Marker light signals with headlights on?
Discussion in 'Technical Chat' started by tbird95, Jan 27, 2019.
  1. Jan 27, 2019 at 2:36 PM
    tbird95
    tbird95 [OP] Well-Known Member
    British Columbia, Canada
    TRD sport SR5 V6 DC, LB, 4x4, Tow package
    4runner heated, signal, courtesy light side mirrors, rearview mirror w/compass, temp & backup cam w/ pop luck PL 5400, Interior lights/gauges, BHLM, grillcraft MX black. Third brake light LED swap, rear tail lights LED swap from 2011. 3" Toytec (Boss) Coil overs, rear TSB AAL Bilsteins, Light Racing UCA. TRD grill badge, VIPER Smart Start.
    Anyone know how to get your side marker/parking lights to act as signal WITH HEADLIGHTS ON? I can get them with dtrl mod and marker flash mod but nothing if i turn on headlights and that just wont work at night.
  2. Jan 28, 2019 at 12:01 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    The only way this can be done unless the coffee has not kicked in.
    Is to go to a dual filament bulb or install a second bulb one for marker lights and one for turn signal .
    where you are do you need the marker light ?
    using a trailer converter might be possible using those bulbs the same as trailer lights just thinking out loud
  3. Jan 28, 2019 at 12:16 AM
    tbird95
    Might be possible to get dually leds....pretty sure they exist just not about tacos. Not sure if they are mandatory and the gov't speak is a bit confusing on that point.
  4. Jan 28, 2019 at 2:02 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
