall.
    They would not release the car back to us without doing a full front brake job (they claimed it needed rotors and calipers, the car was only a year old!)
    Took an hour of fighting the manager and finally threatening to call the owner.
  18. May 27, 2012 at 12:12 PM
    #38
    zul
    zul Professional Goofball
    PNW
    2012 Pyrite Mica DCSB SR5 4WD V6 AT
    HAVE: Bed mat, Tailgate Lock, Color-matched Grille, Weathertech Floor Liners, Avid Step Rails, RokBlokz mud flaps WANT: Rear Plate Bumper, Steel bed cage
    Took my truck in for it's first free oil change - I was only at 2350 miles but it had been about six months. I didnt want to wait til 5000 miles and have them deny service or warranty or whatever. I marked the filter before I drove there. Drove home and checked it... They changed the filter. Next time I'd like to mark the wheels to make sure they rotate them like they said they did. How do you do that? Where do you mark the wheels, and with what?
  19. May 27, 2012 at 12:22 PM
    #39
    Rich91710
    Rich
    Los Angeles
    08 Base
    Chalk on the inside sidewall of the tires, magic marker on the inside of the wheels.
  20. May 27, 2012 at 12:32 PM
    #40
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    If you want to make sure your tires are rotated all you have to do is look at them. For example the tread will wear perfectly flat across on the rear, the front tread will have a rounded surface. This is if your tires are correctly inflated and your getting close to another 5K service. So it should be fairly easy to spot if the job was done without crawling under your car.
