Marlin Crawler's 7th annual Maintenance May!
Discussion in 'Marlin Crawler' started by BigMike, May 2, 2019.
  1. May 2, 2019 at 4:41 PM
    BigMike
    BigMike [OP] Applied common sense Vendor
    Fresno, CA
    2016 56-speed 580:1 Triple Marlin Crawler-equipped TRD Sport
    Welcome to the 7th annual Maintenance May!
    To get things started we are offering 10% OFF on Axle & Knuckle Gasket, Seal, and Bearing rebuild kits!
    Fix leaks and refresh your bearings and seals before the wheel'n season gets underway!
    MarlinCrawler.com/maintenance-may
    Front Axle Service Kit
    $189 $170.1
    Knuckle Service Kit
    $99 $89.1
    Knuckle Gasket & Seal Kit for 1979-85 Pickup/4Runner
    $49 $44.1
    Knuckle Gasket & Seal Kit for disc brake FJ40-62 Land Cruisers
    $49 $44.1
    Front Wheel Bearing Kit
    $49 $44.1
    Rear Axle Service Kit, 1979-99
    $69 $62.1
    Rear Axle Service Kit, 2000-04
    $89 $80.1
    Rus$ likes this.
  2. May 2, 2019 at 4:47 PM
    BigMike
    Fresno, CA
    Additional News & Updates for the month of May!
    New Flat-rate shipping HD Seat & Socket Combo
    We have rolled-out our all-new Heavy Duty Seat & Socket Combo Deal!
    FLAT-RATE SHIPPING OF ONLY $5.02! Check it out here!
    NEW: Heavy Duty Seat & Socket COMBO
    Items in-stock with fast shipping!
    ALL 1979-95 REAR BUMPERS!
    In-stock, ready to ship!
    ALL CLUTCH KITS!
    Caliper Hard Line
    Extended Brake Line Kit, Hilux
    Extended Braided Brake Line Female-Female
    Extended Braided Brake Line Male-Female
    Tacoma Extended Brake Line Kit
    Heavy Duty IFS Steering Box Mount Kit
    Oversized Wheel Cylinder
    High Performance Vented Rotor Set
    Standard Vented Rotor
    R-series Heavy Duty Bearing Retainer
    Crossmember Mount, HD
    V6 IFS Front Brake Caliper, BRAND NEW FROM JAPAN!
    V6 IFS Front Brake Caliper, Rebuilt
    Our Latest YouTube video
    Check out our latest video of our customer George Otwell demonstrating the
    smooth throttle finesse you get when a TacoBox is combined with an
    Automatic transmission. 2001 Supercharged 3.4-liter V6 Tacoma.
    https://www.youtube.com/watch?v=mW2RB_VyIyI
    Our YouTube Channel is growing and we'll be posting many new videos this summer!
    If you haven't subscribed, then give our YT channel a look and consider subscribing today!
    MarlinCrawler.com
    Rus$ likes this.
  3. May 7, 2019 at 2:50 PM
    BigMike
    Fresno, CA
    Update on more in-stock and ready to ship products!
    25mm Steering Pin Upgrade, Kit
    25mm Steering Upgrade Kit w/ Arms
    23mm Tie Rod Ends
    Tapered Pitman Arm Insert
    Tapered Tie Rod Adapter
    On Sale for only $7.99
    Hand-made 1979-1995 Classic Rear Rock Crawling Tube Bumpers heading out to trucks nation-wide!!
    MarlinCrawler.com/armor/rear-bumper/
    Click here for Tech Info on the above popular Dana 60-sized 25mm Steering Upgrade Kit!
    [​IMG][​IMG]
    [​IMG][​IMG]
    Thank you for all the orders! Looking forward to another great wheel'n season!
    MarlinCrawler.com
    Rus$ likes this.
  4. May 11, 2019 at 4:52 PM
    BigMike
    Fresno, CA
    Round No. II is here!!
    For Round No. II we are all about getting your Transfer Case up to excellent working condition before getting out on the trail
    3-speed Rebuild Kit
    $199 $179.1 Save 10%!
    4-speed Rebuild Kit
    Full Rebuild Kit
    $299 $269.1 Save 10%!
    Gasket and Seal Rebuild Kit
    $49 $44.1 Save 10%!
    Gasket and Seal Rebuild Kit, 1988-95 V6
    $90.19 $81.17 Save 10%!
    Flange Dust Shield, T/C
    $5.00 $4.75 Save 10%!
    Gear Drive Counter Shaft Bearing
    $29.52 $26.57 Save 10%!
    Gear Drive Input Bearing
    $25.52 $22.97 Save 10%!
    HD Transfer Case Rear Output Seal
    $9.99 $8.99 Save 10%!
    Heavy Duty Shift Spring
    $4 $3.6 Save 10%!
    Heavy Duty Shifter Seat, Forward Shift
    $12.49 $11.24 Save 10%!
    Input Pocket Bearing
    $15 $13.5 Save 10%!
    Low Speed Gear Cage Bearing
    $13.8 $12.42 Save 10%!
    While you're working on your T/Case,
    we've got GEARS IN STOCK and READY TO SHIP!!
    4.70:1 XD Gear Kit
    Most advanced 1979-95 gear set, Used in 1979-2019+ Dual Case Setups!
    In Stock! Ready to ship!
    Total Spline Input Gear
    Strongest 1979-95 2.28:1 Input, Used in 1979-2019+ Dual Case Setups!
    USA-Made Heavy Duty Transfer Case Mounts
    Check up on the condition of your transfer case mount because we've just finished another batch of our HD Mounts!
    MarlinCrawler.com/armor/crossmember/crossmember-mount-hd
    More 1979-95 Rear Tube Bumpers heading out!
    We are building and shipping out dozens of rear bumpers every week!!
    Check out pictures of our Rear Tube Bumper from Trevor's 2nd gen 4Runner
    [​IMG] [​IMG] [​IMG] [​IMG]
    More to come soon! Subscribe to our Newsletter to stay updated!
    MarlinCrawler.com/newsletter
    Regards,
    BigMike
  5. May 30, 2019 at 9:28 AM
    BigMike
    Fresno, CA
