Marlin Crawler Taco Box in 2004 SASED Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by awsumdc, Jul 2, 2012.
  1. Jul 2, 2012 at 9:42 AM
    awsumdc
    awsumdc [OP] Well-Known Member
    O.C. Cali
    SASED '05 Taco
    SAS, crawler box, 14" coilover shocks, 39.5 tires,dual batteries, and a bunch of other stuff
    Saturday Dan and I installed a Taco Box into Cameron's 2004 Tacoma that has had a previous SAS.
    First off I would like to say what a joy it was to work with Cameron and his MUCH better half Katie. They were absolutely great.
    Anyway, Cameron has owned this truck for about a month and it has the Sky Manufacturing leaf spring SAS kit on it and who ever did that part of the truck did a very good job. Can't say the same about some of the rest of the truck but Cameron, or should I say Katie, because she's the most mechanically inclined in that twosome, will take care of any of the issues this truck may have and they are starting at a good spot with adding a Marlin Crawler Taco Box with 4.7 gears in it.
    This Taco Box is actually a hybrid of sorts. It seems that Marlin Crawler and Inchworm have teamed up to make one awesome crawler box. The front and rear adapters are Inchworm with the rear clocking plate being a derivitive of Marlin's rear clocking plate, while the internals are all Marlin Crawler hardware.
    At first this set up can be quite confusing because the front and rear plates are designed to work with a number of different applications. After some figuring out from Dan and I we were able to install this and come away with a leak free install.
    They drove down from the bay area about 8 hours away and were on the road the next morning and when they got home they reported that there was no noise at all, the interior was closed up tight and not one drop of fluid anywhere. I love it.
    Here is the new crawler. Pretty....
    First thing we had to do was cut off this skid plate frame that the previous owner installed. That was a pain because it looked like he was trying to support a battle ship with this one tube.
    I mean...look at how thick this stuff was...
    After that was done we took the t case out and then I opened it up because we thought we had a problem with the coupler. When I got it opened I noticed there were some differences from other chain case's that I haven't seen before. One was this synchro on the low side of the planetary gear set. Why in the world would there be a synchro on the hi/lo section of the gearset. A call was made to the man himself, Marlin, and he cleared it all up for me. Since this is a fully manual case behind a manual transmission, but the case is still shift on the fly, Toyota put a synchro both on the 2wd/4wd section and the hi/lo section. I know, it's not there on the FJ case six speed but that is because the FJ has ADD hubs and not manual hubs. With that and the fact that this truck is a 2004 Tacoma my guess is this t case is from an earlier Tacoma that had manual hubs unless this truck came from the factory with manual hubs. Here is a picture of the synchro on the planetary side.
    And this is where it goes.
    This case also has the smaller 26 spline input shaft but shouldn't be an issue since it's behind the 2.7
    Since this has a 26 spline input but the crawler has the bigger 23 spline input we have to use a special coupler that has both the 26 spline for the transmission side and the 23 spline for the Taco Box side.
    While I was in the t case Dan clean out the oil pick up screen. It was pretty clean to begin with but we wanted to make sure it was perfect.
    Got it all installed, here the t case is not yet bolted to the crawler.
    Put the shifters in and they were on their way back to their hotel for some sleep and an early morning drive back to the Bay Area.
    Another RockSolidToys install in the books and happy clients as well.
    Stay safe and be good people.....
  2. Jul 2, 2012 at 9:47 AM
    cgs2k2
    cgs2k2 old man
    awesome. sweet rig
  3. Jul 2, 2012 at 12:00 PM
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    sweeeet!!!!
  4. Jul 2, 2012 at 1:25 PM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Very cool. Thanks for sharing that with some good info.
  5. Jul 2, 2012 at 5:19 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    very awesome write up! That truck is beautiful.
  6. Jul 2, 2012 at 5:49 PM
    cameronlane
    cameronlane Well-Known Member
    cameron
    Anywhere but there
    2014 Dbl Cab TRD OR 4x4
    prp premier high backs
  7. Jul 6, 2012 at 5:48 PM
    pikuptruk
    pikuptruk Well-Known Member
    Vallejo
    01 4x4 2.7 Lifted
    6" Fabtech Lift 33" Tires Flowmaster Cold Air Intake
    Got more pics?
  8. Jul 6, 2012 at 6:01 PM
    cameronlane
    cameron
    Anywhere but there
    what do you want to see?
  9. Jul 6, 2012 at 6:05 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Damn! That's a bad ass 1st Gen!!!!
  10. Jul 6, 2012 at 6:05 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    Everything :drool: sweet truck
  11. Jul 6, 2012 at 6:18 PM
    cameronlane
    cameron
    Anywhere but there
    thanks guys
  12. Jul 6, 2012 at 6:19 PM
    amocat 777
    amocat 777 Well-Known Member
    Tacoma Doublecab
    Nice work! My truck is jealous:eek:
  13. Jul 6, 2012 at 6:24 PM
    Slodgetto
    Slodgetto Ăśber Posre
    Silas
    Very nice thread! Thanks, Wyatt!
  14. Jul 6, 2012 at 6:41 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    :drool:
    Crawl box will most likely be my next 'expensive' mod.
  15. Jul 6, 2012 at 9:03 PM
    awsumdc
    O.C. Cali
    SASED '05 Taco
    Your very welcome!
  16. Jul 6, 2012 at 11:32 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Ya no kidding. I'd love one as well
  17. Jul 7, 2012 at 6:42 AM
    pikuptruk
    Vallejo
    01 4x4 2.7 Lifted
    I'd like to see some pics of the after section with the tube work. Also some of the unde carriage. Did you mention which axels were installed? This is exactly what I'm planning on doing with my 01.
  18. Jul 7, 2012 at 6:45 AM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    Sweet, Mine next!? :D
  19. Jul 7, 2012 at 10:24 AM
    awsumdc
    O.C. Cali
    SASED '05 Taco
    Sure. Bring it down to Southern Cal and we'll fix ya right up.... ;)
  20. Jul 9, 2012 at 10:15 AM
    cameronlane
    cameron
    Anywhere but there
    Ill try to get some pics up today. The front axle is a dana 44 with chromoly shafts and an arb and 5.38 gears. rear is stock axle with detroit with 5.29 gears
