Marlin Crawler's New Rock Crawling Long Travel IFS Suspension System (#RCLT)
Discussion in 'Long Travel Suspension' started by BigMike, Feb 2, 2019.
  1. May 3, 2022 at 2:31 PM
    #2381
    Tac05
    Tac05 Unknown Member
    2005 Tacoma DCLB
    None at all. I went spring under in the rear which is very stable. In fact I can't max out the springs. Once all my gear is in the back I think it will help.
  2. May 3, 2022 at 2:33 PM
    #2382
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    The steering is normal. You need more volume and pressure to move the bigger rack and tires.
  3. May 3, 2022 at 2:34 PM
    #2383
    Tac05
    2005 Tacoma DCLB
    Just one. I have a little 20 cu ft bottle, but thinking of an even smaller one mounted under the hood. 1 qt of oil is enough to fill both shocks and reservoirs. The dual fill regulator doesn't take much room either.
  4. May 3, 2022 at 2:36 PM
    #2384
    Tac05
    2005 Tacoma DCLB
    It kinda handles like a go kart now, not as nimble obviously, but the steering doesnt right itself, it kinda holds position. Can't imagine how heavy the steering is with 40's. I am sure I will get used to it, but it was noticeable on the first drive.
  5. May 3, 2022 at 2:44 PM
    #2385
    la0d0g
    running for the hills
    For crawling not hauling
    I found a pic from that trip of my taco and the jeep.
  6. May 3, 2022 at 2:47 PM
    #2386
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    That door is giving me ideas. I like that
    ovrlndkull and la0d0g[QUOTED] like this.
  7. May 3, 2022 at 3:31 PM
    #2387
    la0d0g
    Built as a step to get in with a strap to pull out up. Pretty cool setup.
    JoeCOVA[QUOTED] and ovrlndkull like this.
  8. May 3, 2022 at 3:36 PM
    #2388
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
    fold down door/step -- awesome idea
    Slashaar and ovrlndkull like this.
  9. May 3, 2022 at 3:51 PM
    #2389
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    this is the same as asking if you carry oil for your coilovers. :facepalm:
    Either way, they can leak, ori or not.
  10. May 3, 2022 at 3:58 PM
    #2390
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    That was in response to carrying extra seals for the ORIs no sense in carrying the seals if no nitrogen.
    JoeCOVA and Slashaar[QUOTED] like this.
  11. May 3, 2022 at 4:01 PM
    #2391
    Slashaar
    Josh
    Kansas City, MO
    He said this from the get go. Leaks are relevant to all shocks/struts. :notsure: Maybe I misunderstood the point he was trying to make.
    EDIT: I guess with a normal coilover you still have the coil is what he's saying.
    JoeCOVA[QUOTED] likes this.
  12. May 3, 2022 at 4:11 PM
    #2392
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    So the exchange was about spares. Guy with ORIs says he carrys seals not a full strut well without tooling and nitrogen and possibly oil there is no point to carrying spare seals. Also like he said the big downfall is the you blow one out you're riding on bumps the whole way back to camp. Or doing a repair of said seals on the trail just seems nuts. I can see carrying some spares and tooling to do at camp possibly. Like I carry all kinds of shit with me most of it stays back at camp I carry just what would be needed to get my ass off the trail then do anything major at camp. So when the guy said he brings seals he said do you bring nitrogen because the ORIs use the nitrogen as their spring and without it hence riding back on bumps so no use in carrying spares without everything needed to do a rebuild.
  13. May 3, 2022 at 4:14 PM
    #2393
    Slashaar
    Josh
    Kansas City, MO
    Fair enough. I realized this all after I thought about it harder. Juggling a lot in the ol' noggin lately.
    JoeCOVA and ovrlndkull[QUOTED] like this.
  14. May 3, 2022 at 4:21 PM
    #2394
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Has it had an alignment since the kit was installed?
  15. May 3, 2022 at 6:18 PM
    #2395
    Tac05
    2005 Tacoma DCLB
    The resulting effect of a leak will be related to where the leak is. It could be the spring rate chamber, which wont put you on your bumps, or the ride height chamber. If the result is "riding on the bumps" and the issue is more than a slow leak that a refill wont solve, at least temporarily, I'd probably lower the bump down to maintain ride height.
    They suggest having a tank of nitrogen with you so you can change the tuning if your heart desires.
  16. May 3, 2022 at 6:19 PM
    #2396
    Tac05
    2005 Tacoma DCLB
    Not yet. That is on my list of tasks this week.
  17. May 4, 2022 at 8:48 AM
    #2397
    betterbuckleup
    Ian
    Concord, CA
    That could help with steering effort if it's out of whack in the castor
    ovrlndkull and Airdog like this.
  18. May 4, 2022 at 11:03 AM
    #2398
    Tac05
    2005 Tacoma DCLB
    That is a good point.
  19. May 12, 2022 at 4:02 AM
    #2399
    JC Heng
    JC Heng Member
    Jeff
    Clarksville, TN
    2018 Taco
    Front camera, tailgate pop & lock, bed stiffeners
    Update on the UCA issue. F367BC0C-1778-4725-8029-02D14D70D399.jpg I guess this is a good sign. Hopefully mine was just a one off and no one else runs into this. Thanks to everyone for your help.
  20. May 12, 2022 at 10:09 AM
    #2400
    Tac05
    2005 Tacoma DCLB
    Good they are handling that for you. I am surprised it passed visual inspection before shipping.
    Slashaar likes this.
