Marking drive shaft for u joint replacement??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Orion, Sep 7, 2014.
  1. Sep 7, 2014 at 7:03 AM
    Orion
    Orion [OP] Well-Known Member
    Rhode Island
    Tacoma TRD
    Why does one need to do this?
    Dealer wants $330 to change out 1 u joint (middle one) on my 2009 tacoma double cab...I hate them!... I'm not even sure that is the problem. I have been having an increasing vibration going between 10 and 40 mph. No clunking......... anyway;
    I have a friend who can do it and it would be a good start but he is a bit old school. He doesn't think we need to mark the shaft......I want to be sure if we do it its done correctly.
    How important is this and if it needs to be done do I need to mark it all the way down or just the front and back connecting points??
    thanks
    steve
  2. Sep 7, 2014 at 7:13 AM
    photonashville
    photonashville Well-Known Member
    2006 Silver 4x4 long bed with Leer
    The segmented driveshaft is balanced over the full length. You'll notice the weights on the shaft tube. Reassembling it out of it's factory orientation may induce unwanted vibration. Just make tick marks with whiteout, paint pen or something that won't come off at each junction from piece to piece.
  3. Sep 7, 2014 at 7:16 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    What exactly are you trying to mark, and whats the point of marking it?
  4. Sep 7, 2014 at 9:37 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    YES - Mark it!!
    You'll want to mark one of the EARS....and mark the matching shaft on the other side of the U joint. So...when you put it back together, you can allign the marks together. You'll want to get both shafts in the same orientation to each-other as they were.
    It's hard to explain...some of it has to do with weight/balance, others has to do with wear in, etc.
    It's one of those 'preventative' things. There's enough folks on here who have experienced worse vibrations after changing the ujoint because they didn't mark the shafts. Anytime I change ujoints or anything driveshaft related - I mark the shit out of everything to help prevent future headaches.
    Just sayin.....
  5. Sep 7, 2014 at 9:44 AM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Holy cow! I had all 3 joints and the center bearing replaced with Spicer parts, shaft checked for runout, re-balanced, and painted at at a driveshaft shop for less than $200!
    I marked the flanges on the TC/diff too. If it's machined correctly it shouldn't make a difference but I didn't want to take any chances. It could be a nightmare figuring out where it was from the factory. I've read about others here going through that in the past :(
  6. Sep 7, 2014 at 12:52 PM
    XJ1100JKen
    XJ1100JKen Well-Known Member
    Ken
    Tullahoma, TN
    2014 BIG SILVER LEMON
    Yes, make alignment marks on the both sections, don't want to reassemble it 180 degrees off. Since you are not removing the center yoke or CB it should be pretty easy.. two sets of hands and a ball joint/u joint service tool will really help. I've done all 3 a couple times recently.. that tool really helps.
    You might want to inspect the carrier bearing (and other u joints) prior starting the project, that way you don't have to pull that center u joint twice. You'll need a puller, torque wrench and the torque specs to replace the CB and install the center yoke. There is a sticky on the main page with everything you'll need, even a diagram showing order of assembly and where that spacer goes. After removing the nut and washer holding the yoke, I made a small (very gently) punch mark on the shaft and yoke near the splines. I prefer marks rather than tape, sharpie or white out.
    Driveshaft Parts USA sells the CB for $28+around $10 for shipping. part number CBTHN
    The ball joint service kit is from HB $79.99 Item#60827 , use a 20% off coupon
  7. Sep 7, 2014 at 10:30 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I always use a center punch and hammer. If you have ever had a marker or paint pen mark come off you would too.
    A good center punch mark isn't going anywhere.
    Single dent on one side and a double on the other. The single punch aligned between the double punchs.
  8. Sep 12, 2014 at 6:15 PM
    Orion
    Rhode Island
    Tacoma TRD
    Thanks all. I had all three replaced for $200. It was worth it for me and seems to have fixed the vibration....
  9. Jan 10, 2016 at 2:28 PM
    mgfuson
    mgfuson Active Member
    2010 Tacoma 4x4 DCLB
    King 2.5 with remote reservoirs and 650# coils, SPC UCA, 5100's, Dakars, Pelfreybilt Aluminum front, Pelfreybilt Hi Clearance rear, 16x8 Relations Race RR4 in matte bronze, 285/75r16 KO2's, custom bed rack, FSR RTT.
    Anyone know what to do if my drive shaft was removed and reinstalled without being marked. I am getting all kinds of vibes now.
  10. Jan 11, 2016 at 9:17 AM
    cj13058
    cj13058 Well-Known Member
    Oregon
    2024 Tacoma TRD Off-Road Premium iForceMax Bronze Oxide
    2024 Tacoma TRD Off Road Premium iForceMax Bronze Oxide - AluCab Contour canopy 2005 Tacoma TRD Off Road DCSB Radiant Red - ARB 3'' lift, ARE canopy, 265/75/16 All Terrain KO2, after market stereo, ECGS differential bushing, ARB Deluxe front Bumper, Warn M8000 winch, custom winch control box install, FrontRunner Slimline canopy rack,
    Take it to a shop. I replaced all of my ujoints after a lift to try and get rid of the vibrations. I must have made a mistake somewhere, because the whole shaft came off the truck at 70 mph. Lucky it didn't damage anything else or FLIP the truck over. And it was quite a bit more than $200:(
  11. Jan 11, 2016 at 9:27 AM
    mgfuson
    Ouch, well it's actually at Toyota right now.
  12. Jan 11, 2016 at 9:30 AM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    Marking is simple and free, why not? I never used to mark them when I changed a u-joint. I never had troubles either. Old school I guess.
  13. Jan 11, 2016 at 9:37 AM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Shafts aren't balanced with anything in the rear end during assembly. Marking isn't needed but I guess doesn't hurt.
  14. Jan 11, 2016 at 9:47 AM
    mgfuson
    I probably would have marked it if I replaced them myself. My mechanic didn't mark them though, after replacing three u joints the truck rode terrible.
  15. Jan 11, 2016 at 9:53 AM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    It is easy enough to mark your drive shaft and reassemble it in the same way. Even if it doesn't matter it is nice for peace of mind knowing you don't have to worry about it. I've always marked it and put it back in just the way it came out.
  16. Jan 11, 2016 at 3:15 PM
    ebulang
    ebulang Active Member
    Manny
    Cumming, GA
    SR5
    Is there any DIY instructions here that I can follow in replacing all 3 U-joint?
  17. Jan 11, 2016 at 3:49 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    The reason for the marks is drive shaft timing and to prevent vibrations.
  18. Jan 11, 2016 at 5:32 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
  19. Jan 11, 2016 at 6:05 PM
    ebulang
    Manny
    Cumming, GA
    SR5
  20. Jan 12, 2016 at 2:14 AM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    Exactly,I'd like to know how this whole "marking your driveshaft" started. I remember this years back when I was heavy into the 5.0 scene.
